+880 1325069410-11
Weld defects are more than just surface imperfections and are like the hidden troublemakers that occur during the welding process and can drastically affect the reliability and performance of a joint. From poor technique to incorrect parameter settings to mismatched filler metals to unprepared base materials, a lot can go wrong. These defects not only can affect the quality and shape of the weld, but also can lead to re-work, lower productivity, wasted time, reduced profitability, etc. The good thing is that most of the weld defects are preventable, with the right attention to detail and know-how.
Porosity refers to the tiny gas pockets or cavities that form in the weld metal when trapped gases fail to escape during solidification. They may appear small but can seriously weaken the weld and compromise the quality.
Causes:
Remedies:
Spatter refers to tiny droplets of molten metal that are expelled during welding. These particles often land on the base metal or the gas nozzle, resulting in surface irregularities that can compromise weld quality, diminish visual appeal, and increase cleanup time.
Slag inclusions refer to the non-metallic particles trapped in the weld metal, usually between the weld passes, causing weak spots and poor weld quality.
Undercut is a welding defect characterised by a groove or notch formed along the edge of the weld. It occurs when the weld metal fails to adequately fill the joint, resulting in a depression at the toe of the weld that can weaken the joint and reduce its overall structural integrity.
Lack of fusion is a welding defect that occurs when the weld metal fails to adequately fuse with the base metal or preceding weld passes, resulting in discontinuities and weakened joints. This defect can manifest in various forms, such as lack of root fusion, interpass fusion, or sidewall fusion. When fusion is incomplete, the mechanical strength and structural integrity of the weld are significantly compromised.
Lack of penetration is a welding defect in which the weld metal fails to extend through the full thickness of the joint. This unfilled portion of the joint compromises the weld's internal strength and can influence its load-bearing capacity.
Weld cracks are fracture-type discontinuities that develop in the weld metal or the adjacent base metal. These defects significantly compromise weld integrity and can propagate under load. Based on their origin and orientation, weld cracks are classified as follows:
Hot cracks: These form in the weld metal during the solidification phase at elevated temperatures, often due to solidification shrinkage or metallurgical factors.Cold cracks: These occur after the weld has cooled and solidified, typically as a result of residual stresses, hydrogen embrittlement, or poor joint design. Cold cracks are also referred to as delayed cracking or hydrogen-induced cracking. Longitudinal cracks: These develop parallel to the weld bead and may occur along the centerline or edges of the weld. Transverse cracks: These run perpendicular to the weld bead and are usually associated with high restraint and residual stress.Crater cracks: These are short, star-shaped cracks that form at the end of a weld bead where the arc is extinguished abruptly without sufficient fill.
Causes (Hot cracks):
Causes (Cold cracks):
Weld defects—whether porosity, cracks, undercuts, slag inclusions, or other imperfections—can seriously undermine the quality and safety of a welded structure. Fortunately, the majority of these flaws are preventable. The key lies in mastering the fundamentals: understanding common defect types, knowing their root causes, and applying proven techniques to avoid them. By using the correct welding parameters, maintaining proper procedures, and conducting rigorous inspections, fabricators can minimise errors, reduce costly rework, and consistently deliver strong, high-integrity welds that stand the test of time.
