Are you struggling to maintain consistency, productivity, and control across shifts, operators, and locations?
Manual welding often relies on operator experience, paper-based instructions, or inconsistent interpretation of weld requirements, leading to variability in weld quality and execution.
OCTOPUZ Steps addresses this gap by delivering step-by-step instructions directly to the shop floor through ESAB Warrior Edge welding machines. The weld sequencing software and power source combine to define weld steps, automatically set welding parameters, and validate welds in real time.
In this blog, we will explore how OCTOPUZ Steps and Warrior Edge work together to standardize weld execution and bring process control to manual welding through a connected workflow.
OCTOPUZ Steps and Warrior Edge power sources function as a connected welding workflow on the shop floor.
Instead of treating weld planning, machine setup, and execution as separate steps, this combination connects each step of the process into a single, guided workflow that:
This integration reduces reliance on operator interpretation and ensures every weld is completed according to plan.
Step-by-step weld instructions and a controlled workflow standardize the entire welding process—from engineers defining weld sequences to operators executing them and managers monitoring productivity.
This level of process standardization helps eliminate common challenges in manual welding, including missed welds, inconsistent execution, and limited visibility into performance.
OCTOPUZ Steps requires operators to complete 100% of the defined weld steps according to the plans provided by engineering. Operators cannot skip required welds or move forward without completing each step. This helps avoid missed welds and reduces costly rework.
Through the Warrior Edge integration, each weld is evaluated in real time and operators receive immediate pass/fail feedback. Issues can then be corrected in the moment, leading to improved first-pass quality and reducing wasted time and material.
By integrating with WeldCloud Productivity and the InduSuite ecosystem, teams gain visibility into weld performance, including completed sequences, arc-on time, and operator activity. These insights help identify bottlenecks and areas of improvement.
So what exactly does this look like on the shop floor?
With OCTOPUZ Steps and Warrior Edge, the welding process becomes structured and enforceable from start to finish.
Here’s how:
Using CAD-based tools, engineers create detailed, step-by-step weld instructions that define the weld sequence, welding parameters, and requirements.
Weld operators receive the step-by-step instructions at their machine, ensuring clear guidance at every stage.
ESAB Warrior Edge power sources automatically apply a defined job for each weld step, removing the need for manual setup.
Weld operators execute each step in the instructions, following clear, enforced instructions to ensure consistency and accuracy.
As each weld is completed, results are compared against predefined rules to confirm whether the weld meets requirements before moving forward.
By tightly linking software and equipment, this workflow ensures that execution matches the original weld plan every time, regardless of operator.
Standardizing manual welding is not just about better instructions. It is about connecting plans, equipment, and execution into a single workflow.
ESAB standardizes welding workflows through:
Together, these welding solutions create a connected workflow that improves consistency and increases productivity in manual welding.
Ready to get started with a smarter approach to your manual welding process? Book a demo today.
