Setting Up a Safe Laser Welding Workspace
April 14, 2026
The workspace around a handheld laser welding system presents hazards that extend well beyond the immediate weld point. Laser beams and their reflections can travel across a room, pass through doorways and injure people who are not involved in the welding operation. Establishing a properly controlled laser welding workspace — before the system is powered on for the first time — is one of the most important safety steps any organisation can take. This guide covers the workspace setup requirements for handheld laser welding systems.
The Laser Controlled Area (LCA)
Every laser welding operation, including demonstrations, must have a designated Laser Controlled Area (LCA). The LCA is the physical zone within which the laser operates and within which laser safety controls are enforced. Anyone entering the LCA is subject to the full PPE and safety requirements that apply to the operating wavelength and power class.
An LCA should incorporate:
  • Light-tight enclosure — the LCA should be enclosed with laser-blocking panels that prevent beam and reflection escape. Walls, partitions and curtains within the LCA must be constructed from laser-safe materials capable of withstanding direct and reflected beams at the operating wavelength and power.
  • Interlocked access door — entry points to the LCA must be fitted with interlocks that automatically shut down the laser if the door is opened during operation. This prevents unauthorised personnel from entering an active laser zone without warning.
  • Laser On warning indicator — a clearly visible “Laser On” warning sign or indicator light must be active whenever the laser system is powered and capable of emitting.
Warning Signs and Labels
Laser warning signs must be posted throughout the controlled area, with particular attention to all entrances and exits. Requirements include:
  • Keep all warning labels on the equipment intact and visible at all times. Do not cover, remove or deface laser warning labels.
  • Post laser warning signs at all entry points to the LCA, clearly indicating the presence and class of laser in operation.
  • Signs must conform to the relevant standard for laser warning signage (ISO 11553-1 and applicable national standards).
  • Temporary LCAs for demonstrations or site work must display the same warning signage as permanent installations.
Barriers and Beam Stops
Physical barriers serve two functions: preventing the laser beam or its reflections from leaving the LCA, and stopping unauthorised personnel from entering the hazard zone.
  • Barriers and windows within the welding area must be made of laser-safe materials tested to withstand direct and reflected beams at the operating wavelength.
  • Identify surfaces within and adjacent to the LCA that could cause hazardous reflections — polished metals, glass, mirrors and similar surfaces should be removed or shielded.
  • Non-reflective, laser-absorbent beam stops should be positioned at all points where the beam could reach if misdirected.
Safety Interlocks
Modern laser welding systems incorporate several layers of safety interlocks designed to prevent accidental or unauthorised laser emission. These must be verified before operation and must never be bypassed:
  • Key switch — secures the equipment and prevents unauthorised use. The key must be removed and controlled when the system is unattended.
  • Emergency stop button — immediately halts laser emission. Emergency stop locations must be clearly identified and accessible to all personnel in the LCA.
  • External interlock connection — the system can be connected to external interlock devices, such as door contacts, that automatically shut down the laser if an unauthorised person enters the LCA.
Ensure all machine safety interlocks are functioning correctly before each operating session. Any interlock fault must be rectified before the system is used. Never bypass interlocks or safety mechanisms under any circumstances.
Ventilation
Laser welding generates fumes and gases from the base material, filler wire (if used), coatings, paints and chemical reactions in the weld pool. These must be extracted from the LCA to protect operators and bystanders.
  • Ensure the ventilation and fume extraction system is operational before starting any laser welding operation.
  • The extraction system must be capable of capturing fumes at source — general ambient ventilation alone is not sufficient for laser welding.
  • Routine air monitoring should be performed to determine fume levels in the welding area and verify that extraction is effective.
  • In confined spaces or areas where ventilation is limited, respiratory protection is required in addition to fume extraction.
Work Area Cleanliness
  • Keep the work area free of clutter, particularly combustible materials that could be ignited by the laser beam or reflected energy.
  • Remove or shield any reflective surfaces that are not part of the workpiece.
  • Clean scrap boxes, collection bins and dust collector boxes daily. Metal dust from laser welding can present fire and explosion hazards if allowed to accumulate.
Pre-Operation Checklist
Before starting each laser welding session, complete the following checks:
  • Inspect all system components for visible damage.
  • Verify that the laser is calibrated and properly aligned.
  • Confirm that all PPE (laser helmet, safety glasses, protective clothing, gloves) is available and in good condition.
  • Ensure the ventilation system is running.
  • Confirm all safety interlocks are functioning.
  • Verify that all safety curtains, barriers and beam stops are in position.
  • Confirm that laser warning signs are posted and visible at all LCA entry points.
Shutdown Procedure
  • Power off the system following the manufacturer’s correct shutdown procedure.
  • Ensure the laser power source is completely powered down before leaving the area.
  • Remove and secure the key switch to prevent unauthorised use.
  • Follow lockout/tagout procedures whenever maintenance or inspection is required.
