Every weld receives a visual inspection. It could be as simple as the welder looking at the weld and deciding that it’s fine. However, the term “welding visual inspection” generally refers to a formal qualification process designed to certify the weld and catch unsatisfactory welding. In pipe work, the finalized pipes will usually be channeling pressurized products that could blow through inadequate or compromised welds. Conducting a well-informed and qualified pipe welding visual inspection is especially important before process pipes are cleared for use.
A visual inspection of a pipe weld begins well before welding actually starts. It encompasses the choice of materials, joint preparation and fit-up, the welding process, and the final completed weld. While it’s impossible for a weld inspector to see inside the completed weld with their eyes alone, by performing visual inspections throughout the pipe welding process, it’s possible to minimize the number of weld rejections that occur during non-destructive testing (NDT) and improve welding productivity by keeping the need for rework to an absolute minimum.
Regardless of the method of welding being used, pipe welding begins by thoroughly cleaning the pipe’s interior, end face, and exterior of contaminants like oil, zinc, or paint. Pipes with wall thicknesses greater than about three millimeters aren’t welded as-is but are cleaned and then machined to create a bevel, so that when two pipes are placed face to face the angle of the bevels creates a groove opening out toward the exterior diameter of the pipe. After the bevel is machined it has to be cleaned again to get to remove machining oils from the workpiece.
Inspection of the pipe at this point in the process is important since contaminants that remain on the surface can cause porosity in the weld, and any burrs that remain that can cause uneven melting, disrupt puddle flow, or snag the electrode and change the travel speed. Misalignment of the pipes during fit-up or incorrect spacing can change the basic properties of the joints. A pre-welding visual inspection should also ensure that the angle of the bevel and the spacing and fit-up between the pipes is correct. In most orbital welding operations there is no root gap, and pipe faces directly abut one another, and are tack-welded into place. The quality of the tack welds, and the alignment of the pipe are what needs to be checked in these circumstances. Often with stainless steel and nickel alloys this automated welding requires an inert gas in the interior of the joint to prevent contamination of the weld. Any issue with spacings, the tack welds, or the backing gas can create weak contamination, porosity, or other welding defects.
Pipe welding usually requires multiple passes to complete, which creates the opportunity to check in-progress welds for flaws. Flaws in partially finished welds are much easier to fix than in completed welds as much less material generally needs to be ground away in order to fix the flaw.
A pipe welding visual inspection should look for the following:
Mitigation of welding flaws found during the welding process varies depending on the type of flaw and the severity. Undercut at the side of welds or poor weld distribution are only grounds for rework if it is severe or taking place in industries or on projects that demand a high degree of precision and structural performance. Usually, remediation is simply a matter of adjusting the welding machine’s settings and making sure that subsequent passes have proper distribution and fusion. Foreign material in the weld, porosity, and cracking mean reworking at least a section of a weld and could require starting over with new materials. This can be a very expensive prospect for some welding projects, and underlines the importance of visual inspections before starting and between passes in order to remedy flaws before they become larger problems.
The visual inspection that takes place immediately after welding is in some ways the least important one. If inspections were done properly before and during pipe welding, there shouldn’t be anything to catch. Inspection of the weld after it is completed acts as a final check to ensure that there is nothing obviously wrong with the weld.
Post-weld visual inspections for different pipe welding types typically include the following:
A common method of basic visual inspection is to bring a pipe’s interior pressure up to a level above that of the surrounding atmosphere and spray the weldment with soapy water or another medium that will bubble and make escaping air visible. This isn’t ideal because if leaks are detected it introduces a foreign material into the work area that can make rework more complicated. A more professional variant of this test is to introduce dye into the gas pumped into the pipe and look for leaks on the weld surface. Air and other gases are also compressible and it is possible to pressurize a pipe section to the point of explosive failure, so air testing is not recommended if it can be avoided. If pneumatic testing is used, strict standards are followed to prevent explosive failure of the weld or the piping. ASME B31.8 mandates that a pressure release valve be a part of the test loop and that it vent at either the test pressure plus 345 kilopascals (kPA) or at ten percent above the test pressure (whichever is the lower value).
Dye penetrant is used to test for surface indications and involves simply spraying the weld with a penetrating dye, allowing it to soak in, and wiping off the excess. The dye will penetrate into pores that are too small for the naked eye to perceive, and after the excess is wiped, the dye will remain in the pores, making them visible. If pinhole leaks or small cracks are found, the weld section will need to be removed and rewelded and dye penetrant testing repeated.
Visual inspection is just as important in orbital welding as in manual methods. Because orbital welding is a highly automated process, it can be more difficult for an operator to adjust weld parameters while the weld is in progress or to sense that something is going wrong. For example, it’s harder to register arc sputtering while watching the weld process remotely, removed from the physical feedback of welding. This makes it especially important that potential sources of variability in the arc are removed before welding begins.
The advantages of orbital pipe welding outweigh the disadvantages; however, gaining the full benefits—like fast completion of welds, machine precision, and replicability across joints—requires a stringent visual inspection before and during welding. A pipe welding visual inspection conducted with attention to detail will offer the most benefit to an orbital welding process and ensure welding productivity beyond what is possible with manual welding.
