Welding Bend Tests: Understanding Bending in Welding Inspections
February 26, 2024
The welding bend test is a popular mechanical testing method for determining the ductility and strength of welded connections. A welded specimen is subjected to bending forces to determine its capacity to sustain deformation without fracture or failure. We provide a full explanation of the welding bend test in this post, including the machine used, preparatory methods, test results, and the benefits it provides.
Filler Metal Preparation Steps Before the Test
Before performing the welding bend test, it is critical to complete the following fundamental procedures in filler metal preparation:
  • Sample Extraction: Take representative samples from the welded connection, making sure they are large enough and shaped correctly for bending.
  • Visual Inspection: Check for visible defects, discontinuities, or surface irregularities. Remove any impurities or scale that could interfere with the bending process or evaluation.
  • Sample Preparation: Prepare the specimen by cutting it to the proper dimensions and ensuring that it meets the test requirements and standards.
  • Weld Surface Preparation: Remove any impurities or debris from the weld surface. Smooth down any rough edges that could cause stress concentration while bending.
Welding Bending Test Machine
A bending machine, also known as a weld bend tester, is often used for welding bend testing. To produce bending, this machine delivers regulated forces to the welded specimen. It typically includes adjustable grips or clamps to secure the specimen, a bending mechanism to apply the necessary force, and measurement equipment to quantify the degree of bending.
Process for conducting the bending test:
The bending machine works on the idea of providing mechanical force to the weld specimen to induce controlled bending. It is made up of the following major components:
  1. Adjustable grips or clamps: The machine has adjustable grips or clamps that secure the welded specimen throughout the bending operation. These grips help to maintain perfect alignment and prevent slippage while bending.
  2. Bending Mechanism: A hydraulic or mechanical system drives the bending mechanism, which applies the needed bending force to the specimen. It applies pressure on the grips or clamps of the specimen, causing it to distort and bend.
  3. Measuring Devices: To monitor and record the degree of bending, the bending machine may include measuring devices such as dial gauges, digital displacement sensors, or strain gauges. These devices provide quantitative measures to assess the deformation of the specimen.
    Three-point bending machine from INSTRON
    Figure 1 - Three-point bending machine from INSTRON.
Results and Interpretation
The following results can be obtained after performing the weld bending test and applying controlled bending forces to the specimen:
  • Bending Degree: Measure and record the amount of bending accomplished throughout the test. This is commonly stated as the specimen's angle of deflection or curvature.
  • Visual Inspection: Examine the bent specimen visually for evident defects such as cracks, fractures, or localized deformations. Make a note of the presence, magnitude, and location of any observed flaws.
  • Crack Measurement: If cracks are present, use appropriate measuring equipment to determine their length, width, and depth. Document the characteristics of any cracks found for future examination.
Welding bend Test Advantages
The welding bend test has various advantages:
  • Structural Integrity: The test verifies the structural integrity and ductility of welded components, confirming that they can bear applied forces without failing.
  • Defect Detection: The bending forces used during the test can uncover hidden faults like as cracks, a lack of fusion, or incomplete penetration that are not obvious during visual inspection.
  • Quality Assurance: The test confirms that the welding process satisfies the relevant quality standards and specifications by measuring the performance of the weld under bending loads.
Conclusion
Welding bend testing is an important mechanical testing method for determining the ductility and integrity of welded connections. This test aids in evaluating the weld's capacity to endure bending forces by utilizing a bending machine, following suitable specimen preparation methods, and accurately analyzing the results, ensuring the overall quality and reliability of welded components.
