Vertical stick welding is essential for welding structures that can’t be moved, like steel beams and ship hulls.
Gravity makes controlling the weld pool tricky, but the right electrode, machine settings and technique can help. In this guide, we’ll cover uphill and downhill welds, and the best patterns and joints for strength or speed.
Vertical stick welding is harder than welding in a flat position because gravity pulls the molten weld pool downward. This makes it difficult to control, increasing the risk of imperfections and slag inclusions.
Welders must manage the heat input, travel speed, and electrode angle to prevent the weld from dripping.
In welding, the number refers to the position, and the letter refers to the type of joint. 3G and 3F are two common vertical positions you may use when stick welding structures like steel beams or pipes.
As stick welding is good for outdoor welds, you may use these welding positions when fixing structures.
Mastering vertical stick welding takes skill and practice, but the right techniques can make it easier.
The best joint for your vertical weld depends on how strong it needs to be and the materials you’re using. Access is also a factor, as on-site industries like construction or shipbuilding need welding in tight spaces.
Want to find out more? Visit ESAB University for our dedicated guide to common types of weld joints.
For horizontal (flat) welds, you use a pulling or pushing technique. For vertical, you weld up or down.
Uphill (AKA: Vertical Up, 3G/3F-U)
Downhill (AKA: Vertical Down 3G/F-D)
Pros: Provides a stronger weld with deeper penetration, ideal for thick structural materials
Pros: Faster process, ideal for thinner materials that need a quick travel speed and less strength
Cons: Slower process and may require more skill to control the weld pool from dripping downwards
Cons: Shallower penetration, weaker welds if not controlled, risk of slag entrapment or undercutting
Uses: Steel structures, heavy equipment
Uses: Pipe welding and thinner materials
To weld uphill, hold at a push angle and move steadily upward. Downhill, drag faster to prevent buildup.
Weaving in vertical stick welding involves moving the electrode side to side to improve fusion and control over the weld pool. The right weave pattern can help to prevent defects and ensure a stronger weld.
The stacking technique is where you create a series of overlapping weld beads resembling a stack of coins. It’s used to improve the appearance, strength, and fusion of a weld, especially in vertical and pipe welding.
Instead of dragging the weld pool, you pause to let it cool and let the metal fuse, then repeat the process.
The stacking technique is often used in structural welding, filling large gaps, or where a uniform appearance is beneficial. It offers better control of the weld pool and strong welds, as each pause allows proper fusion.
Now you know a bit more about vertical stick welding techniques, where is it commonly used?
Vertical stick welding is best suited to outdoor, hard-to-reach jobs where moving the workpiece isn’t possible.
Unlike MIG or TIG welding, stick welding doesn’t need shielding gas. This makes it easier to use on-site, or in windy or dirty environments, such as construction sites or shipyards. It’s ideal for rugged, heavy-duty repairs.
Stick welding isn’t always the best choice for vertical welds, especially if precision or looks are a priority.
MIG welding may be better for thin sheet metal in automotive repairs or ductwork, as it offers more control and reduces warping. MIG welding is also preferred in factories for its speed and potential for automation.
For stainless steel and aluminium (such as in food or aerospace), TIG welding provides a cleaner finish.
ESAB offers a wide range of reliable stick welding equipment, ideal for challenging construction, shipbuilding, and pipeline welds. However, you need the right settings to get the most out of your machine.
For example, for strong and slow uphill welds, you might use low amperage, DC+ and a short arc for deep penetration and control. For fast downhill welds, you might use a higher amperage with a DC- polarity.
Start with a lower amperage and adjust until you have a stable weld pool, and take time to practice.
Stick welding requires using an electrode, which is consumed as part of the welding process.
Choosing the right electrode is important for controlling the weld pool for strong, defect-free vertical joins. Stick welding electrodes are classified by their strength, welding position suitability, and flux coating type.
Electrode
Best for
Features
Technique
E7018
Uphill welds on structural steel or heavy-duty repairs
Provide high-strength, clean welds with minimal defects
Weave slowly and steadily uphill, and work on thicker materials
E7014
Light downhill welds, such as farm repairs
Less penetration, not ideal for critical welds
Fast and downhill on thinner materials
E6010
Vertical uphill and downhill welds, an ideal choice for pipe welding
Deep penetration for strong welds, good control in all positions
Requires a stacking technique to help control the molten weld pool
E6011
General purpose and outdoor repairing
Similar to E6010, but works with AC/DC too
Control the fast-freezing arc with a step pattern
Each electrode has an outer flux coating that vaporises and acts as a gas shield during stick welding. This prevents external contaminants from entering the weld. After welding, the flux coating solidifies, forming a layer of slag over the weld. This protects the weld pool whilst cooling, but needs to be removed afterwards.
For beginners learning stick welding, E6013 electrodes are a popular choice. They are considered general-purpose, work well in various applications, can be used in all positions, and are easy to strike.
ESAB offer a huge range of stick welding electrodes in their filler metals, including for vertical positions.
Now you know more about vertical stick welding, here’s some helpful advice from our welding experts.
Stick Welding Basics How to Stick Weld 7018 with ESAB Ruffian ES 150G Stick Welding Test: ESAB Rebel EMP 285 Setting Up Stick Welding with ESAB Ruffian ES 150G
