Most welders experience difficulty welding dissimilar metals. An example of it is weld fusion on ferritic-to-carbon-steel joints – the welds do not seem to be fusing with the carbon steel. This problem is not uncommon when welding stainless steel (SS) to carbon steel. In many cases, it can be resolved simply by removing any mill scale or surface impurities from the base materials. Bear in mind that the surface of stainless steel has a tough oxide layer that makes it passive to environmental attack. This oxide can sometimes cause welding difficulties.
In the present article, we will focus on the potential problems of welding dissimilar metals, such as ferritic to carbon steel. We will also discuss welding dissimilar metals using 309 stainless steel.
Let us consider a case where the welder is experiencing issues welding ferritic stainless steel and other grades of stainless steel (SS) with carbon steel.
The welding team commonly builds and welds carbon steel parts with a standard ER 70S-6 wire using a 98 per cent argon/2 per cent carbon dioxide shielding gas. Recently they have begun manufacturing parts that combine carbon steel, ferritic stainless steel and other grades of stainless steel (SS) using a 309LSi grade of wire with GMAW (Gas Metal Arc Welding). The welders are struggling with weld fusion on the ferritic-to-carbon-steel joints – the welds do not seem to be fusing with the carbon steel. The welding team is looking for suggestions on it.
In most cases when welding dissimilar metals or, more specifically, carbon to SS, we recommend you use a 309 filler metal because of its higher ferrite content. This higher ferrite content can minimise weld dilution and prevent weld cracking. The 309LSi grade of wire has a low carbon content and a higher silicon content, hence the "LSi" in the designator. The lower carbon content is ideal for applications that have a risk of intergranular corrosion cracking. The higher silicon content serves as a deoxidiser and helps remove weld impurities and increase weld puddle fluidity.
When welding carbon steel to SS, some weld dilution from the sides of the joint will occur. The small amount of base material dilution in the weld metal will provide a better match to each of those respective base materials. You should not have difficulties welding on the ferritic side of the joint as stainless-to-stainless welding should fuse relatively well. If there are problems, check to ensure the welding machine is set up correctly with good work lead connections.
The 309LSi weld issues on the carbon steel may be the result of contamination. Try cleaning the steel with an approved cleaner to remove any grease, oil or paint. Grinding the mill scale ½ inch back from the weld joint may also help.
Last, the 98 per cent argon/2 per cent CO2 may not be aggressive enough to allow for proper weld bead wetting on the carbon steel side of the joint. You want to keep the CO2 low to minimise carbon pick-up in the weld joint and prevent the welds from oxidising too much. However, since there is already cross-contamination from welding on the carbon steel, using a higher-CO2 mix, such as 90/10 or even 85/1, may provide the necessary oxidising action to allow the weld to tie in properly.
