The Incredible Benefits of Data-Driven Fabrication
March 16, 2022
Knowledge is power — and that is especially true in fabrication. Welding machines generate enormous amounts of valuable data, and with the right tools in place, that data can be put to work to improve productivity, quality, efficiency, and compliance across your entire operation. Thanks to ESAB InduSuite, capturing and acting on that data is faster and easier than ever — changing the way welding companies, large and small, do business.
So what does data-driven fabrication mean for your day-to-day operations? Here is a look at the top benefits.
What's Measured Can Be Better Managed
You can only control what you measure. ESAB InduSuite provides the baseline data and operational insight you need to understand what is happening on your shop floor — and then compare it across projects, teams, and machines to drive continuous improvement.
Proper weld parameters are documented and verified
With WeldCloud Productivity, exact weld parameters are not only documented but recorded in real time as welding takes place. You can assign a welder to a specific station and monitor whether their welds are on specification, or evaluate how deposition rate changes over time. Parameters can be checked, verified, and compared across stations whenever needed.
For the welding operator, all data — current, voltage, travel speed, wire feed speed, heat input — is visible in real time at a high sampling rate. Issues such as porosity can be identified almost immediately and located precisely within the weld, leading to improved quality overall. Data can be as granular as required to meet the needs of specialist manufacturers.
Bottlenecks are identified before they escalate
In most operations, production problems go unnoticed until they become costly. With data-driven fabrication, patterns emerge quickly. WeldCloud Productivity gives you a complete roadmap of your shop floor — showing you how every station, machine, and welder is performing.
Is one machine going down more often than others? Are there recurring issues with amperage or wire feed speed at a particular station? Once these issues are identified and resolved, weld efficiency improves — optimising the time, resources, and expertise of everyone on the production line.
Equipment breakdowns are avoided
With InduSuite in place, you can see which machines need servicing and when — and if a machine stops, you know immediately, whether it has a broken component or simply needs calibration. WeldCloud Fleet takes this further, allowing service and maintenance managers to monitor entire fleets across multiple sites, schedule preventive maintenance, and push remote software updates without manual configuration.
Over time, recurring issues on specific machines become visible in the data, enabling better-informed purchasing decisions and reducing the likelihood of expensive unplanned downtime.
KPIs Are Monitored to Improve Productivity
Once you know the key performance indicators that matter to your operation, WeldCloud Productivity can gather data on exactly those areas. Arc time, wire and gas consumed, parts completed per shift — all of this is tracked accurately, giving you reliable productivity numbers rather than estimates.
You will have a clear picture of how one shift performs versus another, how quickly a particular part is welded compared to a similar one, and where time is being lost. This visibility enables better team management and more accurate project quoting — all while addressing the root causes of your biggest operational pain points.
What Does This Mean for Your Operation?
In a word: visibility. Data-driven fabrication gives you the information to understand what is happening at every workstation, with every welder, across the entire production line.
Arc-on time is often far lower than assumed
Most managers assume their welders are productive for a significant proportion of their shift — often around 20% arc-on time. In practice, once measured, the actual figure is frequently below 10%, and sometimes closer to 5%. Once you have identified a productivity gap, you can find its source: are welders waiting for parts? Is there a hold-up elsewhere in the line? With weekly data from WeldCloud Productivity, you can see exactly how many hours each day your welders are idle or away from their station — and make targeted improvements that raise productivity across the entire operation.
Documentation and traceability in minutes, not days
Depending on the project or client, you may need to provide complete traceability: which welder worked on which part, what filler metal was used, which WPS was followed, and what parameters were recorded. In many operations, gathering this information manually from spreadsheets takes hours — or days — and manual data entry introduces errors that cause problems at audit or inspection.
With WeldCloud Notes, all documentation — WPS, PQR, and welder performance qualifications — is managed digitally with full code compliance checking for ASME IX, AWS D1.1, ISO 15614-1, ISO 9606-1, and other standards. WeldCloud Assembly adds full production-level traceability, linking every weld to its parameters, operator, filler metal, and inspection records.
If a question arises about work completed on a building, a vessel, or a bridge, the full audit trail is a single click away — secure, accurate, and ready to demonstrate that all work was carried out in accordance with the applicable WPS.
Put Your Data to Work
Every operation is different, and the data sets that matter most will vary. But whether your shop is large or small, actionable data from ESAB InduSuite will help you boost productivity, maintain the highest levels of quality and traceability, and avoid the costly problems that come from operating without visibility.
To explore the full InduSuite portfolio — including WeldCloud Productivity, WeldCloud Notes, WeldCloud Assembly, CutCloud, and COLUMBUS — visit the ESAB InduSuite page or contact your local ESAB representative.
