One of the biggest advantages of plasma cutting over other cutting methods is its versatility across different metals. Where oxy-fuel cutting is limited to mild steel, and grinding is slow on anything thick, a manual plasma cutter handles virtually any electrically conductive metal — from thin sheet aluminium to heavy stainless steel plate — with the same machine and the same compressed air supply.
This guide covers the metals you can cut with a manual plasma cutter, how each material behaves under the plasma arc, and what to adjust to get the best results. For a full introduction to the process, see our Complete Guide to Plasma Cutting.
Plasma cutting works by forming an electrical arc between the torch electrode and the workpiece. This means the only hard requirement is that the material conducts electricity. If it’s conductive, a plasma cutter can cut it.
Plasma cutting cannot be used on non-conductive materials such as wood, plastic, stone, glass or ceramic. For those materials, waterjet or laser cutting are the appropriate processes.
Mild steel is the easiest and most forgiving material to plasma cut. The plasma arc reacts well with the iron content in mild steel, producing fast, clean cuts with consistent edge quality across a wide range of thicknesses. It is the reference material for all plasma cutter capacity ratings — pierce capacity, cut capacity and maximum severance figures quoted by manufacturers are always based on mild steel.
Plasma cutting handles painted, primed and lightly coated mild steel well — far better than oxy-fuel, which requires a clean bare metal surface. The plasma arc burns through most surface coatings without significantly affecting cut quality. Heavily galvanised steel (zinc-coated) can be cut but produces zinc oxide fumes — always ensure adequate ventilation or fume extraction and wear appropriate respiratory protection.
Plasma cutting works on rusty or scaled steel that would cause problems for other processes. Light to moderate surface rust has minimal effect on cut quality. Heavy scale or thick rust may affect arc stability slightly — if cut quality degrades, clean the surface in the cut area or increase amperage slightly.
Stainless steel cuts cleanly with a manual plasma cutter and compressed air across all the thickness ranges the Cutmaster range covers. The cutting speed on stainless is slightly slower than on equivalent thickness mild steel, due to stainless steel’s lower thermal conductivity and higher melting point.
Aluminium is fully plasma-cuttable with compressed air and is a common everyday material for fabrication shops, automotive work and construction. However, aluminium’s physical properties mean it behaves differently under the plasma arc than steel, and a few adjustments are needed to get clean results.
Copper and brass can be plasma cut with a manual cutter, but their high thermal conductivity — even higher than aluminium — makes them more challenging. The plasma arc has to work harder to maintain enough heat in the cut zone to melt and expel material cleanly.
Titanium is electrically conductive and can be plasma cut. It is relatively straightforward to cut with compressed air, though the cut edge will oxidise (turn blue/gold) due to titanium’s reactivity at high temperatures. For aerospace or medical applications where the cut edge integrity matters, post-cut machining is typically required regardless of the cutting method used.
Cast iron can be plasma cut, though it is more brittle than steel and the cut edge is rougher. The high carbon content of cast iron affects the plasma arc slightly, and the material is prone to cracking if thermal shock is severe.
Plasma cutting requires electrical conductivity. It cannot be used on:
All three models in the ESAB Cutmaster range cut mild steel, stainless steel and aluminium with compressed air as standard. The right model depends on the thickness you need to cut:
Not sure which model is right for your material and thickness? See our guide to Tips for Buying a Manual Plasma Cutting Machine or speak to an ESAB specialist.
