Correct flux management is one of the most overlooked factors in submerged arc welding (SAW) quality. Flux that has absorbed moisture — even in small quantities — introduces hydrogen into the weld pool, which is a primary cause of hydrogen-induced cracking (HIC) in high-strength steels and restrained joints. The consequences of poor flux handling are not always immediately visible: HIC is a delayed failure that can develop hours or days after welding is complete, making it particularly dangerous in structural, pressure vessel, and offshore applications.
This guide covers the three key functions of flux, how flux baking works, and the specific storage, handling, recycling, and rebaking requirements for Exaton SAW fluxes. For guidance on flux-cored and metal-cored wire selection, see our Flux-Cored and Metal-Cored Wire Guide.
Before addressing handling and storage, it is worth understanding what flux actually does — because the handling requirements flow directly from these functions and what compromises them.
Flux removes oxides, grease, moisture, and other surface contaminants from the metals being joined. Oxides on the base metal surface prevent the molten filler metal from bonding effectively — flux dissolves these chemically, creating a clean, reactive surface for the weld to form against. Even a brief period between pre-cleaning and welding can allow re-oxidation to begin, which is why flux-protected processes such as SAW are particularly valuable on scale-prone materials.
During welding, flux forms a protective barrier — either as a slag layer or, in SAW, as a physical granular blanket — that shields the molten weld pool from atmospheric oxygen and nitrogen. Without this protection, the weld pool would rapidly oxidise, producing porosity, inclusions, and a mechanically compromised joint. In SAW, the granular flux blanket completely covers the arc and weld pool, providing both atmospheric protection and thermal insulation that contributes to the controlled cooling rate of the weld.
Flux acts as a wetting agent, reducing the surface tension between the filler metal and the base metal. This improved wetting allows the molten filler to spread evenly and form a strong metallurgical bond across the joint. Flux also lowers the effective melting temperature of the filler, enabling it to flow into tight joint geometries more easily and fill the joint completely.
In submerged arc welding, moisture absorbed by flux during storage or handling is one of the most serious process variables. When moist flux is heated in the arc, the moisture dissociates and releases hydrogen into the weld pool. This dissolved hydrogen migrates to points of high stress concentration — typically the weld root, the fusion line, or the HAZ — and can cause cracking that develops well after the weld appears sound.
Hydrogen-induced cracking is particularly dangerous because:
Flux baking removes absorbed moisture and volatile substances by subjecting the flux to a controlled heating cycle, restoring it to its optimal condition before use.
Exaton fluxes are manufactured with carefully controlled raw material selection and optimised production conditions, ensuring a guaranteed as-delivered moisture content from the factory. To maintain this condition for as long as possible, the following handling and storage requirements must be observed.
Unopened flux drums must be kept under the following controlled storage conditions:
SAW flux is typically recovered and recirculated during welding. To maintain flux quality through the recycling process:
When handled and stored correctly according to the requirements above, Exaton fluxes can generally be used as delivered without rebaking. However, rebaking is recommended in two situations:
ESAB's submerged arc welding flux range is available in the BlockPac™ format — a high-moisture-resistance packaging system for fluxes such as OK Flux 10.65 and OK Flux 10.66, designed to maintain flux condition during transport and storage and reduce the frequency of baking required in controlled environments.
For stainless steel and nickel alloy SAW applications, OK Flux 10.99 is a neutral agglomerated basic flux designed for austenitic stainless steels and compatible with nickel-based alloy wires for demanding corrosion-resistant applications.
For SAW wire selection guidance, see our Welding Consumables Selection Guide or contact your local ESAB representative.
