In aluminium MIG and pulse welding, most problems show up at the arc: unstable puddle, inconsistent bead, porosity, or wire feeding issues.
Even when your power source and feeder are set correctly, small details at the torch – liner, contact tip, cable routing, gas coverage, and operator technique – often decide whether you get a clean pass or a rework.
This guide walks through common aluminium issues that typically appear at the arc and how to troubleshoot them – with a few practical examples of how torches like ESAB PP350w (push-pull) and ESAB Exeor MIG (manual torch) help address them in real applications.
1. Inconsistent Wire Feeding at the Arc
What you'll see: The weld starts smoothly then the wire surges, slows, or stutters. The arc sounds choppy and arc length changes mid-weld.
Check Action
Liner type and condition Use PTFE or nylon liner, cut to correct length. Replace if kinked, dirty, or worn
Contact tip fit Match tip size to wire diameter. Replace tips that are oval, enlarged, or show burnback marks
Cable routing Avoid tight loops and sharp bends — these are the fastest way to create feeding problems on aluminium
Drive roll tension Too much deforms soft aluminium wire; too little causes slipping. Verify by pulling wire at the torch with power off
In practice: On long horizontal seams where the feeder sits some distance away, the ESAB PP 350w push-pull torch keeps wire speed constant at the tip even over extended cable lengths. Once cable routing and liner are correct, the stop-start feeling and choppy arc sound typically disappear.
Read Next: Aluminium MIG Liners: PTFE vs Nylon vs PE
2. Burnback and Damaged Contact Tips
What you'll see: Wire burns back into the tip; tips blacken or fuse; starts become unreliable and craters or defects appear at weld end.
Check Action
Stick-out and technique Maintain consistent stick-out — too short dramatically increases burnback risk. Always use a push technique, never drag
Tip selection and change-out Use tips designed for aluminium and correct wire size. Plan regular change-outs rather than waiting for failure
Burnback and run-in settings Set burnback control so wire stops just before arc extinguishes. Ensure run-in is not too aggressive at arc start
In practice: Once feeding is stable — after switching to a well-tuned push-pull setup with correct liner and tension — burnback incidents typically drop sharply because the wire no longer hesitates or slows under load at arc start and stop.
Read Next: Improving Feedability and Wire Delivery.
3. Spatter and an Unstable (“Nervous”) Arc
What you'll see: The arc looks restless, the bead is inconsistent, and spatter builds up on and around the nozzle — quickly contaminating the torch and disturbing the gas shield.
Check Action
Nozzle and gas diffuser Clean or replace heavily contaminated or partially blocked nozzles and diffusers. Confirm gas flow is within recommended range
Torch angle and travel speed Aim for a 10–15° push angle. Maintain steady travel speed — abrupt changes disturb arc and bead profile
Stick-out consistency Large variations change current density and arc behaviour. Training welders to hold a consistent distance often makes an immediate difference
In practice: On detailed work — brackets, gussets, baffles — the ESAB Exeor MIG (manual torch) smaller front end and comfortable grip make it easier to maintain angle and stick-out in tight spaces, which directly calms the arc and reduces spatter.
4. Torch Overheating and Operator Fatigue
What you'll see: The torch body and neck heat up quickly, operators tire on long shifts, and consumables wear faster than expected.
Check Action
Torch rating vs actual use Confirm amperage and duty cycle match your actual welding currents and arc-on times
Cooling and gas paths For gas-cooled torches, ensure passages are unobstructed. For water-cooled, check coolant flow, hoses, and connections
Ergonomics and support Use cable supports, boom arms, or suspension where possible. Poor ergonomics shows up as inconsistent beads long before you reach the power source limit
In practice: On long aluminium seams along tank shells, a lighter, well-balanced push-pull torch such as the ESAB PP350w (push-pull) helps welders maintain posture and control without gripping hard or fighting the cable — translating directly into more consistent welds at the end of the shift.
5. Difficult Access and Awkward Weld Positions
What you'll see: Unsuitable torch geometry forces welders into uncomfortable postures, making it hard to maintain bead quality on tanks, trailers, and complex frames.
Check Action
Neck angle and torch length Match neck angles and lengths to your common joints. Use longer cable sets for straight runs; compact heads for tight access
Cable management Route cables to avoid snagging and drag. Keep off the floor where practical to reduce pulling force
Operator technique Include torch-handling in training — how to brace, step along long seams, and reposition safely
In practice: In areas with limited room — inside compartments, around stiffeners or fittings — the ESAB Exeor MIG makes it easier to position the nozzle correctly without twisting the wrist into an awkward angle.
6. Gas Coverage Problems at the Arc
What you'll see: Intermittent porosity, sooting, or dull surface finish at random points along the weld, often correlating with certain positions, reaches, or changes in torch angle.
Check Action
Nozzle and diffuser condition Ensure clean, undamaged, and correctly assembled. Replace worn components that disturb gas flow
Nozzle distance and access Maintain consistent nozzle-to-work distance. Avoid burying the nozzle in corners where gas cannot flow properly
Gas leaks near the torch Inspect hoses and connections in the last few metres for leaks, kinks, or damage
In practice: Standardising on a few nozzle and diffuser combinations that work well for aluminium — and training operators to keep them clean — removes a large share of "mystery" porosity issues in most shops.
Read Next: Argon vs Helium Shielding Gases for Aluminium Welding
Quick Arc/Torch Troubleshooting Checklist (Aluminium MIG)
When you see issues at the arc, walk through this six-point check:
  1. Contact tip – correct size, clean, no burnback damage.
  2. Liner – aluminium-compatible, correct length, no kinks or contamination.
  3. Cable – routed without tight bends, loops, or twists.
  4. Torch angle & stick-out – push technique, steady distance.
  5. Nozzle & diffuser – clean, unobstructed, consistent gas flow.
  6. Torch rating – duty cycle and amperage match the job.
Once these basics are under control, most torches – whether push-pull or standard MIG – become far more predictable and easier to troubleshoot.
How ESAB’s Manual Aluminium System Supports Stable Welding
Arc-level troubleshooting is significantly easier when the torch is part of a well-matched system rather than a collection of individually sourced components.
ESAB's manual aluminium packages combine the Warrior Edge power source — with aluminium-ready MIG and pulse control — with the RobustFeed Edge feeder optimised for stable aluminium wire delivery, application-specific torches such as the PP350w push-pull for long seams and the Exeor MIG for tighter access, and matched OK Autrod wires, liners, drive rolls, and gas recommendations. Treating aluminium as a complete power-to-wire solution reduces the feeding-related issues that show up at the arc, improves weld appearance and consistency across shifts and stations, and makes training and standardisation more straightforward for your welding team.
Arc problems will never disappear entirely — but with a system approach, the right torches, and a structured troubleshooting process, they become much easier to diagnose, correct, and prevent from recurring.
Explore ESAB's Aluminium Solutions
