Few materials are as common in modern fabrication as aluminium and stainless steel. They are lightweight, corrosion resistant, and versatile, making them essential in industries from transportation and energy to food-grade processing and medical equipment. Yet for all their advantages, both present unique challenges on the shop floor.
Aluminium’s high thermal conductivity makes it easy to overheat or burn through, while its softness can cause feeding problems. Stainless steel, by contrast, is highly sensitive to heat input, which can distort material, damage surface finish, or compromise corrosion resistance.
Conventional MIG can weld both, but often with compromises: burn-through, warping, spatter, discoloration, and rework that add labor cost and slow delivery. That’s why more shops are turning to pulse welders.
The Rustler MIG PRO Compact 350C Synergic/Pulse (air-cooled) and Rustler MIG PRO Compact 350Cw Synergic/Pulse (water-cooled) use Pulse MIG technology to deliver controlled heat input, cleaner transfer, and repeatable quality across aluminium and stainless applications, with cooling options that match different duty-cycle and comfort needs.
In both cases, conventional short-arc or spray-transfer MIG often struggles to deliver consistently clean results without significant post-weld cleanup or rework.
Pulse MIG alternates between a peak current and a background current at high frequency. The peak current detaches a single droplet of molten wire, while the background current keeps the arc lit with minimal heat input. One-droplet-per-pulse transfer stabilises the arc, controls penetration, and lowers spatter and distortion.
For fabricators who regularly work with aluminium and stainless steel, a pulse welder delivers both practical and economic advantages.
The Rustler MIG PRO Compact 350C (air-cooled) and 350Cw (water-cooled) combine pulse capability with operator-focused design, making them well suited for aluminium and stainless steel applications from job shops to production lines.
Example: A shop fabricating stainless tanks reduced average cleanup time per weld by roughly 30% after switching to Pulse MIG on stainless programs. Across 10 welders, this translated into hundreds of labor hours saved annually — time that could be redirected to higher-value fabrication work and additional projects.
“Pulse welders are too complex.”With synergic control, most parameter setup is automated. Operators focus on torch angle, travel speed, and technique, while the system manages the waveform.
“Pulse is only for thin materials.”While pulse is excellent on thin-gauge aluminium and stainless, it also improves productivity on thicker materials by lowering spatter, stabilising transfer, and improving deposition efficiency.
“They’re too expensive.”The upfront cost is higher than basic MIG, but reduced rework, shorter finishing times, lower consumable use, and faster training mean pulse welders often pay for themselves quickly in aluminium and stainless applications.
Aluminium and stainless steel are central to modern fabrication, but they also bring challenges that conventional MIG often struggles to overcome. Pulse welders offer a practical solution, delivering cleaner welds, lower distortion, and more consistent results.
The Rustler MIG PRO Compact 350C and 350Cw Synergic/Pulse take these benefits further by pairing pulse-ready synergic programs with a premium 4WD wire feed system, high-duty-cycle performance, and operator-friendly design — in both air-cooled and water-cooled configurations.
For fabricators working with aluminium and stainless day in and day out, it’s more than a machine upgrade. It’s a way to cut rework, control costs, improve aesthetics, and deliver better results to customers — while preparing the shop for the future of high-performance fabrication.
Explore more ESAB University content on Pulse MIG:
