Choosing the Right Filler Metal for Aluminium Welding
January 18, 2026
Filler metal selection is one of the most consequential decisions in aluminium welding — and one of the most misunderstood. The wrong wire can cause hot cracking, poor corrosion behaviour, or joints that fall short of design strength even when the rest of the setup looks right. This guide walks through a practical, step-by-step approach to choosing the right filler for your base alloy, application, and service conditions.
If you'd rather talk it through, ESAB's specialists can help you match filler, wire, and full system to your aluminium application. Shop our solutions or contact us for more information.
Jump to:
Why Filler Choice Matters in Aluminium Welding
In aluminium welding, filler metal isn’t just wire that matches the plate. The alloy you choose influences how easily the joint welds without hot cracking, the tensile and shear strength of the finished weld, ductility, corrosion performance, and even how the part looks after anodising.
Get it wrong and you can end up with cracking, poor corrosion behaviour or joints that don’t meet design strength — even if everything else about the setup looks right. Get it right and aluminium becomes far more predictable, both in the workshop and in the field. Learn more Avoiding Porosity and Cracking.
The goal of this article is to turn the technical data in ESAB’s aluminium guide into a simple, repeatable way of choosing filler: start from the base alloy and application, then narrow down based on strength, crack resistance, service conditions and appearance.
Step 1: Know Your Base Alloy
Filler selection always starts with the base material. Aluminium alloys are grouped by series:
  • 1xxx, 3xxx, 5xxx – non heat-treatable (often used where corrosion resistance and formability matter).
  • 2xxx, 6xxx, 7xxx – heat-treatable (often used for higher-strength structures and extrusions).
The first digit of the alloy tells you the main alloying element (1xxx = nearly pure aluminium, 5xxx = magnesium, 6xxx = magnesium–silicon, and so on). Once you know the alloy family (for example 5xxx vs 6xxx), the list of sensible filler options becomes much shorter.
Common patterns:
  • 5xxx base alloys (e.g. 5083, 5086): usually paired with 5xxx fillers like 5183, 5356, 5556 to maintain strength and corrosion performance.
  • 6xxx base alloys (e.g. 6061): often welded with 4043 (good crack resistance, easy to weld) or 5356 (higher strength, better anodised colour match), depending on priorities.
  • Some alloys such as 2024 and 7075 are generally considered non-weldable for critical load-bearing applications because of hot-cracking risk and should be flagged early in design.
Step 2: Match Filler to Strength Requirements
Next, look at what the joint needs to carry in service. For groove welds, the heat-affected zone in the base material often controls tensile strength. For fillet welds, the filler metal has a large impact on shear strength.
High-strength 5xxx fillers (5183, 5356, 5556) deliver strong fillet welds on many 5xxx base alloys. On 6xxx alloys, the weld zone will usually be softer than the T6 base metal; the question isn’t “does it match T6?” but “does the welded joint still meet design strength with the chosen filler?” Learn more about Understanding Heat-Treatable vs Non-Heat-Treatable Alloys.
A practical workflow:
  1. Identify whether the joint is mainly fillet (shear) or groove (tension).
  2. Use data tables to compare typical shear/tensile properties for candidate fillers on your base alloy.
  3. Choose the filler that gives enough strength while still meeting crack-resistance and corrosion requirements.
Step 3: Manage Crack Sensitivity
Hot cracking is one of the most serious ways an aluminium weld can fail. It’s driven by the combined chemistry of the base and filler and by the solidification range of the weld metal.
Silicon-rich 4xxx fillers (4043, 4047, 4643) tend to reduce hot-cracking risk on many 6xxx alloys because they lower the melting range and improve fluidity. Magnesium-bearing 5xxx fillers (5356, 5183, 5556, 5554, 5654) are usually the right choice for 5xxx base alloys, but in some combinations you need to watch for increased cracking or stress-corrosion susceptibility at elevated temperature.
A simple way to think about it:
  • If crack resistance on 6xxx is the top priority, 4043 is often a good starting point.
  • If you need higher strength and better colour match on 6xxx, 5356 can be used — but procedure control becomes more important.
  • For 5xxx base alloys in transport and marine work, 5xxx fillers remain the default, with exact choice depending on strength and temperature.
Step 4: Service Conditions – Corrosion, Temperature, Fatigue
Two wires may both weld nicely in the shop but behave very differently in service. When choosing filler, think about the environment and loading the joint will see.
Corrosion and Environment
In marine or de-icing salt environments, filler choice can influence how the welded joint corrodes relative to the base metal. For example:
  • For 5xxx base alloys in marine service, fillers like 5183, 5356 or 5556 are commonly used because they offer a good balance of strength and corrosion performance.
  • For 6xxx structures exposed to salt water, a 5xxx filler may be preferred over 4xxx if corrosion is a major concern — provided cracking and strength remain acceptable.
Elevated Temperature
Some Mg-bearing fillers are not recommended for sustained high-temperature service due to stress-corrosion cracking risk. For components that see elevated temperature (for example certain tanks or structures near heat sources), you’ll want a filler that is explicitly rated as suitable above typical thresholds.
Fatigue
If the weld will see repeated loading, both filler alloy and weld profile matter. Even with the right filler, excessive face reinforcement or undercut will reduce fatigue life. Good joint design and profile control are essential to let the filler’s mechanical properties translate into real-world performance.
Step 5: Appearance and Anodising
For architectural, rail and visible transport components, appearance can be just as important as strength. Different fillers respond differently to anodising.
On 6061, for example, 4043 often gives very good weldability but a darker, greyer tone after clear anodising. 5356 typically produces a brighter weld that blends better with the base material.
Even when you choose a filler with an excellent colour rating, the weld may still be visible because the weld metal behaves like a casting next to a rolled or extruded surface. The anodised layer follows the surface texture; it doesn’t flatten out the weld. Surface preparation — light grinding, brushing, bead blasting — can make the weld far less noticeable after anodising.
Practical Choices: 4043 vs 5356 vs 5183 vs 5554/5556
Filler Alloy Typical Use Key Advantages Trade-offs /Notes
4043 (Al–Si)
6xxx series and many cast aluminium alloys; general fabrication where ease of welding and leak-tight joints matter.
Very good hot-crack resistance; fluid weld pool with good wetting; well suited to leak-tight joints and positional work.
Lower tensile strength than many 5xxx fillers; typically darker / greyer appearance after anodising compared with 5xxx wires.
5356 (Al–Mg ≈5%)
5xxx base alloys and many 6xxx structures in transport, marine and general fabrication.
High fillet shear strength; good general corrosion behaviour; usually brighter anodised colour on 6xxx than 4043.
Can be more sensitive to cracking on some heat-treatable alloys; requires good procedure control and parameter selection.
5183
High-strength 5xxx alloys (e.g. 5083, 5456) in marine, offshore and transport applications.
Very high fillet shear strength; good performance at low and cryogenic temperatures; suitable for demanding structural joints.
Availability and cost may differ from 5356 in some regions; selection should follow design and code requirements.
5554 / 5556
5xxx alloys where properties must be retained at elevated service temperatures (e.g. certain tanks and structures).
Balanced strength and corrosion resistance; formulated for improved performance in warm service conditions.
Always confirm suitability against the specific base alloy and service conditions using a filler selection chart.
ESAB’s aluminium filler alloy charts provide A–D ratings for weldability, strength, ductility, corrosion, temperature and colour match for each of these fillers across a wide range of base alloys. Use those charts as your shortlist filter whenever you introduce a new aluminium grade into production.
Next Steps with ESAB Aluminium Solutions
If you're reviewing filler choices for your aluminium work, it's worth aligning the full picture at the same time.
  1. Confirm your filler selection Check your main base alloys against ESAB's aluminium filler alloy chart to confirm you're running the best-fit wire for strength, crack resistance, corrosion, and appearance.
  2. Review your feedability setup Drive rolls, liners, and contact tips all need to be matched to your chosen filler. Whether you're running a manual system — Warrior Edge DX / RobustFeed Edge DX / PP 350w Push-pull Torch — or a robotic setup — Aristo Edge / RoboFeed Edge / RT PushPull — the wire needs to feed cleanly before anything else works.
  3. Align your shielding gas strategy Filler selection doesn't sit in isolation. Make sure your wire, process, and gas — argon or argon/helium — are working together as a system.
Explore ESAB's Aluminium Solutions or contact us if you need a second opinion or want to standardise aluminium procedures across multiple sites, ESAB's specialists can help you review filler selection and full system setup for your key applications.
Frequently Asked Questions
Pure argon is generally the best shielding gas for most aluminium MIG and TIG welding applications. It provides a stable arc, good weld pool control, and consistent weld quality, particularly on thin and medium-thickness aluminium. For thicker materials, argon/helium mixtures can provide additional heat and deeper penetration.
Argon produces a stable, controlled welding arc and is well suited to general aluminium fabrication. Helium increases arc energy, producing a hotter, more fluid weld pool with greater penetration. Argon/helium mixtures combine the arc stability of argon with the additional heat of helium, making them useful for thicker aluminium sections.
Argon/helium mixtures are recommended for applications involving thick aluminium sections, heavy structural components, or high-productivity welding. The additional heat can improve penetration, increase travel speed, and reduce the number of welding passes required. However, the higher gas cost should be considered when selecting a shielding gas.
No. CO₂ and argon/CO₂ mixtures are designed for welding materials such as steel and are not suitable for aluminium. These active gases react with molten aluminium, causing excessive oxidation, porosity, and poor weld quality. Aluminium welding requires inert shielding gases such as pure argon, helium, or an argon/helium mixture.
