Oil and gas pipelines operate under extreme conditions — high pressures, corrosive media, temperature fluctuations, and in some cases subsea or arctic environments. A weld defect in a pipeline is not simply a quality issue: it is a safety and environmental risk with potentially catastrophic consequences. Local and international pipeline welding standards exist to establish minimum requirements for materials, design, fabrication, inspection, and maintenance, ensuring that pipelines are consistently safe and reliable across all operating environments — onshore, offshore, underground, and overground.
This article summarises the key oil and gas pipeline standards covering welding, explains what each requires, and outlines what compliance means in practice for welders, fabricators, and operators.
Standardisation in the oil and gas industry serves three core purposes:
When every step — from material selection through welding procedure qualification, production welding, and final inspection — is carried out in accordance with the applicable standard, the pipeline can be deemed safe and reliable by both national regulators and international operators. Non-compliance at any stage can compromise the integrity of the entire system.
API 1104 is the most widely used welding standard in the global oil and gas pipeline industry. It covers the welding of carbon and low-alloy steel pipeline systems in their entirety — from procedure qualification through production welding and inspection — for both new construction and in-service repair welding.
Key areas covered by API 1104 include:
AWS D10.12 and AWS D10.18 complement API 1104 by providing process-specific and material-specific guidance for mild steel and duplex stainless steel pipeline applications respectively.
Meeting oil and gas pipeline welding standards is not simply a matter of selecting the correct process — it requires documented compliance at every stage of the welding operation:
Every welding operation on an oil and gas pipeline must be performed to a qualified WPS. The WPS defines the essential variables — process, filler metal, preheat, interpass temperature, heat input, position, and post-weld heat treatment — within which the procedure has been qualified. Any change to an essential variable requires requalification. For guidance on managing WPS and PQR documentation, see our article on WPS and PQR management with WeldCloud Notes.
Filler metals must be specified and used in accordance with the WPS. Traceability of filler metal batch, diameter, and classification to each weld is typically required for high-specification pipeline work. ESAB's range of pipeline filler metals — including solid wires, flux-cored wires, and TIG rods for carbon steel, low-alloy, and stainless steel pipeline applications — covers the full scope of API 1104 and AWS D10 requirements. See our welding consumables selection guide for material-by-material filler metal recommendations.
Low-hydrogen practice is mandatory for most pipeline welding. This means using low-hydrogen designated consumables, maintaining correct storage and handling of electrodes and flux, and controlling preheat and interpass temperatures to allow hydrogen to diffuse from the weld before cooling. For flux-dependent processes, see our guides on flux baking and flux storage and handling.
Pipeline welds are subject to rigorous non-destructive testing — radiography, automated ultrasonic testing (AUT), magnetic particle inspection, or a combination — in accordance with the applicable standard and project specification. Weld quality data and inspection records must be maintained and traceable to the specific weld, welder, procedure, and date.
ESAB offers a complete range of equipment and consumables qualified for oil and gas pipeline welding applications:
What are the main welding standards for oil and gas pipelines?
The primary welding standards for oil and gas pipelines include API 1104, ISO 13623, ASME B31.4, ASME B31.8, and relevant AWS standards. API 1104 covers pipeline welding procedures, welder qualification, and inspection requirements. ASME B31.4 and B31.8 address liquid and gas pipeline systems, while ISO 13623 provides international guidance for onshore and offshore pipeline design, construction, and operation.
What is API 1104, and why is it important for pipeline welding?
API 1104 is a widely used standard governing the welding of carbon and low-alloy steel pipelines in the oil and gas industry. It establishes requirements for welding procedure qualification, welder certification, welding processes, and inspection acceptance criteria. Compliance helps ensure consistent weld quality, structural integrity, and safety during pipeline construction, maintenance, and repair.
What is the difference between API 1104 and ASME B31.4 or B31.8?
API 1104 focuses specifically on pipeline welding, including procedure qualification, welder testing, and weld inspection. ASME B31.4 covers pipeline transportation systems for liquids, while ASME B31.8 applies to gas transmission and distribution piping systems. These standards are often used together, with the applicable ASME code establishing broader pipeline system requirements and API 1104 providing welding-specific requirements.
What qualifications are required for oil and gas pipeline welders?
Pipeline welders must be qualified according to the applicable welding standard, typically API 1104 or another code specified by the project. Qualification testing demonstrates the welder's ability to produce acceptable welds using the required process, position, and materials. Welding must also follow a qualified Welding Procedure Specification (WPS), supported by appropriate procedure qualification documentation and inspection records.
How are oil and gas pipeline welds inspected for compliance?
Pipeline welds are inspected using methods specified by the applicable code and project requirements. Common techniques include visual inspection, radiographic testing (RT), ultrasonic testing (UT), and magnetic particle testing (MT). Inspection results are evaluated against defined acceptance criteria, with records maintained to provide traceability to the weld, welder, welding procedure, and inspection date.
