Should I Use 4043 or 5356 Filler Alloy?
Which Aluminium Filler Alloy To Choose?
What are 4043 and 5356 filler alloys?
As a basic description, we can say that 4043 is an aluminium filler alloy with 5% silicon added and that 5356 is an aluminium filler alloy with 5% magnesium added.
There are some misconceptions within the industry that you can successfully weld any aluminium base alloy with either 4043 or 5356 filler alloy. But this is not the case. However, there are many common structural aluminium base alloys that can be welded with either 4043 or 5356. One such alloy is 6061.
Should I use 4043 or 5356 filler alloy?
One of the frequently asked questions from most of the welders is – When should we choose one of these filler alloys over the other?
When the filler alloy selection chart allows the use of either 4043 or 5356 as filler for a specific base alloy, as a guide, we may wish to consider the following facts about each of these filler alloys:
  • Colour match – 4043 should not be used if you are considering the best colour match after post weld anodising, as this filler alloy will typically turn dark grey after the anodising process. 5356 will provide a much closer colour match after anodising.
  • Temperature – 4043 is suitable for service temperatures above 150 Deg. F, however, 5356, because of its 5% magnesium content, is not suitable for these elevated temperature applications.
  • Ductility – 4043 has lower ductility than 5356. This may be of some consideration if forming after welding is to be carried out.
  • Shear Strength – 4043 has lower shear strength than that of 5356 (see Fig 1). This may be of consideration when calculating the size of fillet welds.
  • Alloy softness – 4043 is a softer alloy in the form of spooled wire when compared to 5356. Typically, when Gas Metal Arc Welding (GMAW), feedability will become a less critical issue when feeding the more rigid 5356 alloy.
  • Weldability – 4043 will typically provide a higher rating for weldability and provide slightly lower crack sensitivity. 4043 will generally tend to produce welds with improved cosmetic appearance, smoother surfaces, less spatter and less smut. For this reason, it is sometimes more appealing to the welder.
Fig 1. Shows the typical shear strengths of various filler alloys. As can be seen, 4043 has 15 ksi in transverse shear and 5356 has 26 ksi when loaded in the same transverse direction.
Filler Alloy Longitudinal Shear Strength (KSI) Transverse Shear Strength (KSI)
1100 7.5 7.5
2319 16.0 16.0
4043 11.5 15.0
4643 13.5 20.0
5183 18.5 28.0
5356 17.0 26.0
5554 15.0 23.0
5556 20.0 30.0
5654 12.0 18.0
Summary
It is wise to use the filler alloy selection chart to assist with the selection of the most appropriate filler alloy to be used. It is also wise to conduct procedure qualification testing to evaluate the filler alloy selected to verify its performance characteristics.
