Manual Metal Arc (MMA) welding — also known as shielded metal arc welding (SMAW) or stick welding — is one of the most widely practised welding methods in the world. Its enduring value lies in its simplicity, portability, and ability to weld in almost any environment. This guide explains the fundamentals of the MMA process, essential equipment, and electrode classifications, along with how shielding gases and slag are produced.
Manual Metal Arc (MMA) welding — also known as shielded metal arc welding (SMAW) or stick welding — is one of the most widely practised welding methods in the world. Its enduring value lies in its simplicity, portability, and ability to weld in almost any environment. Unlike processes such as MIG or TIG that require bottled shielding gases, MMA welding uses a flux-coated consumable electrode that provides its own protection as it burns.
The decomposition of the flux generates a shielding gas and forms a protective slag covering over the bead, allowing MMA to perform well in outdoor and field conditions where shielding gas could be blown away. This makes MMA the go-to process for construction, shipbuilding, pipelines, repair and maintenance, and countless site welding applications.
MMA welding works by striking an electric arc between the tip of a coated electrode and the workpiece. The arc melts the electrode core and the edges of the base metal, forming a molten pool. The electrode’s flux coating decomposes under the heat, releasing gases that shield the weld pool and forming a layer of slag on top of the solidifying weld bead.
This two-fold protection prevents contamination from oxygen, nitrogen, and hydrogen in the air — all of which can cause porosity or cracking if uncontrolled. The slag slows down cooling, improving toughness, but it must be chipped and brushed away between passes.
The basic MMA setup is simple, consisting of a power source, an electrode holder, and an earth clamp. However, power sources are critical to weld quality:
A major advantage of MMA welding is its wide range of electrodes, making it suitable for virtually every metal and industry sector.
This classification system identifies tensile strength, welding position, flux type, and current compatibility, giving welders clear guidance on selecting electrodes for the job.
MMA does not rely on external shielding gases. Instead, the flux coating provides:
This self-shielding feature makes MMA welding highly suitable for outdoor and draughty conditions where gas-shielded processes would struggle. The trade-off is that slag must always be removed between passes to avoid inclusions and ensure clean weld quality.
MMA welding can produce high-quality welds, but incorrect technique or poor preparation may lead to defects. The table below outlines the most common problems, their causes, and remedies:
MMA welding remains popular because of its versatility. It uses simple, inexpensive equipment that is durable enough for tough conditions. Since no shielding gas is required, MMA can be used in the open air without fear of gas disruption. The wide variety of electrodes means almost any material — from mild steels and stainless steels to nickel alloys and cast irons — can be welded.
MMA is also positionally versatile. Welders can work flat, horizontal, vertical, or overhead, which is vital for on-site construction and repair work. This combination of portability, adaptability, and reliability keeps MMA welding relevant even as more mechanised processes gain ground.
MMA welding is indispensable across many industries:
MMA welding continues to be one of the most important welding processes in the world due to its simplicity, adaptability, and robustness in harsh conditions. Its reliance on flux-coated electrodes instead of shielding gas makes it ideal for outdoor and remote work, while the vast range of electrodes ensures compatibility with almost every material and application.
Although slag removal and fume generation are disadvantages compared to cleaner processes, MMA’s reliability in the field and its ability to produce strong, defect-free welds make it indispensable for industries requiring flexibility and strength.
ESAB supplies a full portfolio of MMA power sources and electrodes, designed to deliver dependable performance and code-quality welds in the most demanding environments.
Explore ESAB Stick Welding (SMAW/MMA) Equipment
What is MMA welding, and how does it work?
Manual Metal Arc (MMA) welding, also known as Shielded Metal Arc Welding (SMAW) or stick welding, is an arc welding process that uses a flux-coated consumable electrode to join metals. An electric arc forms between the electrode and the workpiece, melting both to create a weld pool. The electrode coating produces shielding gases and protective slag, preventing atmospheric contamination without requiring an external gas supply.
What is the difference between MMA welding and MIG welding?
MMA welding uses a flux-coated electrode that provides its own shielding, while MIG welding uses a continuously fed wire electrode and external shielding gas. MMA is generally more portable and suitable for outdoor welding, construction, and maintenance applications. MIG welding offers higher productivity, continuous wire feeding, and less post-weld cleaning, making it better suited to workshop fabrication and automated production.
What types of metals can be welded using MMA welding?
MMA welding can be used on a wide range of metals, including mild steel, stainless steel, low-alloy steel, nickel alloys, and cast iron. The appropriate electrode must be selected according to the base material, required mechanical properties, and welding position. Common electrode classifications include E6012 for mild steel, E308L-16 for stainless steel, and E8018-B2 for certain chromium-molybdenum low-alloy steels.
What are the main advantages and disadvantages of MMA welding?
The main advantages of MMA welding include portability, relatively low equipment costs, versatility, and suitability for outdoor or remote welding applications. It can be performed in flat, horizontal, vertical, and overhead positions using appropriate electrodes. However, MMA welding requires frequent electrode changes, produces slag that must be removed between passes, and generally has lower deposition rates than continuous wire welding processes.
What are the most common MMA welding defects, and how can they be prevented?
Common MMA welding defects include incomplete penetration, undercut, slag inclusions, and lack of fusion. These problems can result from incorrect welding current, improper electrode angle, poor joint preparation, or inadequate slag removal. Maintaining the correct arc length, selecting suitable welding parameters, cleaning the base material, and removing slag between passes help improve weld quality and reduce defects.
