Thorough weld preparation is one of the most important factors in achieving consistent aluminium weld quality — both as a standard production practice and as a starting point when troubleshooting problems. Whether you are working on a high-volume fabrication line or a smaller project, a clean, methodical preparation process directly influences weld integrity and reduces the risk of costly rework.
Preparing aluminium correctly before welding is essential to achieving reliable, high-quality results. There are two distinct reasons to establish a robust pre-weld cleaning procedure:
At AlcoTec, an ESAB brand and the world's largest producer of aluminium welding wire, we advocate setting up every weld for success through proper preparation. Clean, well-stored material can produce quality welds — and yes, we are familiar with the arguments ("I don't have time for prep" or "I've never prepped and my welds are fine"). But whether you are fabricating structural aluminium components for an oil and gas facility in the Gulf, a marine vessel, or a construction project across the Middle East, there is real value in knowing that correct procedures have been followed.
The first step is to clean the aluminium surface using a degreaser that contains no chlorinated solvents. ZeroTri® is a widely used option, available in both spray cans and bulk containers. To keep the workshop organised, many fabricators decant bulk degreaser into refillable spray bottles rather than relying on aerosol cans.
Other effective degreasers include:
Apply the degreaser using white industrial paper towels and dispose of them in accordance with your site or shop regulations (typically in closed, non-leaking containers). Avoid using shop rags — these are frequently reused and may carry lanolin or detergent residue, both of which can contaminate the weld area.
Key degreasing guidelines:Always degrease before tacking to avoid trapping contaminants between mating surfaces.If edge bevelling is required, use a high-speed carbide bit without cutting lubricant. If lubricant has been used, degrease again before proceeding to welding.
Aluminium forms an oxide layer almost immediately upon exposure to air. This oxide melts at approximately 2,000°C, whilst aluminium itself melts at around 660°C depending on the alloy. If not removed or adequately disrupted, the oxide layer can interfere with weld pool formation and lead to fusion defects.
Recommended tools for oxide removal:
Avoid tools that generate dust rather than shavings — shavings can be collected and recycled, whereas dust spreads contamination across the work area. Also avoid:
Cleaning area guidelines: Limit mechanical cleaning to an area slightly larger than the weld face unless your procedure specifies otherwise. Cleaning beyond what is necessary wastes time and increases the potential for surface contamination.
When working with clean, well-stored material and time is limited, prioritise degreasing. Whilst oxide removal adds an important layer of assurance, oils and surface contaminants represent the greater immediate threat to aluminium weld quality. That said, completing both steps — degreasing followed by oxide removal — always delivers the highest level of confidence in weld performance and integrity.
Skipping preparation may save a few minutes, but it increases the likelihood of defects including:
In structural or high-load applications — such as process pipework, offshore structures, or load-bearing fabrications common across oil and gas and construction sectors — these defects can have serious consequences. Whether you are MIG or TIG welding aluminium, correct cleaning and preparation is one of the most reliable and cost-effective measures available to ensure safe, sound welds.
Working on aluminium fabrication across oil and gas, construction, or marine sectors? Explore ESAB's aluminium welding solutions to find the right equipment for your application.
