+880 1325069410-11
By carefully selecting raw materials and optimizing manufacturing conditions the Exaton fluxes have guaranteed as-delivered moisture content from the factory.
Normally, the fluxes are delivered in steel drums, each containing 25 kg (55 lbs). Each pallet has a net weight of 500–1000 kg (1100–2200 lbs) and is shrink-wrapped in plastic or packed in wooden crates before delivery from the factory.
To maintain the as-delivered moisture content, as long as possible, the handling and storage of the flux must be done according to the following requirements.
Transportation of the flux must be done in covered vehicles.
Unopened flux drums must be kept under properly maintained storage conditions as follows:
When handled and stored as above, the Exaton fluxes can normally be used as they are. If, however, a severe application is considered, as given by the material specification, rebaking of flux is recommended.
Furthermore, if flux, due to unfavorable handling or storage, has picked up moisture, rebaking can return the flux to its original state.
Rebaking shall be performed as follows:
