MIG welding is one of the most versatile arc welding processes available — capable of joining a wide range of metals and alloys across a broad thickness range. But the metals you are welding directly determine the wire type, shielding gas, transfer mode, and technique required. Using the wrong combination of consumable and gas for a given base metal will produce poor results regardless of operator skill. This guide covers the most common base metals for MIG welding, what makes each one distinctive, and the key considerations for each.
For a full introduction to how MIG welding works, transfer modes, and equipment selection, see our article on what is MIG welding.
Carbon steel and mild steel are the most commonly MIG welded materials globally. Their weldability is generally excellent — they are tolerant of a range of parameters and shielding gases, and a wide range of filler wires is available.
Key considerations for MIG welding carbon and mild steel:
For high-strength carbon and low-alloy steels, filler metal selection requires more careful attention — the wire must meet the mechanical property requirements of the base material. See our welding consumables selection guide and our article on low manganese filler metals for heavy industrial applications.
Stainless steel's resistance to corrosion and oxidation makes it essential in food processing, pharmaceutical, chemical, and marine applications. MIG welding stainless steel is well established but requires specific consumable and gas combinations to maintain corrosion resistance in the finished weld.
Key considerations for MIG welding stainless steel:
For dissimilar material joints involving stainless steel, or for duplex and super-duplex stainless steels, see our article on specialised filler metals for exotic alloys.
Aluminium MIG welding is widely used in automotive, marine, aerospace, and general fabrication. The process works well but requires different equipment setup and technique compared to steel — aluminium's lower melting point, higher thermal conductivity, and tendency to form a refractory oxide layer all require careful management.
Key considerations for MIG welding aluminium:
For troubleshooting common aluminium MIG welding problems, see our article on aluminium MIG troubleshooting at the arc.
Copper's high thermal conductivity — approximately eight times that of mild steel — means heat dissipates very rapidly from the weld area, making fusion more difficult to achieve. MIG welding of copper and copper alloys (bronze, brass, copper-nickel) is possible but requires higher heat input and preheat on thicker sections to overcome the thermal conductivity disadvantage. Filler wire selection must account for the specific alloy being welded — copper-silicon (CuSi3) and copper-aluminium (CuAl) wires cover most common applications. Argon shielding gas is standard.
Nickel alloys — including Inconel, Hastelloy, and Monel — are used in high-temperature and highly corrosive service environments where standard steels and stainless steels cannot perform. MIG welding of nickel alloys requires matched or compatible nickel-based filler wires, controlled heat input to prevent hot cracking, and strict contamination control. Argon shielding gas or argon/helium mixtures are used. For detailed guidance on filler metal selection for nickel alloys, see our article on specialised filler metals for exotic alloys and the Exaton nickel alloy filler range.
Titanium is highly reactive at elevated temperatures and will absorb oxygen, nitrogen, and hydrogen from the atmosphere if shielding is inadequate — causing severe embrittlement of the weld. While MIG welding of titanium is possible, TIG (GTAW) with comprehensive atmospheric shielding (trailing shields, back purging, and pure argon at 99.999%) is the preferred process for most titanium applications. For guidance on titanium welding and contamination control, see our article on welding exotic alloys.
What types of metals can be MIG welded?
MIG welding can be used to join a wide range of metals, including mild steel, carbon steel, stainless steel, aluminium, copper, bronze, nickel alloys, and titanium. Each metal requires compatible filler wire, shielding gas, and welding parameters to achieve proper fusion and weld quality. MIG welding is widely used in automotive manufacturing, structural fabrication, shipbuilding, and general engineering.
What is the easiest metal to MIG weld?
Mild steel is generally considered the easiest metal to MIG weld because of its good weldability, relatively forgiving operating parameters, and wide availability of compatible filler wires. ER70S-6 wire is commonly used for general fabrication, while argon/CO₂ shielding gas mixtures provide stable arc performance and good penetration. Mild steel is an excellent starting point for beginners learning MIG welding.
Can you MIG weld stainless steel and aluminium with the same machine?
Yes. Many MIG welding machines can weld both stainless steel and aluminium, but the filler wire, shielding gas, and equipment setup must be changed to suit each material. Stainless steel typically requires compatible stainless filler wire and a low-CO₂ shielding gas mixture. Aluminium requires an appropriate aluminium filler alloy, pure argon shielding gas, and specialised wire feeding components to prevent wire deformation and feeding problems.
What shielding gas should be used for different metals in MIG welding?
Shielding gas selection depends on the base metal and welding process. Mild steel commonly uses argon/CO₂ mixtures, while stainless steel typically requires argon-rich mixtures with small additions of active gas. Aluminium is generally welded using pure argon or argon/helium mixtures for thicker sections. Copper and nickel alloys commonly use argon or argon/helium mixtures. Using the correct shielding gas helps maintain arc stability, penetration, and weld quality.
Can you MIG weld copper, nickel alloys, and titanium?
Yes. MIG welding can be used for copper, nickel alloys, and titanium, although these materials require specialised procedures. Copper's high thermal conductivity often requires additional heat input or preheating. Nickel alloys need compatible filler metals and controlled heat input to reduce cracking. Titanium requires exceptionally clean conditions and comprehensive inert gas shielding to prevent contamination and weld embrittlement.
