Personal protective equipment (PPE) for laser welding is not interchangeable with conventional arc welding PPE. The hazards are different, the wavelengths are different, and the consequences of using the wrong equipment are severe. A standard arc welding helmet provides no meaningful protection against a Class IV laser beam. This guide covers the specific PPE requirements for handheld laser welding — what you need, why it matters, and what the relevant standards require.
For an introduction to laser welding safety and laser classification, see What Is Laser Welding Safety?
Conventional arc welding helmets are designed to protect against arc flash, UV radiation and visible light from the welding arc. They are not tested or rated for protection against near-infrared laser radiation at wavelengths such as 1,070 nm, which is the operating wavelength of most handheld laser welding systems. Using an arc welding helmet for laser welding can result in serious, permanent eye injury.
All PPE used in laser welding environments must be rated specifically for the laser wavelength and output class in use.
All personnel present in the Laser Controlled Area (LCA) during laser welding operations must wear appropriate laser safety eyewear. This includes bystanders and observers, not just the operator.
The primary eye and face protection for the laser welding operator is a dedicated laser welding helmet. This is distinct from both laser safety glasses and standard arc welding helmets.
Laser-specific welding helmets are designed for use with handheld laser welding systems operating as Class IV energy at 900–1,100 nm wavelengths. Key features include:
The helmet also provides respiratory protection when used with appropriate filtration — important given the fume hazards associated with laser welding. See our guide to Laser Welding Safety: Fire, Fume, Dust and Electrical Hazards for more detail on fume management.
Laser radiation and the UV/IR radiation generated by the welding plasma can cause skin burns, increase the risk of skin cancer and accelerate skin ageing with repeated exposure. All personnel in the LCA must wear appropriate protective clothing.
Appropriate gloves must be worn during laser welding operations. Gloves serve two purposes: protection against laser burns from incidental beam contact, and protection against hot or sharp workpieces.
