A complete reference to MIG (GMAW/MAG) welding: fundamentals, equipment configuration, filler wires, shielding gases, metal transfer modes, defects and remedies, advantages, and industrial applications.
Metal Inert Gas (MIG) welding — more formally known as Gas Metal Arc Welding (GMAW) — is one of the most widely used arc welding processes. When chemically active gases are employed, the process is correctly termed Metal Active Gas (MAG) welding. Together, these variants dominate fabrication across multiple industries due to their productivity, flexibility, and ability to deliver clean, high-quality welds that conform to stringent codes and standards.
The process is widely applied in automotive manufacturing, structural steel fabrication, pipeline and pressure vessel construction, shipbuilding, and general workshop use. MIG welding is equally suitable for manual applications, mechanised systems, and robotic automation, making it indispensable in both high-volume and specialist production environments.
MIG welding relies on an electric arc established between the end of a consumable filler wire electrode and the workpiece. The heat generated by the arc melts both the wire and the surface of the base material, creating a molten pool. As the wire is continuously fed — by the wire feeder — it provides both filler material and the current path for sustaining the arc.
The arc and pool are protected from atmospheric contamination by a shielding gas, supplied externally. This prevents absorption of nitrogen, oxygen, or hydrogen, which would otherwise cause porosity or cracking. The use of a bare wire electrode eliminates slag formation, meaning no post-weld de-slagging is required — a key advantage over manual processes such as stick welding. For a full overview of how MIG welding works — including transfer modes and equipment components — see our article on what is MIG welding.
MIG wires are available for virtually all ferrous and non-ferrous metals. Selection should be based on the base metal composition and required mechanical properties.
Shielding gas composition strongly affects heat input, arc stability, bead shape, and penetration profile.
Key benefits of MIG shielding gases include:
MIG welding offers several metal transfer modes, each with distinct characteristics and applications.
Despite its advantages, MIG welding is sensitive to incorrect parameter settings and poor technique. The following table summarises common defects:
MIG welding provides several key benefits compared with other arc processes:
MIG welding is used across industries requiring both productivity and quality:
MIG welding has earned its place as a cornerstone of modern fabrication because it combines productivity, consistency, and metallurgical reliability. With a constant voltage power source and continuous wire feed, welders can produce strong, clean joints efficiently, while avoiding the downtime linked to electrode changes or slag removal. Its low hydrogen input ensures high-strength, defect-resistant welds that meet demanding standards.
The availability of different metal transfer modes — from low-heat dip transfer to pulsed spray for stainless steel and aluminium — makes MIG highly adaptable across industries. Whether applied manually in workshops or integrated into automated systems, MIG delivers repeatable results that support both everyday fabrication and advanced manufacturing.
What is the typical stick-out (CTWD) in MIG welding?
The contact-tip-to-work distance (CTWD), often called stick-out, is critical because it affects current density, arc stability, and spatter. For carbon steel solid wire, 10–15 mm is typical. Aluminium usually requires 12–20 mm due to higher thermal conductivity. Keeping CTWD consistent helps maintain stable penetration and reduce spatter. Too long increases resistance heating and instability, while too short causes excessive spatter and burn-back.
Which shielding gas is best for structural steel?
Pure CO2 is cost-effective and provides deep penetration, but it produces more spatter and a rougher bead. Argon/CO2 blends (e.g., 80/20) improve arc stability, reduce spatter, and create smoother weld beads. For projects where finish and reduced clean-up are important, blends are recommended. For heavy structural sections prioritising penetration, CO2 may still be used.
When should pulsed MIG transfer be used?
Pulsed MIG is ideal when spray transfer quality is desired but with lower average heat input. It is commonly used on thin stainless steel, aluminium, and heat-sensitive alloys to avoid distortion. The process alternates between a low background current and high-current pulses, detaching controlled droplets at 50–100 Hz. This makes pulsed MIG well suited for all-position welding and robotic systems where consistency is critical.
Do MIG welds require slag removal?
No. MIG welding uses a bare wire electrode with shielding gas, so no flux and no slag are produced. This reduces cleaning time and eliminates the risk of slag inclusions in multi-pass welds. Welders may still need to remove spatter and clean surfaces before and after welding to ensure quality results.
Can MIG welding be automated?
Yes. MIG welding is highly suited to mechanised and robotic automation because of its continuous wire feed and stable arc. It is widely used in automotive, shipbuilding, and industrial fabrication. Modern synergic and pulsed power sources simplify control and deliver consistent quality. Automation reduces operator fatigue, increases repeatability, and ensures compliance with international welding standards.
