Tungsten Inert Gas (TIG or GTA) welding is a precise and versatile welding process, known for its ability to produce high-quality welds on various metals. However, like any welding technique, TIG welding can encounter issues, one of which is porosity. Porosity in welds refers to the presence of small cavities or voids within the weld bead. It weakens the weld and compromises its integrity. In this article, we'll explore some of the causes of porosity in TIG welding and discuss effective strategies to prevent it.
Porosity can manifest as tiny gas pockets or voids in the weld, which appear as small, round holes. These voids significantly reduce the weld's strength and make it more susceptible to cracking and failure. It can result from various factors and conditions during the welding process.
Porosity in TIG welding is primarily caused by the entrapment of gases, such as hydrogen, nitrogen, oxygen, and moisture, within the molten weld pool.
To prevent porosity effectively, it's essential to understand the common factors that contribute to its occurrence:
Preventing porosity in TIG welding requires careful consideration of the factors mentioned above. Here are some tips and techniques to help you achieve porosity-free welds:
Porosity in TIG welding is a common issue, but with proper knowledge and careful attention to key factors, it can be effectively prevented. Cleanliness, appropriate gas shielding, electrode selection, and sound welding techniques are essential for achieving porosity-free welds. By following the tips and techniques outlined in this article, you can produce high-quality TIG welds with the confidence that your welds will be strong, durable, and free from porosity-related defects.
For further insights into TIG welding, make sure to explore the following articles on ESAB University:
What causes porosity in TIG welding?
Porosity in TIG welding occurs when gases such as hydrogen, oxygen, or nitrogen become trapped in the molten weld pool as it solidifies. Common causes include contaminated base metals, inadequate shielding gas coverage, dirty tungsten electrodes, incorrect gas flow rates, and poor welding techniques. Moisture, oil, grease, and other surface contaminants can also contribute to gas formation and weld defects.
How can you prevent porosity in TIG welding?
Preventing TIG welding porosity requires thorough cleaning of the base metal, filler rod, and tungsten electrode before welding. Use high-purity shielding gas, maintain the correct gas flow rate, and ensure consistent torch angles and travel speeds. Proper joint preparation, suitable tungsten electrodes, and adequate shielding gas coverage also help minimise atmospheric contamination and produce high-quality welds.
Can incorrect shielding gas flow cause porosity in TIG welding?
Yes. Both insufficient and excessive shielding gas flow can contribute to porosity. Low gas flow may allow atmospheric oxygen and nitrogen to enter the weld pool, while excessive flow can create turbulence that draws surrounding air into the shielding gas. Following the manufacturer's recommended flow rates and using an appropriately sized gas cup or gas lens helps maintain consistent weld protection.
How does tungsten electrode preparation affect TIG welding porosity?
A contaminated or improperly prepared tungsten electrode can introduce impurities into the weld pool and contribute to porosity. Keeping the electrode clean, selecting the correct tungsten type, and maintaining a properly ground tip help promote stable arc performance and consistent weld quality. Ceriated and lanthanated tungsten electrodes are commonly used for welding steels, while pure tungsten is traditionally used for AC aluminium welding.
What is back purging in TIG welding, and how does it help prevent porosity?
Back purging involves introducing an inert shielding gas, typically argon, to the reverse side of a weld joint to displace atmospheric gases. It is particularly important when welding stainless steel pipes, tubes, and other applications where the underside of the weld requires protection. Proper back purging helps prevent oxidation and contamination, supporting clean weld formation and reducing the risk of defects.
