Choosing the right manual plasma cutter is one of the most straightforward purchasing decisions in the workshop — once you know what to look for. The market is full of options at varying price points, and the differences between them matter more than most buyers realise. This guide walks you through the key factors to evaluate before you buy, so you end up with a machine that does exactly what you need it to do — on day one and for years to come.
For a broader overview of plasma cutting technology, see our Complete Guide to Plasma Cutting.
The single most important factor in choosing a manual plasma cutter is matching the machine to the material you actually cut — not the thickest material you might occasionally need to cut. Every plasma cutter has three capacity figures you need to understand:
As a rule of thumb, choose a machine whose recommended cut capacity comfortably exceeds your typical material thickness. If you regularly cut 10mm mild steel, a machine rated at 12mm cut capacity is working at its limit. A machine rated at 20mm or 25mm gives you headroom, better cut quality and longer consumable life.
Output amperage drives cut capacity. Higher amperage cuts thicker material, but also draws more from the power supply and typically costs more. For most professional fabrication and site applications, the choice comes down to three bands:
Many buyers overlook this until the machine arrives on site. Before you purchase, confirm:
Duty cycle tells you how long a machine can cut continuously within a ten-minute period before it needs to cool down. A 60% duty cycle at rated amperage means six minutes of cutting followed by four minutes of rest.
A plasma cutter is only as good as the air supply feeding it. Poor air quality is the leading cause of bad cut quality and premature consumable wear — and it’s entirely avoidable.
Consumables — the electrode and cutting tip inside the torch — are the main ongoing cost of plasma cutting. They wear with use and need regular replacement. The differences between consumable systems can be significant over time:
The torch is the part of the system you interact with on every cut. It matters more than most specifications sheets suggest.
Older plasma cutters used a simple rotary dial. Modern machines offer significantly more control and feedback, which matters in a professional environment.
Not sure which model fits your application? Get in touch with an ESAB specialist — we’ll help you get the right specification first time.
If the machine stays in the workshop, portability is less critical. If it goes to site, it matters enormously.
Most fabricators buying a manual plasma cutter don’t need a CNC interface — but it’s worth knowing whether the option exists. The Cutmaster 50+ and 70+ both include a pre-installed 14-pin CNC interface with voltage divider, which enables:
Combined with the optional ESAB MechPak straight-line and circle cutting attachment, this gives you semi-automated cutting capability from a manual machine — a practical step up from freehand cutting for shops that cut a lot of straight lines or repeat circles without the investment of a full CNC table.
