Most fabricators know their plasma cutter as a cutting tool. Far fewer realise it’s also one of the most effective metal removal tools in the workshop. Plasma arc gouging uses the same machine, the same compressed air supply and the same basic technology — but with a different torch angle, different consumables and a different technique, it removes material rather than severing it. The result is a faster, cleaner and safer alternative to carbon arc gouging and grinding for a wide range of fabrication and repair tasks.
This guide covers what plasma gouging is, when to use it, how it compares to other methods, and the five key motion techniques that give you full control over the profile and depth of your gouge.
For a full introduction to plasma cutting, see our Complete Guide to Plasma Cutting.
Plasma arc gouging is a variation of plasma cutting in which the arc is used to melt and remove metal from the surface of a workpiece — creating a groove or channel — without severing the base material.
In plasma cutting, the torch is held perpendicular to the work surface and the arc cuts all the way through. In plasma gouging, the torch is angled to the surface and the arc melts into the material, while high-velocity gas blows the molten metal away to the side. The result is a controlled groove — the depth, width and profile of which you control through torch angle, travel speed and amperage.
The key differences from cutting are:
Plasma gouging is the right tool any time you need to remove material from the surface of metal without cutting through it. The most common applications are:
Plasma gouging is one of four common methods for removing metal. Understanding how it compares helps you choose the right approach for the job.
Plasma gouging’s main advantages over carbon arc gouging — the most common alternative in heavy fabrication — are its cleaner gouge surface (no carbon deposits, no carbon embrittlement of the base material), significantly lower noise levels, and the fact that it works on stainless steel and aluminium as well as mild steel. The gouged surface is ready to reweld with minimal or no grinding preparation.
The good news is you don’t need a separate machine for plasma gouging. Any plasma cutter that supports gouging consumables can gouge. What you do need:
Controlling the profile, depth and width of a plasma gouge comes down to mastering the five core motion techniques. Each produces a different result and is suited to different applications.
The most common technique. The torch is held at 35°–45° to the work surface and moved in a straight line along the area to be gouged. The arc is pushed forward into the material in the direction of travel.
The torch is moved in a side-to-side weaving motion while travelling forward, producing a wider, U-shaped groove. The width of the weave controls the width of the gouge.
The torch is moved in a circular or oval pattern to enlarge a hole, clean out an existing cutout, or create a recessed area. The torch angle and distance from the edge of the hole control the depth and profile.
A controlled sweep of the torch across the surface at a very shallow angle, removing a thin layer of material over a wide area. Used when you need to clean up a surface rather than cut a defined groove.
Gouging from the back side of a completed weld to expose the weld root before applying a back-weld pass. The torch is positioned under or behind the joint and angled to remove material from the root area without damaging the surrounding base metal.
All three Cutmaster+ models support plasma gouging with the appropriate gouging consumables for the SL60 1Torch®. For most gouging applications in a fabrication shop or on site, the Cutmaster 50+ or Cutmaster 70+ are the recommended choice — the higher amperage gives you better control over gouge depth and allows you to work at productive speeds without pushing the machine to its limits.
Contact your ESAB specialist or distributor to confirm the correct gouging consumable kit for your Cutmaster+ model.
What is plasma arc gouging, and how does it work?
Plasma arc gouging is a metal removal process that uses a high-temperature plasma arc to melt and remove material from the surface of a workpiece without cutting completely through it. Unlike plasma cutting, the torch is held at an angle, typically 35°–60°, allowing the operator to create controlled grooves or channels. High-velocity gas removes the molten metal, while torch angle, travel speed, and amperage determine the gouge depth and width.
What is the difference between plasma gouging and carbon arc gouging?
Plasma gouging uses a concentrated plasma arc and compressed gas to remove metal, while carbon arc gouging uses a carbon electrode and compressed air. Plasma gouging generally produces less noise and avoids carbon contamination of the base metal, often reducing post-gouge cleaning requirements. Carbon arc gouging can achieve high metal removal rates but typically generates more noise, fumes, and spatter.
What are the main applications of plasma arc gouging?
Plasma arc gouging is commonly used for weld removal, back gouging, defect repair, joint preparation, and industrial maintenance. It can remove defective welds, cracks, porosity, and unwanted metal before rewelding. The process is also suitable for creating grooves, enlarging holes, preparing plate edges, and removing damaged material from electrically conductive metals such as mild steel, stainless steel, and aluminium.
What are the different plasma gouging techniques?
The five main plasma gouging techniques are straight gouging, U-shaped or weave gouging, circle or hole gouging, wipe gouging, and back gouging. Straight gouging creates narrow grooves for weld removal, while weave gouging produces wider channels. Circle gouging is used for holes and recesses, wipe gouging removes shallow surface material, and back gouging prepares weld roots for full-penetration joints.
Can you use a plasma cutter for gouging?
Yes. Many plasma cutters can perform gouging when equipped with compatible gouging consumables and sufficient output amperage. The ESAB Cutmaster+ range supports plasma gouging using appropriate SL60 1Torch® consumables. The Cutmaster 50+ is suitable for light to medium gouging applications, while the higher-output Cutmaster 70+ offers greater material removal capability for heavy fabrication, weld repair, and back gouging on thicker plate.
