Manual Metal Arc (MMA) welding — also known as shielded metal arc welding (SMAW) or stick welding — is one of the most widely practised welding methods in the world. Its enduring value lies in its simplicity, portability, and ability to weld in almost any environment. This guide explains the fundamentals of the MMA process, essential equipment, and electrode classifications, along with how shielding gases and slag are produced.
Manual Metal Arc (MMA) welding — also known as shielded metal arc welding (SMAW) or stick welding — is one of the most widely practised welding methods in the world. Its enduring value lies in its simplicity, portability, and ability to weld in almost any environment. Unlike processes such as MIG or TIG that require bottled shielding gases, MMA welding uses a flux-coated consumable electrode that provides its own protection as it burns.
The decomposition of the flux generates a shielding gas and forms a protective slag covering over the bead, allowing MMA to perform well in outdoor and field conditions where shielding gas could be blown away. This makes MMA the go-to process for construction, shipbuilding, pipelines, repair and maintenance, and countless site welding applications.
MMA welding works by striking an electric arc between the tip of a coated electrode and the workpiece. The arc melts the electrode core and the edges of the base metal, forming a molten pool. The electrode’s flux coating decomposes under the heat, releasing gases that shield the weld pool and forming a layer of slag on top of the solidifying weld bead.
This two-fold protection prevents contamination from oxygen, nitrogen, and hydrogen in the air — all of which can cause porosity or cracking if uncontrolled. The slag slows down cooling, improving toughness, but it must be chipped and brushed away between passes.
The basic MMA setup is simple, consisting of a power source, an electrode holder, and an earth clamp. However, power sources are critical to weld quality:
A major advantage of MMA welding is its wide range of electrodes, making it suitable for virtually every metal and industry sector.
This classification system identifies tensile strength, welding position, flux type, and current compatibility, giving welders clear guidance on selecting electrodes for the job.
MMA does not rely on external shielding gases. Instead, the flux coating provides:
This self-shielding feature makes MMA welding highly suitable for outdoor and draughty conditions where gas-shielded processes would struggle. The trade-off is that slag must always be removed between passes to avoid inclusions and ensure clean weld quality.
MMA welding can produce high-quality welds, but incorrect technique or poor preparation may lead to defects. The table below outlines the most common problems, their causes, and remedies:
MMA welding remains popular because of its versatility. It uses simple, inexpensive equipment that is durable enough for tough conditions. Since no shielding gas is required, MMA can be used in the open air without fear of gas disruption. The wide variety of electrodes means almost any material — from mild steels and stainless steels to nickel alloys and cast irons — can be welded.
MMA is also positionally versatile. Welders can work flat, horizontal, vertical, or overhead, which is vital for on-site construction and repair work. This combination of portability, adaptability, and reliability keeps MMA welding relevant even as more mechanised processes gain ground.
MMA welding is indispensable across many industries:
MMA welding continues to be one of the most important welding processes in the world due to its simplicity, adaptability, and robustness in harsh conditions. Its reliance on flux-coated electrodes instead of shielding gas makes it ideal for outdoor and remote work, while the vast range of electrodes ensures compatibility with almost every material and application.
Although slag removal and fume generation are disadvantages compared to cleaner processes, MMA’s reliability in the field and its ability to produce strong, defect-free welds make it indispensable for industries requiring flexibility and strength.
ESAB supplies a full portfolio of MMA power sources and electrodes, designed to deliver dependable performance and code-quality welds in the most demanding environments.
Explore ESAB Stick Welding (SMAW/MMA) Equipment
MMA welding is suitable for mild steel, stainless steels, low-alloy steels, cast iron, and nickel alloys. The choice of electrode determines the material compatibility. For example, rutile-coated electrodes are ideal for general structural steel, while basic low-hydrogen electrodes are required for critical joints and high-strength steels.
The flux coating produces a slag layer that protects the weld as it cools. However, if slag is not removed between passes, inclusions can form within the weld, weakening its strength. Thorough chipping and brushing are essential to ensure proper fusion in multi-pass joints.
MMA welding requires a constant-current (CC) power source to keep the arc stable. Inverter-based machines are popular because they are lightweight and provide smooth, stable arcs, while transformer and generator sets are often chosen for heavy-duty site welding.
To avoid defects such as lack of fusion, slag inclusions, and undercut, welders should maintain correct current settings, use proper electrode angles, and ensure good joint preparation. Cleaning between passes is vital to remove slag and prevent inclusions.
