Flux-cored arc welding (FCAW) and metal-cored wire (MCAW) processes are growing in popularity across fabrication and heavy industrial applications — and for good reason. Both offer significant productivity and quality advantages over solid MIG wire and stick electrodes in the right applications. But choosing between flux-cored and metal-cored wire, understanding when each delivers the greatest benefit, and knowing how to handle flux correctly are decisions that require a clear understanding of how these consumables work. This guide covers all three.
Flux-cored wire is produced by slitting coiled sheet steel into strips, which are passed through rollers that form a U-shaped cross-section. The formed strip is filled with a measured quantity of core ingredients — fluxing agents, deoxidisers, arc stabilisers, and alloying elements — then passed through closing rolls that shape it into a tube and compress the granular core. The tube is then drawn through dies that reduce the diameter and lock the core ingredients in place, preventing any movement within the wire.
This construction is what gives flux-cored wire its characteristic performance advantages: the thin metal sheath concentrates current in a small cross-sectional area, the core controls arc chemistry and slag behaviour, and the combination produces a consistently high-performance electrode that solid wire cannot match in many applications.
In a solid MIG wire, welding current travels through the entire cross-section of the wire. In a flux-cored wire, current travels primarily through the thin outer sheath. This means:
Flux-cored wire electrodes achieve high deposition rates because of their high current density. The small cross-sectional current path in the metal sheath causes rapid resistance heating, bringing the electrode to its melting point quickly. ESAB Dual Shield flux-cored wires are capable of deposition rates significantly higher than equivalent solid MIG wires — making them one of the most productive consumables available for flat and positional structural welding.
The columnar arc stream produced by flux-cored wire's concentrated current path delivers deep penetration — deepest when CO₂ shielding gas is used. This has practical consequences for joint design: deeper penetration increases the effective throat of a fillet weld, meaning the joint's strength depends less on the exterior weld size. In many applications, fillet leg dimensions can be reduced — decreasing fillet size by as little as 1.6 mm (1/16") can reduce the total weld metal required by 50–60%.
The small diameter and deep penetration of flux-cored wire allow joint included angles and root openings to be reduced compared to solid wire or stick, significantly reducing the volume of weld metal needed to fill the joint. In out-of-position work, flux-cored electrodes can operate at higher currents than solid MIG in short-circuit mode, improving sidewall fusion and reducing the risk of lack-of-fusion defects — one of the most common and costly causes of weld repair.
Welding with flux-cored electrodes requires less training time than many other processes. The fast-freezing slag holds the weld pool in position in all orientations, giving the operator greater control and reducing the skill required for positional welding. This is particularly relevant in environments where experienced welder availability is limited.
Welds produced with flux-cored electrodes are smooth with minimal ripple. The metal transfer produces very little spatter, significantly reducing post-weld cleaning time — an important consideration in production environments where cleaning time is a real overhead.
ESAB produces one of the broadest ranges of all-position flux-cored electrodes available, including the OK Tubrod 15.14 for mild steel all-position work and the OK Tubrod 15.17 for low-alloy applications with toughness requirements to -40°C. All-position capability eliminates the setup time and expense of fixturing required when using positional-only processes.
Although flux-cored electrodes have a higher unit cost than solid wire or stick electrodes, labour and overhead account for 80–85% of the total cost of a welding operation. The higher deposition rates and efficiencies of flux-cored wire reduce both, meaning that in many applications flux-cored wire delivers a lower cost per kilogram of deposited weld metal. Savings compared to coated stick electrodes can reach 60% of the total cost of depositing one kilogram of weld metal.
Metal-cored wire (MCAW) is a tubular wire filled with metallic powders, alloys, and arc stabilisers — but unlike flux-cored wire, it contains no or very little slag-forming material. The result is a wire that combines some of the best characteristics of solid MIG wire and flux-cored wire: the spray transfer arc of a solid wire with higher deposition rates, better gap-bridging ability, and lower spatter. It is primarily suited to automated and robotic welding applications.
Metal-cored wires offer deposition efficiencies in the 92–98% range when used in spray transfer mode with high-argon shielding gas mixtures. Deposition efficiency — the ratio of deposited weld metal to wire consumed — directly drives consumable cost per kilogram of weld metal deposited. The higher the efficiency, the less wire is wasted as spatter or fume.
Metal-cored wire achieves deposition rates of up to 12–14 kg/hr for a 1.2 mm diameter wire, compared to 3.6–4.5 kg/hr for a solid MIG wire of the same diameter. When combined with high deposition efficiency and very low slag volume, metal-cored wire can be run at significantly higher travel speeds — generally, once deposition rates of 4 kg/hr or greater are achieved with metal-cored versus solid MIG wire, cost savings follow. ESAB's OK Tubrod 14.11 is a metal-cored wire specifically designed for robotic and automated single and multi-pass fillet welding applications.
With a continuous wire process such as metal-cored wire, duty cycles can reach 50% (30 minutes of arc time per hour), compared to approximately 20% for stick electrodes (12 minutes per hour). This is one of the primary reasons that automated and robotic welding with metal-cored wire is so productive — the process can sustain arc generation for far longer periods than any manual process.
The near-absence of slag means less post-weld cleaning from parent material before painting or finishing — significant in continuous production lines where parts move directly from welding to surface treatment.
Metal-cored wire is better able to bridge poor fit-up than solid wire in spray transfer mode. In practice this translates to lower defect rates on parts with variable fit-up, less offline rework, and more consistent throughput.
To realise the full productivity benefits of metal-cored wire, an automated or robotic welding setup is required. The increased weld puddle fluidity means the positioning of the torch relative to the part is more sensitive than with solid wire — this demands precise, repeatable robotic motion. The higher heat and radiant light levels also make automated operation the safer choice. For manual welding applications, flux-cored wire or solid MIG wire is usually the better fit.
To achieve all-position capability, either short-circuit transfer mode or pulse mode is required. Many pulse power sources do not include a specific programme for metal-cored wire — while not essential, a metal-cored wire-optimised pulse programme from the equipment manufacturer improves performance meaningfully.
A significant increase in welding throughput at one station will be negated if subsequent stations in the production line cannot handle the additional output. Before converting to metal-cored wire, the entire production flow must be assessed — not just the welding cell.
Flux is a chemical agent used in welding, brazing, and soldering to perform three essential functions:
Flux removes oxides, grease, moisture, and other contaminants from the metal surfaces being joined. Oxides on the base metal surface prevent the molten filler metal from bonding effectively — flux dissolves these, creating a clean, reactive surface for the filler to adhere to. This is why unwelded base material left exposed after pre-cleaning can re-oxidise before welding begins, making controlled flux application timing important.
During the heating phase of welding, brazing, or soldering, flux forms a protective barrier over the molten metal, shielding it from atmospheric oxygen and nitrogen. Without this protection, the molten weld pool would rapidly re-oxidise — producing porosity, inclusions, and a weakened joint. In submerged arc welding (SAW), the granular flux blanket provides this protection mechanically by completely covering the arc and weld pool.
Flux acts as a wetting agent, reducing the surface tension between the filler metal and the base metal. This improved wetting allows the molten filler to spread evenly and form a strong metallurgical bond across the joint. Flux also lowers the effective melting temperature of the filler, enabling it to flow into tight joint geometries more easily.
In submerged arc welding (SAW) and other flux-dependent processes, moisture in the flux is one of the most damaging variables. Moisture absorbed by flux during storage or handling introduces hydrogen into the weld pool — a primary cause of hydrogen-induced cracking (HIC), also known as cold cracking or delayed cracking. This is particularly serious in high-strength steels, thick sections, and restrained joints where the consequences of HIC are severe.
Flux baking — subjecting flux to a controlled heating cycle before use — removes absorbed moisture and volatile substances, restoring the flux to its optimal condition and ensuring consistent, reliable performance.
ESAB's submerged arc welding flux range — including OK Flux 10.65 and OK Flux 10.66 — is available in the BlockPac™ packaging format: a high-moisture-resistance packaging solution that protects flux integrity during storage and transport, reducing the frequency of baking required in controlled storage environments.
ESAB pioneered the development of gas-shielded flux-cored welding (FCAW) in 1957 and today offers one of the broadest ranges of flux-cored and metal-cored wires available. Key products for common heavy industrial applications:
What is the difference between flux-cored and metal-cored welding wire?
Flux-cored wire contains fluxing agents, deoxidisers, and alloying elements that help control arc performance, penetration, and slag formation. Metal-cored wire contains primarily metallic powders and alloying elements, producing little or no slag. Flux-cored wire is commonly used for structural and all-position welding, while metal-cored wire is particularly suited to high-productivity automated and robotic welding applications.
What are the advantages of flux-cored wire over solid MIG wire?
Flux-cored wire offers higher deposition rates, deeper penetration, and improved performance in out-of-position welding compared with solid MIG wire in many applications. Its flux core helps stabilise the arc and supports weld pool control, while its high current density enables faster electrode melting. These advantages can reduce welding time, improve productivity, and lower overall fabrication costs.
When should I use metal-cored wire instead of flux-cored wire?
Metal-cored wire is particularly effective for automated and robotic welding applications requiring high deposition rates, faster travel speeds, and minimal post-weld cleaning. It also offers good gap-bridging capability and high deposition efficiency. Flux-cored wire is often preferred for manual structural welding, especially when all-position capability, deep penetration, and weld pool control are priorities.
Why does welding flux need to be baked before use?
Welding flux may absorb moisture during storage and handling, introducing hydrogen into the weld metal and increasing the risk of hydrogen-induced cracking. Baking removes absorbed moisture and helps maintain consistent welding performance. For submerged arc welding (SAW), flux baking temperatures are often between 250°C and 350°C, but the manufacturer's specified temperature and duration must always be followed.
How should welding flux be stored after baking?
After baking, welding flux should be kept in sealed, dry containers or an appropriate flux holding oven to prevent moisture absorption. Exposure to humid conditions can compromise flux quality and increase the risk of weld defects. If the flux is exposed for an extended period, rebaking may be necessary according to the manufacturer's handling and storage recommendations.
