Cladding and overlay are commonly used terms in welding. In manufacturing, the cladding and overlay processes are implemented to enhance the strength of pipe, tubes, or similar components being fused. Because the terms are similar, however, they are often used interchangeably. This article will discuss the difference between the cladding and overlay processes and explore the specific uses of each.
To better understand the differences, let’s first define the cladding and the overlay processes.
Cladding is a method of depositing surface material to the base metal by welding fusion or other mechanical processes. This can be accomplished with different techniques, such as roll bonding, explosion bonding, or powder metallurgy. Pressure and temperature play important roles in the deposition when using these cladding methods. The process can be used for any type of pipes, tubes, metal sheets, or equipment with an ideal metal surface. The cladding process aims to:
Through the weld overlay process, the base metal surface is covered with one or more additional metals. As a result, the base metal is protected from deterioration when exposed to a corrosive environment. Although different arc welding methods can be used to perform the overlay, it is important to consider the compatibility of the overlaying metal with that of the base metal. Important reasons for weld overlay include:
With such similar processes, it is easy to see why the terms often are used interchangeably. The following table focuses specifically on the difference between cladding and overlay:
Whether you need to perform overlay or cladding for piping, tubing, or other applications, there are different solutions to assist you in the process. AMI offers a wide range of weld heads, such as AMI Model 43 and AMI Model 2, for ID and OD cladding, respectively. Orbital TIG welding machines can assist in producing an overlay that can be enhanced with the use of a remote pendant and monitoring system to control the parameters.
By understanding the difference between cladding and overlay, you can choose the right equipment for your process. With AMI’s TIG welding, cladding, and overlaying equipment, you can expect strong, high-quality welds resistant to corrosion and abrasion.
