Laser Welding Hazards & How to Stay Safe
April 14, 2026
The laser beam itself is the most immediate hazard in any handheld laser welding operation — but it is not always the most obvious one. The direct beam is hazardous, but so are the reflections it generates from metal surfaces, the ultraviolet and infrared radiation produced by the welding plasma, and the blue light emitted during high-power laser interaction with the weld material. Understanding each of these hazards is essential for anyone operating, supervising or working near a handheld laser welding system.
Direct Beam Hazards
Handheld laser welding systems operate at Class IV energy levels during welding. Direct exposure to the beam causes immediate, serious injury:
  • Eye injury — the primary and most severe risk. The eye’s lens focuses near-infrared laser radiation (around 1,070 nm) directly onto the retina, where it causes thermal burns. Permanent loss of vision can result from exposures measured in milliseconds. There is no safe unprotected exposure level for a Class IV laser beam.
  • Skin burns — direct beam contact with skin causes immediate thermal burns. Skin is less sensitive than the eye, but high-power Class IV systems can cause serious burns in seconds.
Never look directly into a laser aperture or direct the torch at another person. Direct exposure to the beam or its reflections must be avoided at all times. Serious injuries can occur in seconds.
Specular (Mirror-Like) Reflections
Specular reflections occur when the laser beam strikes a smooth, polished or highly reflective surface at an angle and reflects in a defined direction — like light reflecting from a mirror. In a laser welding environment, these are among the most dangerous secondary hazards:
  • Highly reflective metals — polished steel, chrome, copper and aluminium — can produce specular reflections that carry a significant proportion of the original beam energy.
  • A specular reflection can travel considerable distances and still retain sufficient energy to cause serious eye or skin injury.
  • Retroreflection — a particularly hazardous form of specular reflection that occurs when two reflective surfaces are oriented at an angle to each other. The beam reflects off one surface onto the second and returns in the direction of the source — directly back towards the operator.
  • Always assess the work site before welding to identify surfaces that could cause hazardous reflections. Remove, shield or cover reflective surfaces wherever possible.
Diffuse Reflections
When the laser beam strikes a rough or matte surface, it scatters in multiple directions as diffuse reflection. While diffuse reflections are less concentrated than specular reflections, they can still present a hazard:
  • Even scattered laser light can cause eye injury if exposure is sustained or at close range.
  • Do not direct the laser at reflective surfaces, even when the surface appears matte. Surface appearance is not always a reliable guide to reflectivity at near-infrared wavelengths.
  • All personnel in the LCA must wear laser safety eyewear rated for the operating wavelength, including protection against diffuse reflections.
Highly Reflective Metals: Special Considerations
Certain metals present elevated specular reflection risks due to their surface properties:
  • Aluminium — aluminium and its alloys have high thermal conductivity and can reflect laser energy before the plasma ignition point is reached. Once plasma is initiated, reflectivity decreases significantly. The period before plasma ignition presents the highest reflection risk.
  • Copper — similarly, copper has high reflectivity at near-infrared wavelengths before plasma ignition. Take extra precautions when starting welds on copper or copper alloys.
  • Polished stainless steel — polished surfaces can produce strong specular reflections. Matt or brushed finishes reflect less predictably and in more directions.
Ultraviolet and Infrared Radiation from the Welding Plasma
High-power laser beams interacting with metal produce a welding plasma — an ionised gas cloud above the weld pool. This plasma emits several types of radiation beyond the laser wavelength itself:
  • Ultraviolet (UV) radiation — the welding plasma emits UV radiation. Unprotected UV exposure can cause conjunctivitis (arc eye), corneal injury, skin burns and, with repeated exposure, increases the risk of skin cancer and premature skin ageing.
  • Blue light — high-power laser-material interaction can generate intense visible blue light, which can cause retinal injury (photoretinitis) and conjunctivitis.
  • Infrared (IR) radiation — IR radiation from the plasma and heated workpiece causes thermal burns to exposed skin and can cause cataracts with prolonged, repeated exposure.
The ESAB laser welding helmet is designed to filter both UV and IR radiation to the levels required by EN 207:2017 D LB6, providing protection against all of these radiation types during normal welding operation.
How to Reduce Beam Exposure Risk
  • Read and follow all labels and the instruction manual before operating laser welding equipment.
  • Ensure the LCA is properly established with laser-blocking barriers and interlocks before any welding takes place.
  • Assess the work area for reflective surfaces and remove, shield or cover them before welding.
  • Wear appropriate laser PPE at all times when in the LCA — the correct laser helmet, safety glasses, clothing and gloves for the operating wavelength.
  • Never direct the torch at personnel or at surfaces where the reflection path is not controlled.
  • Ensure all safety interlocks are functioning — key switch, emergency stop and external interlock connections.
  • Only qualified personnel should install, operate, maintain and repair the equipment.
In Case of Laser Eye or Skin Exposure
If anyone is exposed to the laser beam or its reflections:
  • Seek medical attention immediately — even if no immediate symptoms are apparent. Retinal injuries from near-infrared laser exposure may not produce immediate pain or vision loss, but damage can be permanent.
  • Report all accidents and incidents to a supervisor and complete an incident report.
  • Do not assume that brief exposure was harmless. Any suspected laser eye exposure requires immediate professional medical assessment.
