+880 1325069410-11
Welding is an essential process in the automobile industry. It is done to join together different metal parts of a car. Automakers use different welding techniques depending on the type of metal used and the desired result. In car manufacturing, the welding techniques, which are majorly applied are resistance welding, GMAW, MIG, and TIG welding. Welding has extensive applications in the automotive industry and is pivotal in repairing and making after-market car parts, like custom bumpers, exhaust systems, etc. The welding process has its challenges, and weld defects can compromise the safety and structural integrity of the welded components.
Welding services in automotive or any industry often lead to a few imperfections, called “Weld Defects, " which could occur internally or externally in the welded metal. The weld defects can take many forms, from cracks to porosity to lack of penetration to distortion. Each has its unique characteristics and causes, and understanding these could be great in producing high-quality welds.
Before delving into specific weld defects that could occur commonly in the automotive industry, let’s look at the causes that can trigger them.
Now, let’s discuss the most common weld defects seen during MIG/TIG welding in the automotive sector.
These defects are wormhole welds, which occur when air or gas bubbles get trapped in the weld. Gases like carbon dioxide, hydrogen, and steam are frequently produced during welding, and these entrapped gases can be distributed uniformly or localised in a specific location throughout the weld. The bubbles can further weaken the weld joint, making it prone to damage or fatigue. In the automotive industry, porosity impacts the strength of the weld, and it could vary from part to part. For example, porosity can lead to leakage issues in fuel tanks.
Distortion or warping is an accidental change in the shape of the surrounding metal of the weld. The excessive heating around the weld joint is usually the prime reason for distortion around its area. The weld defect mainly occurs in thin metals and can be classified into four kinds: angular, fillet, longitudinal, and neutral axis. In the automotive industry, it is a cause of concern when welding B – Pillars in 3-wheeler applications and seating systems for 4-wheeler applications along with exhaust systems or 2/3-wheeler under frames or chassis welding, the thickness of the base material is very thin, probably in the range of 0.8 mm to 4 mm.
The metal particles that eject from the welding arc are spatters. During Arc or Gas MIG welding, these particles scatter over the base metal. These welding flaws adhere to the length of the weld bead and could also occur in joint designs. In the automotive sector, spatters usually occur while welding on seating systems, brakes, and steering columns. If not cleaned, the spatter can adversely affect the movements of these critical parts of the automobile, endangering the lives of the passengers in the car.
It happens when the weld metal is not entirely pierced to the joint’s root. This is of grave concern because the strength of the weld lies in penetration. Lack of penetration in automotive applications like radiators can cause the radiators to malfunction. Even in seating systems, lack of penetration prevents the seats from being rooted to the base of the car and, in case of an impact, can uproot the seat and endanger the life of the occupants in the vehicle.
Excessive heat during welding can cause the metal to burst through the centre. In such situations, burn throughs happen, and they typically occur in thin metal sheets which are less than ¼ inch thick. Though not very critical, burn through becomes one when it is overlooked in the automotive segment, especially while welding the chassis of 2/3-wheelers, which can reduce the strength of that specific joint, causing it to break due to continuous vibrations while riding on the road or carrying loads.
The operators must have the necessary skills, quality equipment, and proper training to drive quality results. To avoid weld defects, here are a few tips.
Undoubtedly, welding has been an essential component of automotive manufacturing for decades. In earlier times, techniques like gas metal arc welding and others were used to join metal components in cars. As technology advanced, the welding methods also saw changes in automotive production. Adopting robotic welding systems and digital solutions in automotive welding technology offers unparalleled efficiency and precision, letting operators produce superior welds at a rapid pace. Helping drive innovation and shaping the vehicles of tomorrow, welding is revolutionising the way cars are built, making them more environmentally friendly, safer, and efficient than ever before. As we look to the future, it is evident that welding will continue to play a crucial role in shaping the industry.
