Laser welding is one of the fastest-growing joining processes in modern fabrication — delivering exceptional precision, minimal distortion, and weld speeds that conventional arc welding cannot match. But alongside its performance advantages, laser welding introduces a category of hazard that is fundamentally different from conventional arc welding. The beam is invisible, silent, and capable of causing permanent eye damage in milliseconds. Understanding both how laser welding works and why it demands a different approach to safety is essential for anyone operating, supervising, or specifying these systems.
Laser welding (Light Amplification by Stimulated Emission of Radiation) is a fusion welding process in which metals are joined using a highly focused laser beam. The beam is directed onto the joint between the materials to be welded, melting the base materials at the seam and fusing them as the material cools and solidifies.
The highly concentrated heat source allows laser welding to be carried out at high speeds — in some applications, metres per minute — while the small heat-affected zone (HAZ) minimises distortion and thermal stress on the surrounding material. This combination of speed, precision, and low distortion is what drives the rapid adoption of laser welding across automotive, aerospace, medical, and structural fabrication industries.
There are two fundamental modes of laser welding, each suited to different applications and power levels:
In heat conduction welding, the laser beam heats the material surface above its melting point but below the vaporisation point. The process produces smooth, aesthetically clean welds with a shallow penetration profile, carried out with a relatively low-power laser (below 500 W). Typical applications include thin sheet joining, jewellery manufacture, and precision electronics where appearance and minimal penetration are priorities.
In keyhole welding, the laser beam heats the material to the point of vaporisation, penetrating deep into the material and creating a narrow channel — the "keyhole" — with a plasma-like condition inside it and temperatures exceeding 10,000 K. Keyhole welding is carried out with high-power lasers (above 10⁵ W/mm²) and produces deep, narrow welds with an excellent depth-to-width ratio. This is the standard mode for structural and industrial laser welding applications.
Laser welding can be combined with conventional arc welding — MIG, TIG, MAG, or plasma — to create hybrid laser arc welding. The combination delivers the advantages of both processes: the deep penetration and high speed of laser welding, with the gap-bridging capability, controlled weld cooling, and metallurgical flexibility of arc welding. Hybrid laser welding is widely used in shipbuilding, heavy fabrication, and automotive manufacturing.
The same properties that make laser welding so effective — the concentrated, high-energy beam — also make it significantly more hazardous than conventional arc welding if not properly controlled. These differences are not incremental; they require a fundamentally different approach to risk management and PPE.
ESAB handheld laser welding systems operate as Class III-A or Class IV devices. Understanding the distinction is essential for anyone working with or near these systems.
Class III-A laser products are primarily hazardous when combined with optical instruments that change the beam diameter or power density. Even without optical amplification, direct contact with the eye for more than two minutes can cause serious retinal damage.
Class IV laser products are the highest hazard class. They have high output power and cause immediate, serious eye and skin injuries to anyone in the path of the direct or reflected beam. There is no safe level of unprotected exposure. Class IV lasers can also present fire hazards when the beam contacts flammable materials. ESAB handheld laser welding systems operate as Class IV energy during welding.
Laser welding safety requirements apply to everyone in the laser environment — not only the operator. This includes:
For full guidance on setting up a safe laser welding workspace including LCA requirements and access controls, see our article on setting up a safe laser welding workspace.
Every organisation operating a laser welding system must appoint a qualified Laser Safety Officer (LSO). The LSO is a regulatory requirement under IEC 60825-1 and ANSI Z136.9, and is responsible for hazard evaluation, control measures, procedure approval, and operator training. A certified LSO must be available at all times during laser welding operations.
International Electrotechnical Commission. (2014). IEC 60825-1: Safety of laser products — Part 1: Equipment classification and requirements. https://webstore.iec.ch/en/publication/3587
What is laser welding, and how does it work?
Laser welding is a fusion welding process that uses a highly concentrated laser beam to melt and join metals. The focused heat source produces precise welds with a small heat-affected zone, minimal distortion, and high travel speeds. Two primary methods are heat conduction welding, used for shallow precision welds, and keyhole welding, which provides deeper penetration for industrial applications.
What are the advantages of laser welding compared to MIG and TIG welding?
Laser welding offers faster welding speeds, greater precision, and a smaller heat-affected zone than conventional MIG and TIG welding in many applications. Its concentrated energy reduces thermal distortion and enables consistent weld quality, making it particularly suitable for automotive, aerospace, medical device manufacturing, and precision fabrication. However, laser welding requires specialised equipment, strict joint preparation, and additional safety measures.
What are the main safety hazards of laser welding?
Laser welding presents serious hazards from direct and reflected laser radiation, particularly with Class IV systems. Near-infrared laser beams are invisible to the naked eye and can cause permanent eye damage or skin injuries in milliseconds. Additional risks include fire, welding fumes, and hazardous reflections from metal surfaces. Proper laser-rated protective equipment, controlled work areas, and operator training are essential.
Can you use a standard welding helmet for laser welding?
No. Standard MIG, TIG, and stick welding helmets are not designed to protect against the near-infrared radiation produced by many laser welding systems. Laser welding requires protective eyewear and face protection specifically rated for the laser's wavelength and power. Equipment should comply with applicable standards, such as EN 207, and be selected according to a documented laser hazard assessment.
What safety standards apply to industrial laser welding?
Industrial laser welding is governed by standards including IEC 60825-1 for laser product classification, ANSI Z136.9 for laser safety in manufacturing, EN 207 for laser eye protection, and ISO 11553-1 for laser processing machinery. Employers must assess laser hazards, establish appropriate Laser Controlled Areas, implement protective measures, and ensure personnel receive suitable training. A Laser Safety Officer should oversee the programme in accordance with applicable regulations and safety requirements.
