This is Part 3 of 3 in ESAB University’s filler metal packaging selection series. Part 1 covered the selection framework and “which format fits which job.” Part 2 focused on bulk wire drums for uptime. This article addresses moisture control—specifically for submerged arc welding (SAW) flux and low-hydrogen covered electrodes (SMAW/MMA). Quick Links Why moisture control matters When moisture-control packaging makes sense BlockPac for SAW flux BlockPac performance data VacPac for low-hydrogen electrodes Moisture-control SOP checklist Learn more Why Moisture Control Matters Fluxes and low-hydrogen electrode coatings can re-absorb moisture from the atmosphere. In moisture-sensitive workflows, that exposure can increase the risk of hydrogen-related discontinuities (such as hydrogen-induced cracking) and porosity, driving rework, added inspection, and avoidable downtime. Takeaway: If your quality system depends on moisture controls, packaging can be the simplest control point because it reduces exposure before the consumable reaches the floor. When Moisture-Control Packaging Makes Sense Choose moisture-control packaging when: The work is moisture sensitive by design: SAW flux systems or low-hydrogen SMAW procedures for critical joints and thick sections. The environment is high exposure: outdoor staging, coastal/offshore humidity, and field fabrication where climate control is limited. You pay a “moisture tax” today: routine flux re-drying, frequent electrode re-baking, or scrap/rework from opened consumables. BlockPac™ for SAW Flux: How It Works and Where It Fits BlockPac is moisture-protected packaging for agglomerated submerged arc welding fluxes. Flux from a 25 kg BlockPac can be used directly from the package without re-drying. Download Brochure Packaging construction BlockPac uses a laminated, multi-layer aluminum foil with welded seals to protect flux against moisture re-absorption. The packaging is designed for long shelf life without special warehouse conditions, provided the foil is not damaged. How to use BlockPac correctly Receiving inspection: segregate any pack that is punctured, torn, crushed, or deformed. Storage: protect packs from forklift/edge damage and avoid crushing stacked pallets. Opening and use: open only what you plan to consume and minimize open-to-air time. “Block shape” rule: once opened, flux remains dry as long as the bag stays in block shape (no air inside / retains its form). If block shape is lost: treat as exposed flux and revert to your site’s flux handling/re-drying procedure. Best-fit applications: SAW in structural steel, shipbuilding, pipelines, and storage tanks—where consistent flux condition and simplified handling matter. BlockPac Performance Data Severe Climate Test + Hydrogen Result BlockPac moisture protection was tested in a climate chamber for 10 weeks at 45°C / 90% relative humidity (severe tropical conditions). In weeks 9 and 10, the dew point was artificially reached once per day and droplets appeared on the outer packaging. Moisture variation remained within test-method accuracy, supporting that no moisture absorption took place. All-weld-metal measurements confirmed low hydrogen levels of H4 after the treatment for the stated wire/flux combination, with hydrogen testing according to EN ISO 3690. Takeaway: The value is both predictable moisture control and workflow simplification (no re-drying step) under harsh exposure. VacPac™ for Low-Hydrogen Electrodes: What Changes Operationally Controlling moisture re-absorption in low-hydrogen electrode coatings is critical to reduce the risk of hydrogen-induced cracking in thick structural steels and porosity in stainless or nickel-based weld metal. In demanding applications, the cost and complexity of storage controls and administrative procedures can exceed the consumable cost—so packaging becomes a practical control point. Download Brochure No re-baking, no holding ovens, no quivers (workflow impact) Electrodes supplied in VacPac can be used directly from the package without the need for re-baking or temporary storage in holding ovens and quivers. This simplifies handling, saves time, reduces energy consumption, and helps ensure electrodes remain in optimal condition until the moment of use. Shift exposure control: pack sizes + “one electrode at a time” One electrode at a time: remove only what you will use immediately. Shift-optimized pack sizes: 3/4, 1/2, and 1/4 pack sizes help limit how many electrodes are exposed at once. If exposure limits are exceeded: follow your site procedure (re-bake before use). Best-fit applications: critical low-hydrogen welding in offshore, petrochemical, pressure vessels, and other defect-intolerant industries. Moisture-Control SOP Checklist Receiving → Storage → Point-of-Use Receiving Inspect packaging integrity (punctures/tears/deformation). Segregate compromised packs immediately. Storage Keep moisture-control packaging intact until needed. Prevent mechanical damage (forklift tines, sharp edges, crushing). Point-of-use Open only what will be consumed in the planned window. Control open-to-air time and train “what good looks like” (block shape for flux packs; one-at-a-time for electrodes). If exposure control is lost, revert to site reconditioning rules (flux re-drying / electrode re-baking). Documentation Align handling rules with WPS/QC requirements where applicable. Standardize training to reduce variability between shifts and sites. Rewind Part 1 Packaging selection framework + “which format fits which job” Part 2 will quantify bulk-wire downtime savings and show setup requirements. Learn More on ESAB University Handling and Storage of Welding Fluxes SAW Flux Types: A Guide to Submerged Arc Welding Fluxes Flux Baking: Key Functions and Procedures for Bonding Storing and Redrying Stick Electrodes the Right Way Baking Procedure for Welding Electrodes: Step-by-Step Guide
