Cutting expanded metal, grating, mesh or any open grid material with a standard plasma cutter is a frustrating experience. Every time the arc crosses an open gap between strands, it loses contact with the workpiece and extinguishes — then has to restart for the next strand. On a basic plasma cutter, this means repeated arc interruptions, excessive nozzle wear and poor cut quality. On the Cutmaster range, a dedicated grate cutting mode solves this problem completely.
This article explains what grate cutting mode is, why it matters, how to use it and when to switch between normal and grate cutting on the ESAB Cutmaster 30+, 50+ and 70+.
For a full overview of the Cutmaster range and manual plasma cutting, see our Complete Guide to Plasma Cutting.
When you cut solid plate with a plasma cutter, the arc maintains continuous contact with the workpiece throughout the cut. The plasma arc is stable, the consumables wear at a normal rate and cut quality is consistent.
Expanded metal (also called grating, mesh or grid) is different. The material has open voids between the metal strands. As the torch moves across the surface, the arc repeatedly loses contact with the metal each time it crosses a gap, then must re-ignite when it reaches the next strand.
On a standard plasma cutter without grate mode, this creates several problems:
Grate cutting mode (also called expanded metal mode) is a dedicated operating mode available on all three ESAB Cutmaster models — the 30+, 50+ and 70+. When activated, it changes how the machine manages the plasma arc when it loses contact with the workpiece.
In normal plate cutting mode, when the arc extinguishes, the machine requires the operator to release and re-press the trigger to restart. In grate cutting mode, the machine automatically maintains the pilot arc in the gaps between strands and instantly re-transfers the cutting arc the moment it detects conductive material again. This is sometimes referred to as auto-pilot restart.
The result:
Switch to grate cutting mode any time you are cutting material with gaps or voids that the arc will pass over during the cut. Common applications include:
For all solid plate and sheet cutting — including mild steel, stainless steel, aluminium and any continuous solid surface — use normal plate cutting mode. There is no benefit to grate mode on solid material and it uses slightly more energy to maintain the pilot arc between strands.
Switching between normal and grate cutting mode on the Cutmaster 30+, 50+ and 70+ takes seconds and requires no tools or settings adjustments beyond the mode selection itself.
The mode selection is accessible directly from the main display screen. You do not need to power down or adjust any other settings. Amperage, air pressure and torch settings carry over between modes.
The difference grate mode makes to consumable life on expanded metal is significant. Without grate mode, every gap crossing is a full arc extinction and restart — the same stress on the electrode as starting a new cut. On a typical expanded metal cutting task with hundreds of gaps per metre of cut, this translates to electrode and nozzle wear that would occur in a fraction of the normal plate cutting lifespan.
With grate mode active, the pilot arc is maintained between strands. The electrode hafnium insert and nozzle orifice are not subjected to the same restart stress on every gap. The ESAB Cutmaster Black Series consumables are engineered for extended life in all cutting modes — and the combination of Black Series consumables with grate mode active gives you the best possible consumable performance on expanded metal work.
Grate cutting mode with auto-pilot restart is available as standard on all three Cutmaster models:
All three models also feature an automatic post-cut air purge that cools the torch and extends consumable life after the trigger is released — another feature that works in your favour on grate cutting tasks where the torch is frequently stopping and starting at the edges of panels.
Get in touch with an ESAB specialist if you have questions about the right Cutmaster model for your expanded metal or grating cutting application.
