MIG welding thin aluminium is entirely achievable, but it demands a different approach from welding steel or thicker aluminium sections. The combination of high thermal conductivity, a refractory surface oxide, soft wire that is prone to feeding problems, and low burn-through tolerance on thin sheet means that equipment selection, surface preparation, and parameter control all matter more than they do on forgiving base materials. This guide covers the specific challenges of thin aluminium MIG welding and the equipment, consumable, and technique choices that address them.
For a broader overview of aluminium MIG welding including filler alloy selection and feedability, see our articles on the aluminium filler alloy selection guide and feedability in aluminium MIG welding.
Aluminium dissipates heat approximately eight times faster than steel. On thin sections, this creates a difficult balance: enough heat input is needed for good fusion, but excess heat accumulates rapidly and causes burn-through or distortion before the operator can react. Heat management — through travel speed, pulse MIG settings, and interpass cooling — is the central technical challenge in thin aluminium MIG welding.
Aluminium forms a natural oxide layer (Al₂O₃) on its surface that melts at approximately 2,050°C — far above aluminium's melting point of 660°C. If not removed before welding, the oxide prevents proper fusion and causes inclusions in the weld. The oxide layer reforms within minutes of cleaning in ambient air, so joints must be cleaned and welded promptly. For detailed guidance, see our article on aluminium MIG troubleshooting at the arc.
Thin aluminium sheet — particularly below 3 mm — has very little thermal mass to absorb the heat of the arc. Burn-through can occur in a fraction of a second if travel speed drops or heat input is too high. Distortion from thermal expansion is also a significant issue on thin sheet, where even correctly made welds can cause warping if heat management is poor.
Aluminium MIG wire is significantly softer than steel wire and is prone to birdnesting (wire tangling at the drive rolls), buckling in the liner, and erratic feeding — all of which cause arc instability and inconsistent welds. Standard push feeders with steel liners will cause wire shaving and feeding problems on aluminium. Dedicated equipment is required. For full guidance, see our article on feedability and wire delivery in aluminium MIG welding.
A MIG power source with pulse capability is strongly recommended for thin aluminium. Pulse MIG alternates between peak and background current — transferring one droplet per pulse while the background current maintains the arc without adding continuous heat. This controlled heat input is the most effective way to prevent burn-through on thin aluminium while maintaining good fusion. ESAB's Warrior Edge 500 DX with its THIN and CRAFT WeldModes is purpose-designed for exactly this application, delivering TIG-like bead appearance at MIG productivity on thin aluminium and stainless steel.
For thin aluminium, the wire feeding system is as important as the power source. The options are:
Whichever system is used, the liner must be non-metallic (Teflon or nylon) and drive rolls must be smooth U-groove type with chamfered edges — not the V-knurled rolls used for steel wire.
Pure argon (100%) is the standard shielding gas for aluminium MIG welding. It provides excellent arc stability, good oxide-cleaning action on the aluminium surface, and adequate heat input for thin sections. Do not use CO₂ or CO₂-containing gas mixtures on aluminium — CO₂ reacts with the aluminium and produces severe porosity and contamination.
Argon/helium mixtures (typically 50–75% He balance Ar) increase heat input and penetration and can be beneficial on thicker aluminium sections, but for thin material — where heat management is the primary challenge — pure argon is the correct choice. For guidance on gas selection for aluminium, see our article on argon vs helium for aluminium welding.
Set gas flow to 10–12 LPM. Do not exceed 15 LPM — turbulent gas flow draws in atmospheric air and introduces porosity.
For thin aluminium MIG welding, use the smallest diameter wire appropriate for the application — 0.8 mm or 1.0 mm is recommended for thin sheet, as smaller diameter wire gives better arc control and lower heat input than 1.2 mm or larger.
The two most common aluminium MIG filler wires are:
Always match filler wire to base alloy. See our aluminium filler alloy selection guide for full guidance including the 5083 and dissimilar alloy rules.
Surface preparation is non-negotiable for aluminium MIG welding. The oxide layer must be removed immediately before welding:
Do not use a wire brush that has previously been used on carbon steel — embedded steel particles will introduce corrosion sites and porosity into the aluminium weld.
Can you MIG weld thin aluminium without burning through?
Yes. Thin aluminium can be MIG welded successfully with the correct equipment, parameters, and technique. Pulse MIG welding is particularly effective because it controls heat input while maintaining good fusion. Using smaller diameter filler wire, consistent travel speeds, close joint fit-up, and backing bars can help prevent burn-through and distortion.
What is the best MIG welding process for thin aluminium?
Pulse MIG welding is generally preferred for thin aluminium because it provides controlled metal transfer with lower average heat input than conventional spray transfer. This helps reduce burn-through, distortion, and spatter while maintaining arc stability and weld quality. Advanced power sources with aluminium-specific synergic programmes can further simplify parameter selection.
What filler wire should I use for MIG welding thin aluminium?
Common filler wires for thin aluminium MIG welding include 4043 and 5356, typically in diameters of 0.8 mm or 1.0 mm. The 4043 alloy offers good fluidity and lower crack sensitivity, while 5356 provides higher strength and better colour matching after anodising. Filler selection must always be compatible with the base aluminium alloy and application requirements.
What shielding gas is best for MIG welding thin aluminium?
Pure argon (100%) is the standard shielding gas for MIG welding thin aluminium. It provides stable arc performance and consistent weld quality without introducing excessive heat. Argon/helium mixtures are generally better suited to thicker aluminium sections requiring increased penetration. CO₂-containing shielding gases should not be used for aluminium welding.
How can I prevent distortion and wire feeding problems when welding thin aluminium?
To minimise distortion, maintain consistent travel speed, control heat input with pulse MIG, use closely spaced tack welds, and allow cooling between passes. To prevent wire feeding problems, use smooth U-groove drive rolls, non-metallic liners, and a spool gun or push-pull torch. These components help deliver soft aluminium wire consistently and reduce birdnesting, burn-back, and arc instability.
