Laser Welding Vs Traditional Welding
Laser Welding Vs Traditional Welding: Process, Advantages and Applications
Laser Welding Process
Laser (Light Amplification by Stimulated Emission of Radiation) welding is a fusion welding process in which metals or thermoplastics are joined using a focused laser beam. It is the most advanced type of welding method and finds application across many industries spanning from aerospace and medical equipment to fine jewellery making.
In the laser welding process, a concentrated beam of light is focused on the cavity between the materials to be joined. The powerful laser beam melts the materials at their seams and fuses into a joint. A highly concentrated heat source allows laser welding in thin sheet metal to be conducted at high speeds of metres per minute. In thicker materials, laser welding can produce deep and narrow welds.
Advantages Of Laser Welding
Less heat
Faster processing time
Lower risk of thermal distortion
As the process involves low heat input, there is less thermal stress. The focused beam melts only a small surface area of the metal, resulting in minimised heat-induced internal stress and distortion to the workpiece.
High precision
Laser Welding Application
Due to its high precision, faster processing time, wide material tolerance and consistent high quality, laser welding has various applications, including:
  • Automobile
  • Tool construction
  • Steel construction
  • Shipbuilding
  • Fine jewellery
Traditional Welding Process
Some of the most common types of traditional welding processes include – Gas Metal Arc Welding (GMAW/MIG), Gas Tungsten Arc Welding (GTAW/TIG), Shielded Metal Arc Welding (SMAW) and Flux Cored Arc Welding (FCAW).
Advantages Of Traditional Welding
Low cost
Easy to work
Easy implementation
Traditional Welding Application
  • Shipbuilding
  • Construction
  • Automotive
  • Mechanical
  • Steel structures
  • Pressure vessels
  • Aerospace
  • Autobody repair
  • Railways
  • Industrial piping
  • Manufacturing plants
Laser welding and traditional welding each have their own set of advantages. Traditional welding is easy to implement and master and requires less investment, thus making it suitable for all fabrication and manufacturing sectors. Laser welding is the most advanced type of welding. It offers high precision, low heat distortion and faster processing time. This makes laser welding suitable for applications that require high precision. You must decide which welding method is right for you based on the application, type of project and budget.
Laser Welding Traditional Welding
Heat-affected zone (HAZ) Smaller heat-affected zone (HAZ) as the concentrated laser beam is focused on a small area of the workpiece. Higher heat-affected zone (HAZ) as the heat is applied on a large surface area of the workpiece.
Temperature input Requires low-temperature input due to smaller heat-affected zone (HAZ). Requires high-temperature input due to large heat-affected zone (HAZ).
Precision Offers high precision welding as the laser beam can be controlled and focused on a small area of the workpiece. Does not offer high precision as the heat cannot be focused on a small area of the workpiece.
Thermal distortion The workpiece has low thermal distortion due to low heat input and a small heat-affected zone (HAZ). The workpiece has thermal distortion due to high heat input and a large heat-affected zone (HAZ).
Investment Requires high investment Requires low investment
