Aluminium and stainless steel are among the most widely used materials in modern fabrication. Lightweight, corrosion resistant, and versatile, they are essential across industries from oil and gas and marine construction to food-grade processing and architectural metalwork. Yet for all their advantages, both present distinct challenges on the shop floor.
Aluminium's high thermal conductivity makes it straightforward to overheat or burn through, whilst its softness creates feeding problems in standard drive systems. Stainless steel, by contrast, is highly sensitive to heat input — excess heat distorts the material, damages the surface finish, and can compromise corrosion resistance at the weld zone.
Conventional MIG can weld both materials, but often with trade-offs: burn-through, warping, spatter, discolouration, and rework that add labour cost and slow delivery schedules. That is why an increasing number of fabrication shops are moving to pulse welders.
The Rustler MIG PRO Compact 350C Synergic/Pulse (air-cooled) and Rustler MIG PRO Compact 350Cw Synergic/Pulse (water-cooled) use Pulse MIG technology to deliver controlled heat input, cleaner transfer, and repeatable weld quality across aluminium and stainless applications, with cooling configurations to match different duty-cycle demands and working environments.
In both cases, conventional short-arc or spray-transfer MIG frequently struggles to deliver consistently clean results without significant post-weld cleanup or rework.
Pulse MIG alternates between a peak current and a background current at high frequency. The peak current detaches a single droplet of molten wire, whilst the background current maintains the arc with minimal heat input. This one-droplet-per-pulse transfer stabilises the arc, controls penetration depth, and significantly reduces spatter and distortion.
For fabricators who work regularly with aluminium and stainless steel, a pulse welder delivers both practical and economic advantages over conventional MIG processes.
The Rustler MIG PRO Compact 350C (air-cooled) and 350Cw (water-cooled) combine pulse capability with operator-focused design, making them well suited to aluminium and stainless steel work across job shops, fabrication contractors, and production lines.
Example: A fabrication shop producing stainless steel tanks reduced average post-weld cleanup time by approximately 30% after switching to Pulse MIG on stainless programmes. Across a team of ten welders, this represented hundreds of labour hours recovered annually — capacity that was redirected to higher-value fabrication work and additional project throughput.
"Pulse welders are too complex to operate."With synergic control, the majority of parameter setup is handled automatically. Operators concentrate on torch angle, travel speed, and technique; the machine manages the waveform.
"Pulse is only suitable for thin materials."Whilst pulse MIG excels on thin-gauge aluminium and stainless, it also improves productivity on thicker sections by reducing spatter, stabilising transfer, and increasing deposition efficiency.
"The upfront cost is too high."The initial investment is greater than basic MIG, but reduced rework, shorter finishing times, lower consumable usage, and faster operator training mean pulse welders frequently recover their cost quickly in aluminium and stainless applications.
Aluminium and stainless steel are central to modern fabrication, but they bring challenges that conventional MIG processes often struggle to address consistently. Pulse welders offer a practical and proven solution — delivering cleaner welds, lower distortion, and more repeatable results across both materials.
The Rustler MIG PRO Compact 350C and 350Cw Synergic/Pulse build on these advantages by combining pulse-ready synergic programmes with a premium 4WD wire feed system, high-duty-cycle performance, and operator-focused design — available in both air-cooled and water-cooled configurations to suit different working environments and output demands.
For fabricators working with aluminium and stainless steel on a regular basis, this represents more than a machine upgrade. It is a practical route to cutting rework, controlling costs, improving finished quality, and meeting the demands of customers and project specifications with greater confidence.
Working on aluminium fabrication across oil and gas, construction, or marine sectors? Explore ESAB's aluminium welding solutions to find the right equipment for your application.
