How to Plasma Cut Aluminium and Steel
March 31, 2026
Whether you're cutting mild steel plate in a fabrication shop or aluminium sheet on a construction or marine site, understanding how each material behaves under the plasma arc — and how to configure your setup for clean edges — makes all the difference. This guide covers both materials in detail, along with the full range of conductive metals a manual plasma cutter can handle.
Working on aluminium fabrication across oil and gas, construction or marine sectors? Explore ESAB's aluminium welding solutions to find the right equipment for your application.
Why Use Plasma for Aluminium & Steel
Plasma cutting offers a combination of speed, precision, and process flexibility that few alternatives can match. A single machine handles aluminium, mild steel, stainless steel, and more — making it a practical choice for fabrication shops and field operations that work across multiple materials. For thin to medium sections, plasma consistently outpaces oxy-fuel and most mechanical cutting methods, particularly where piercing and curved profiles are involved.
The narrow kerf and reduced heat-affected zone help maintain dimensional accuracy and limit distortion — which translates directly to less edge preparation before welding and fewer rejected parts caused by overheating. The ability to pierce directly into plate without pre-drilling simplifies workflows across fabrication, maintenance, and site-based cutting operations.
Cutting Aluminium with Plasma
Aluminium's high thermal conductivity causes heat to dissipate rapidly away from the cut zone. If travel speed is too slow, excess heat builds up and molten metal adheres to the cut edge. This is frequently interpreted as a machine or consumable fault when the cause is more often a combination of travel speed, standoff distance, and air quality.
Start with a faster travel speed than you would use for steel of equivalent thickness. Match amperage carefully to the material and maintain a consistent standoff of approximately 3 mm unless using a drag shield designed for contact cutting. Clean, dry air is essential: moisture or oil aerosol in the air supply destabilises the arc and produces a porous, rough cut edge. In humid coastal environments or on sites where compressor maintenance is inconsistent — both common considerations across the Middle East — air filtration and regular dryer servicing deserve particular attention.
On thin sheet, plasma produces clean edges with minimal finishing, especially when used with a straightedge or circle guide. On thicker plate (12 mm and above), a higher-output machine with strong arc density — such as a 70-amp class unit — helps sustain penetration and maintain edge quality throughout the cut. Some dross on the underside of thicker aluminium cuts is expected; the objective is to minimise it through correct speed and standoff, then remove any remainder efficiently during finishing.
Operator checklist for aluminium: increase travel speed, verify dry air supply, maintain a consistent standoff, and replace nozzles at the first signs of ovaling. These adjustments have the greatest impact on cut edge appearance and consistency.
Cutting Steel with Plasma
Mild steel responds predictably to a plasma arc, allowing fast, square cuts with minimal distortion. Plasma performs particularly well on sections up to approximately 25 mm, delivering consistent cut faces and low bottom dross when travel speed is correctly set. On thin sheet, the narrow kerf makes intricate profiles and tight nesting practical, improving material utilisation.
Set amperage to suit the material thickness and select the correct nozzle size for that current range. The spark stream provides a useful real-time indicator: when sparks eject straight down beneath the cut, speed is generally correct. If the stream trails rearward, travel is too slow and dross will increase; if sparks spray forward, speed is too high and the arc may not fully sever the material.
For stainless steel, the same principles apply, though greater discolouration is likely. Maintaining arc stability through solid grounding and clean, dry shielding gas will reduce post-cut finishing time.
Tips for Cleaner Cuts on Both Materials
Consistent cut quality depends on setup discipline as much as machine capability. Building the following checks into your pre-shift routine will produce measurable improvements on both aluminium and steel:
  • Consumables: Inspect electrodes and nozzles before each shift. Replace at the first signs of pitting, erosion, or nozzle ovaling to preserve arc focus and cut quality.
  • Gas pressure: Follow the manufacturer's specified setpoints for your torch and material combination. Pressure that is too low destabilises the arc; too high accelerates consumable wear. Keep filters and dryers serviced and replace elements on schedule.
  • Standoff and angle: Maintain a consistent 3 mm standoff and keep the torch perpendicular to the workpiece unless a bevel cut is specifically required.
  • Grounding: Clean the work clamp contact area thoroughly and keep the return path as short as practical to avoid arc sputter and misfires.
  • Practice passes: Run a test cut on scrap of the same thickness to confirm speed and current settings before cutting production parts.
  • Guides and templates: Use drag shields, straightedges, and circle guides to improve repeatability and reduce unintended bevel on manual cuts.
Safety Considerations
Plasma cutting generates intense light, heat, and fumes. Wear flame-resistant clothing and gloves, and use a helmet with the appropriate lens shade — typically #5 to #9 for handheld plasma cutting; consult your relevant safety guidelines for confirmation. Ensure adequate ventilation or fume extraction is in place for any indoor cutting work. Aluminium dust is combustible, and prolonged exposure to steel fumes presents health risks; both require appropriate controls. Secure all workpieces to prevent movement during cutting, and inspect power leads, work clamp, air hoses, and consumables before starting each shift.
