Laser welding is one of the most advanced and fastest-growing joining processes in modern fabrication — delivering exceptional precision, minimal distortion and weld speeds that conventional arc welding cannot match. But alongside its performance advantages, handheld laser welding introduces a category of hazard that is fundamentally different from conventional arc welding. The beam is invisible, silent and capable of causing permanent eye damage in milliseconds. Understanding both how laser welding works and why it demands a different approach to safety is essential for anyone operating, supervising or specifying these systems.
Laser welding (Light Amplification by Stimulated Emission of Radiation) is a fusion welding process in which metals are joined using a highly focused laser beam. In the laser welding process, a concentrated beam of light is directed onto the cavity between the materials to be joined. The powerful laser beam melts the materials at their seams and fuses them into a joint as the material cools.
The highly concentrated heat source allows laser welding on thin materials to be carried out at high speeds — in some applications, metres per minute — while the small heat-affected zone (HAZ) minimises distortion and thermal stress on the surrounding material.
There are two fundamental modes of laser welding, each suited to different applications and power levels:
In heat conduction welding, the laser beam heats the material surface above its melting point but below its vaporisation point. The process is used to produce welds where high weld strength is not the primary requirement. It is carried out with a relatively low-power laser (below 500W) and produces smooth, aesthetically clean welds with a shallow penetration profile. Typical applications include thin sheet joining, jewellery manufacture and precision electronics.
In keyhole welding, the laser beam heats the material surface to the point of vaporisation, penetrating deep into the material. This creates a narrow channel (the “keyhole”) with a plasma-like condition inside it, with temperatures rising above 10,000K. Keyhole welding is carried out with high-power lasers (above 10&sup5; W/mm²) and produces deep, narrow welds with an excellent depth-to-width ratio. It is the standard mode for structural and industrial laser welding applications.
Laser welding can also be combined with conventional arc welding (MIG, TIG, MAG or plasma) to create hybrid laser arc welding. The combination delivers the advantages of both processes: the deep penetration and high speed of laser welding, with the gap-bridging capability, slower weld cooling and metallurgical flexibility of arc welding. Hybrid laser welding is widely used in shipbuilding, heavy fabrication and automotive manufacturing.
The same properties that make laser welding so effective — the concentrated, high-energy beam — also make it significantly more hazardous than conventional arc welding if not properly controlled. Understanding these differences is the starting point for safe operation.
ESAB handheld laser welding systems operate as Class III-A or Class IV devices. Understanding the distinction is essential:
Class III-A laser products are primarily hazardous when combined with optical instruments that change the beam diameter or power density. Even without optical amplification, direct contact with the eye for more than two minutes can cause serious retinal damage.
Class IV laser products are the highest hazard class. They have high output power and cause immediate, serious eye and skin injuries to anyone in the path of the direct or reflected beam. There is no safe level of unprotected exposure. Class IV lasers can also present fire hazards when the beam contacts flammable materials. ESAB handheld laser welding systems operate as Class IV energy during welding.
Laser welding safety requirements apply to everyone in the laser environment — not just the operator:
Every organisation operating a laser welding system must appoint a qualified Laser Safety Officer (LSO). The LSO is a regulatory requirement under IEC 60825-1 and ANSI Z136.9, and is responsible for hazard evaluation, control measures, procedure approval and operator training. A certified LSO must be available at all times during laser welding operations.
Key standards relevant to ESAB handheld laser welding systems include:
APAInternational Electrotechnical Commission. (2014). IEC 60825-1: Safety of laser products — Part 1: Equipment classification and requirements. https://webstore.iec.ch/en/publication/3587
ChicagoInternational Electrotechnical Commission. IEC 60825-1: Safety of Laser Products — Part 1: Equipment Classification and Requirements. Geneva: IEC, 2014. https://webstore.iec.ch/en/publication/3587
Vancouver International Electrotechnical Commission. IEC 60825-1: Safety of laser products — Part 1: Equipment classification and requirements [Internet]. Geneva: IEC; 2014 [cited 2026 Jun 25]. Available from: https://webstore.iec.ch/en/publication/3587
