In Submerged Arc Welding (SAW), flux plays a critical role in protecting the weld pool, stabilizing the arc, and influencing the final weld quality. The correct flux selection impacts weld integrity, shape, surface finish, and the mechanical properties of the weld metal. This blog dives into the different types of fluxes used in SAW welding, their applications, and how they influence the welding process.
SAW fluxes serve several key functions during the welding process:
In addition to these primary functions, fluxes also impact the final weld's bead shape and surface finish, making them an essential part of any SAW operation.
SAW fluxes can be grouped into three primary types based on how they are manufactured: fused, agglomerated, and mixed fluxes.
Fused fluxes are made by melting all ingredients in a furnace and then crushing and granulating them. However, due to environmental concerns and limitations in meeting the demands for newer steel types, the use of fused fluxes has declined in recent years.
Agglomerated fluxes are manufactured by rolling components with added silicates, followed by drying and baking the grains. These fluxes are chemically heterogeneous, meaning they have not reacted during manufacturing, which allows metallic deoxidants and alloying elements to be added. This makes agglomerated fluxes highly effective in deoxidizing the molten pool and achieving better toughness, especially at subzero temperatures. They are often preferred for applications requiring higher toughness and a more favorable bead shape.
Mixed fluxes are a combination of fluxes that have been fused or agglomerated and then mixed with additional components. This blending allows for greater flexibility in tailoring the flux’s properties for specific welding applications.
SAW fluxes are also classified based on the alloying elements they add to the weld metal. These fluxes can be neutral, active, or alloying, and each type serves a different purpose.
Neutral fluxes are used for multi-layer welding of plates of unlimited thickness. These fluxes do not significantly alter the composition of the weld metal, especially elements like silicon (Si) and manganese (Mn). They are ideal for applications requiring consistency in weld metal composition.
Active fluxes are designed to add significant amounts of deoxidizers like Si and Mn to the weld metal. This improves resistance to porosity and enhances the weld’s appearance and toughness, particularly in high dilution applications. Active fluxes are used primarily for single-pass or multi-layer welds with a limited number of layers (typically 3-5 layers).
Alloy fluxes are used for cladding applications, where specific alloying elements like carbon (C), chromium (Cr), silicon (Si), and manganese (Mn) are added to the weld metal. These fluxes help create a particular composition in the weld metal, especially when used with unalloyed wires. The arc voltage must be carefully controlled to ensure proper alloying and consistency.
Basicity is a key factor in determining the performance of SAW fluxes. It refers to the ratio of acidic to basic components in the flux and affects how the flux interacts with the weld metal. There are three primary categories of flux based on basicity:
Acidic fluxes offer excellent weld performance and consistent metal transfer but result in higher oxygen content in the weld metal. This makes them unsuitable for applications where high impact toughness at low temperatures is critical.
Neutral fluxes have a balanced chemical composition that results in relatively low oxygen content in the weld metal. These fluxes are ideal when a uniform weld metal composition is needed, and they strike a balance between performance and toughness.
Basic fluxes have a higher basicity, which reduces the oxygen content in the weld metal, improving its impact toughness and resistance to cracking. However, their welding performance may not be as good as acidic fluxes. High basicity fluxes are particularly useful for low-temperature applications where toughness is critical.
Choosing the right flux for Submerged Arc Welding is crucial for achieving optimal weld quality, mechanical properties, and performance. By understanding the different types of fluxes, their applications, and how they interact with the welding process, you can select the best flux for your specific welding needs. Whether you are working with thick plate welding, cladding, or applications that demand high toughness, selecting the appropriate flux type will directly impact your welding success.
At ESAB, we offer a wide range of high-performance fluxes tailored to meet the demands of modern welding applications. If you're unsure which flux is right for your project, our team of experts can guide you in making the best selection for optimal results.
