Most fabricators know their plasma cutter as a cutting tool. Far fewer realise it’s also one of the most effective metal removal tools in the workshop. Plasma arc gouging uses the same machine, the same compressed air supply and the same basic technology — but with a different torch angle, different consumables and a different technique, it removes material rather than severing it. The result is a faster, cleaner and safer alternative to carbon arc gouging and grinding for a wide range of fabrication and repair tasks.
This guide covers what plasma gouging is, when to use it, how it compares to other methods, and the five key motion techniques that give you full control over the profile and depth of your gouge.
For a full introduction to plasma cutting, see our Complete Guide to Plasma Cutting.
What Is Plasma Arc Gouging?
Plasma arc gouging is a variation of plasma cutting in which the arc is used to melt and remove metal from the surface of a workpiece — creating a groove or channel — without severing the base material.
In plasma cutting, the torch is held perpendicular to the work surface and the arc cuts all the way through. In plasma gouging, the torch is angled to the surface and the arc melts into the material, while high-velocity gas blows the molten metal away to the side. The result is a controlled groove — the depth, width and profile of which you control through torch angle, travel speed and amperage.
The key differences from cutting are:
  • Torch angle — 35° to 60° to the work surface (versus perpendicular for cutting)
  • Consumables — a larger nozzle with a wider orifice “defocuses” the arc to spread it across a wider area for material removal rather than a precise cut
  • Travel direction — torch is pushed forward into the gouge (in the direction of travel) rather than dragged
  • Objective — controlled material removal, not separation
When to Use Plasma Gouging
Plasma gouging is the right tool any time you need to remove material from the surface of metal without cutting through it. The most common applications are:
  • Weld removal and rework — removing a defective weld before re-welding. Plasma gouging removes the weld cleanly without damaging the base material, leaving a surface that’s ready to reweld with minimal grinding.
  • Back gouging — preparing the back side of a weld joint for a back-weld pass on full-penetration welds. Essential in structural steel, pressure vessel and pipeline fabrication.
  • Defect removal — removing cracks, porosity or inclusions from castings, plate or welds prior to repair welding.
  • Plate edge preparation — creating a bevel or J-groove profile on plate edges for weld joint preparation.
  • Maintenance and repair — removing old welds, corroded sections or damaged material on heavy equipment, structural steel, pipework and vehicles.
  • Hole enlargement — opening up or cleaning out existing holes or cutouts.
Plasma Gouging vs Other Metal Removal Methods
Plasma gouging is one of four common methods for removing metal. Understanding how it compares helps you choose the right approach for the job.
Method Speed Materials Edge quality Noise & fume
Plasma arc gouging Fast All conductive metals Clean, minimal post-work Low noise, moderate fume
Carbon arc gouging Fast (high removal rate) Most metals Carbon deposits, requires grinding Very loud, heavy fume and spatter
Grinding Slow Most metals Good with care Loud, dust
Oxy-fuel gouging Slow (requires preheat) Mild steel only Variable Moderate noise and fume
Plasma gouging’s main advantages over carbon arc gouging — the most common alternative in heavy fabrication — are its cleaner gouge surface (no carbon deposits, no carbon embrittlement of the base material), significantly lower noise levels, and the fact that it works on stainless steel and aluminium as well as mild steel. The gouged surface is ready to reweld with minimal or no grinding preparation.
Equipment: What You Need
The good news is you don’t need a separate machine for plasma gouging. Any plasma cutter that supports gouging consumables can gouge. What you do need:
  • Plasma cutter with sufficient amperage — gouging is more demanding than cutting at equivalent material thickness. A 50A machine will gouge effectively on light to medium applications. For deep or wide gouges on heavier material, 70A or more gives you better control and productivity.
  • Gouging consumables — a gouging nozzle has a larger orifice than a cutting nozzle, which defocuses the arc and creates the wider, softer arc profile needed for material removal rather than a precise cut. You’ll also need a gouging shield. The ESAB Cutmaster SL60 1Torch® accepts a full range of gouging consumables — check the consumables kit for your Cutmaster model.
  • Gouging mode (if available) — some machines have a dedicated gouging mode that adjusts gas pressure and arc characteristics for optimal gouging performance. If your machine has this, use it.
  • Clean, dry compressed air — same requirement as for cutting. Moisture and oil contamination affect gouge quality in the same way they affect cut quality.
  • PPE — plasma gouging produces more spatter than cutting. Use a full welding helmet (not just a cutting shield), fire-resistant clothing, heavy gloves and hearing protection. Ensure adequate fume extraction or ventilation.
The Five Plasma Gouging Techniques
Controlling the profile, depth and width of a plasma gouge comes down to mastering the five core motion techniques. Each produces a different result and is suited to different applications.
1. Straight Gouge
The most common technique. The torch is held at 35°–45° to the work surface and moved in a straight line along the area to be gouged. The arc is pushed forward into the material in the direction of travel.
  • Profile: narrow, parabolic groove
  • Controls: steeper angle and slower speed = deeper, narrower gouge. Shallower angle and faster speed = wider, shallower gouge
  • Best for: weld removal along a joint, back gouging, preparing long runs for rewelding
2. U-Shaped / Weave Gouge
The torch is moved in a side-to-side weaving motion while travelling forward, producing a wider, U-shaped groove. The width of the weave controls the width of the gouge.
  • Profile: wide, U-shaped channel
  • Best for: removing wide welds, preparing large areas for rewelding, aggressive material removal where width is needed
  • Tip: keep the weave motion smooth and consistent to maintain a uniform groove depth across the full width
3. Circle / Hole Gouging
The torch is moved in a circular or oval pattern to enlarge a hole, clean out an existing cutout, or create a recessed area. The torch angle and distance from the edge of the hole control the depth and profile.
  • Profile: circular or oval recess
  • Best for: enlarging holes, removing fasteners or inserts, creating recesses in plate
  • Tip: work progressively — multiple lighter passes give better control than trying to remove too much material in a single pass
4. Wipe Gouge
A controlled sweep of the torch across the surface at a very shallow angle, removing a thin layer of material over a wide area. Used when you need to clean up a surface rather than cut a defined groove.
  • Profile: broad, shallow removal across a wide area
  • Best for: removing surface corrosion, paint, coatings or weld spatter over a large area; surface preparation before welding
  • Tip: keep the angle very shallow (20°–30°) and maintain a consistent distance from the surface to avoid gouging into the base material
5. Back Gouge
Gouging from the back side of a completed weld to expose the weld root before applying a back-weld pass. The torch is positioned under or behind the joint and angled to remove material from the root area without damaging the surrounding base metal.
  • Profile: targeted groove at the weld root
  • Best for: full-penetration welds in structural steel, pressure vessels, pipework and any joint requiring a back-weld pass for full structural integrity
  • Tip: take your time — back gouging in a confined space rewards slow, controlled movement over trying to work quickly
Key Tips for Better Plasma Gouging
  • Practice on scrap first — gouging is a skill that takes a little time to develop. Run a few test passes on scrap material of the same thickness before working on the actual part.
  • Start with lower amperage — it’s easier to take additional passes than to repair a gouge that went too deep. Start at a lower amperage and increase if needed.
  • Keep the arc moving — pausing or slowing down significantly in one spot concentrates heat and increases depth rapidly. Maintain a consistent travel speed.
  • Single passes where possible — for precise work, multiple shallow passes give more control over the final profile than one deep pass.
  • Inspect consumables before gouging — worn consumables produce an inconsistent arc that is hard to control. Start with fresh gouging consumables for critical work.
  • Allow for post-gouge inspection — after back gouging a weld root, visually inspect (and dye penetrant test where required by the welding procedure) before applying the back-weld pass.
Gouging with the ESAB Cutmaster+ Range
All three Cutmaster+ models support plasma gouging with the appropriate gouging consumables for the SL60 1Torch®. For most gouging applications in a fabrication shop or on site, the Cutmaster 50+ or Cutmaster 70+ are the recommended choice — the higher amperage gives you better control over gouge depth and allows you to work at productive speeds without pushing the machine to its limits.
  • Cutmaster 50+ — 50A, suitable for light to medium gouging on material up to around 20mm
  • Cutmaster 70+ — 70A, recommended for heavier gouging, back gouging on thick plate, and any application where depth and speed of removal matter
Contact your ESAB specialist or distributor to confirm the correct gouging consumable kit for your Cutmaster+ model.
