Quality Matters: Resolving Common MIG Welding Defects
September 11, 2025
Part Eight - Fundamentals of MIG Welding
MIG welding is a widely used and versatile welding process that can produce strong and reliable welds. However, like any welding technique, MIG welding is prone to certain defects that can compromise the quality and integrity of the weld. In this troubleshooting guide, we will explore some common MIG welding defects and provide effective solutions to resolve them. By understanding and addressing these issues, you can achieve exceptional welds that meet the highest quality standards.
What causes porosity in MIG welding?
Porosity is one of the most common defects encountered in MIG welding and is caused by either atmospheric air or weld joint contamination such as rust, paint, grease, or dirt. It appears as small gas bubbles trapped within the weld bead, potentially weakening its strength and integrity. To resolve porosity issues, start by ensuring proper gas shielding coverage. Check that the gas flow rate is correct, typically 25 - 40 CFH (cubic feet per hour) and verify that the gas nozzle is positioned close enough to the weld joint. Additionally, thoroughly clean the work surface before welding to eliminate contaminants that can cause porosity. Adjusting the voltage and wire speed settings to achieve optimal weld penetration can also help prevent porosity. Finally, consider using a flux-cored wire instead of solid wire, as it can provide improved cleaning action and reduce the risk of porosity.
What causes burn-through and undercut?
Burn-through and undercutting occur when excessive heat causes the metal to melt through or erode the base material, respectively. To avoid burn-through, use a lower voltage or reduce the wire feed speed to decrease the amperage. Increasing travel speed reduces total heat input which can help prevent burn through. Undercutting, on the other hand, can be mitigated by adjusting the welding parameters, primarily voltage, to achieve proper weld size. Maintain a steady arc length and proper gun angles to prevent excessive melting. Additionally, ensure proper joint preparation and consistency to help prevent burn through issues.
How do you fix lack of fusion?
Lack of fusion occurs when the weld metal fails to fuse completely with the base metal or adjacent weld passes. This defect weakens the joint and reduces its load-bearing capacity. To overcome this issue, start by cleaning the joint surfaces thoroughly to remove any oxide layers or contaminants. Increase the heat input by adjusting the voltage, wire feed speed, and travel speed to ensure proper fusion. Take care to maintain the correct travel speed and maintain a consistent arc length. If lack of fusion persists, consider using a different welding technique, different shielding gas, or additional welder training to resolve the issues.
How do you get rid of welding spatter?
Spatter refers to the small droplets of molten metal that are expelled during the welding process and can stick to nearby surfaces. While spatter is mainly an aesthetic concern, it can also indicate an issue with the welding parameters. To minimize spatter, ensure that the work surface is clean and free from oils, rust, or paint. Adjust the voltage to achieve the optimal arc length, reducing the chance of excessive spatter. Excessive shielding gas flow rate may contribute to spatter generation while using anti-spatter sprays or gels can also help control spatter. Regularly clean or replace the welding nozzle, as a clogged nozzle can contribute to spatter formation.
Achieving exceptional welds requires careful attention to detail and addressing common MIG welding defects. By troubleshooting issues such as porosity, burn-through, undercutting, lack of fusion, and spatter, you can significantly improve the quality of your welds. Remember to maintain proper gas shielding, adjust welding parameters, and thoroughly prepare the joint surfaces. With practice and experience, you can master MIG welding and produce welds that meet the highest quality standards, ensuring the structural integrity and longevity of your projects.
Enjoying our series on MIG Welding? Follow the links below to read more.
  1. Mastering MIG Welding: Process and Techniques for Beginners
  2. MIG Torch Maintenance 101: The Top Do's and Don'ts
  3. Essentials of Choosing the Right MIG Welder
  4. What types of metals can you MIG weld?
  5. Essential MIG Welding Safety Tips: Protect Yourself and Your Work Environment
  6. MIG Welding Guns and Accessories
  7. Fine-tuning Performance: Mastering MIG Welding Machine Settings
  8. Quality Matters: Resolving Common MIG Welding Defects
  9. DIY MIG Welding: Real-World Applications and Project Showcase
