Whether you’re a first-time buyer looking for a reliable handheld plasma cutter or a fabrication professional cutting metal every day, plasma cutting is one of the fastest, most versatile and most cost-effective ways to cut conductive metal. This guide covers everything you need to know — from how plasma arc cutting works, to choosing the right manual plasma cutter for your application, understanding gas selection, getting the best cut quality and knowing when a CNC system makes more sense.
Plasma is the fourth state of matter — a superheated, ionised gas that conducts electricity. In plasma cutting, compressed gas (typically air, nitrogen or oxygen) is forced through a small copper nozzle where it contacts an electrode and ionises into a plasma arc. This arc reaches temperatures exceeding 20,000°C — hot enough to melt through virtually any electrically conductive metal almost instantly.
The process works like this:
Unlike oxy-fuel cutting, which relies on a chemical oxidation reaction and only works on mild steel, plasma cutting works on all conductive metals — including stainless steel and aluminium — making it far more versatile in a real fabrication environment.
For the majority of fabrication shops, maintenance teams, construction sites and metalworkers, a manual (handheld) plasma cutter is the right tool. It’s portable, quick to set up, straightforward to operate and capable of cutting everything from thin sheet metal to structural steel plate — all with a single machine that can go wherever the job takes you.
Manual plasma cutting is ideal for:
The most important factor when choosing a manual plasma cutter is matching the machine’s output amperage to the thickness of material you cut most often. A higher amperage machine cuts thicker material, but also costs more and typically draws more from the power supply. For most workshop and site applications, the answer lies in one of three ranges — light fabrication, mid-range all-rounder or heavy workshop use.
The ESAB Cutmaster+ range — built on the heritage of Thermal Dynamics, one of the most trusted names in plasma cutting — offers a complete lineup of manual plasma cutters from light fabrication through to heavy workshop and site use. Every Cutmaster+ shares the same core design principles: honest cut capacity ratings, the industry-leading SL60 1Torch® for ergonomic handling, and long-life Black Series consumables that reduce your running costs.
Compact and lightweight, the Cutmaster 30+ is the ideal entry-level professional plasma cutter for light fabrication, automotive, HVAC and maintenance work. Runs on standard single-phase 230V — no special power supply needed.
View the Cutmaster 30+ ›
The mid-range all-rounder and the most popular Cutmaster for fabrication shops and trade professionals. With a 25mm cut capacity and portable enough to take to site, it handles the vast majority of professional cutting tasks.
View the Cutmaster 50+ ›
The high-output model for demanding environments — heavy plate, structural steel, construction and industrial maintenance. 70 amps of cutting power in a portable, all-weather package that goes wherever the job takes you.
View the Cutmaster 70+ ›
With the right technique, a manual plasma cutter produces clean, dross-free cuts that need minimal finishing. The key variables to control are travel speed, standoff distance, air quality and consumable condition.
Most manual plasma cutters — including the entire Cutmaster range — run on compressed air, which makes them practical and low-cost to operate. Understanding when other gases might be worth considering helps you get the best results across different materials.
Compressed air is the standard plasma gas for manual cutting and the right choice for the vast majority of applications. It delivers a good balance of cutting speed and cut quality on mild steel, stainless steel and aluminium. The key requirement is clean, dry air — a two-stage inline filter and dryer is the best investment you can make for consistent performance.
Nitrogen produces a cleaner cut edge than compressed air on stainless steel and aluminium, with less oxidation on the cut face. It is sometimes used for manual cutting when cut edge quality on non-ferrous metals is important, for example in food-grade stainless fabrication where discolouration on the cut edge is unacceptable.
Plasma cutting works on any electrically conductive metal. The most commonly cut materials are:
A manual plasma cutter is the right tool for the majority of fabrication and site applications. However, if your work regularly involves any of the following, a CNC plasma table is worth considering:
For shops looking for a bridge between manual and full CNC, the Cutmaster 50+ and 70+ both include a pre-installed 14-pin CNC interface. Combined with the optional ESAB MechPak straight-line attachment, they can be used for semi-automated straight-line and circle cutting — a practical step up from freehand cutting without the investment of a full CNC table.
For full CNC plasma cutting, ESAB’s Columbus CNC table range and gantry systems offer scalable solutions for every production environment. See our guide to choosing a CNC plasma cutter.
Plasma cutting is the most versatile and cost-effective cutting method for most fabricators. Here’s how it compares to the alternatives
If you’re ready to choose your next plasma cutter, ESAB’s application specialists are here to help you find the right Cutmaster+ for your application — whether that’s the lightweight, versatile Cutmaster 30+ for light fabrication and site work, the all-round professional Cutmaster 50+ for general workshop and trade use, or the high-output Cutmaster 70+ for demanding heavy fabrication environments.
Cutmaster 30+ | Cutmaster 50+ | Cutmaster 70+
Or get in touch with an ESAB specialist to discuss your cutting application and get the right system specified for your needs.
