Laser (Light Amplification by Stimulated Emission of Radiation) welding is a fusion welding process in which metals or thermoplastics are joined using a focused laser beam. It is the most advanced type of welding method and finds application across many industries spanning from aerospace and medical equipment to fine jewellery making.
In the laser welding process, a concentrated beam of light is focused on the cavity between the materials to be joined. The powerful laser beam melts the materials at their seams and fuses into a joint. A highly concentrated heat source allows laser welding in thin sheet metal to be conducted at high speeds of metres per minute. In thicker materials, laser welding can produce deep and narrow welds.
As the process involves low heat input, there is less thermal stress. The focused beam melts only a small surface area of the metal, resulting in minimised heat-induced internal stress and distortion to the workpiece.
High precision
Due to its high precision, faster processing time, wide material tolerance and consistent high quality, laser welding has various applications, including:
Some of the most common types of traditional welding processes include – Gas Metal Arc Welding (GMAW/MIG), Gas Tungsten Arc Welding (GTAW/TIG), Shielded Metal Arc Welding (SMAW) and Flux Cored Arc Welding (FCAW).
Laser welding and traditional welding each have their own set of advantages. Traditional welding is easy to implement and master and requires less investment, thus making it suitable for all fabrication and manufacturing sectors. Laser welding is the most advanced type of welding. It offers high precision, low heat distortion and faster processing time. This makes laser welding suitable for applications that require high precision. You must decide which welding method is right for you based on the application, type of project and budget.
Laser welding is widely used in industries that require high precision, speed, and consistency. Common applications include automotive manufacturing, aerospace, electronics, medical device production, and battery manufacturing. Its ability to create narrow, accurate welds with minimal heat distortion makes it particularly valuable for automated production environments.
The initial investment for laser welding equipment is typically higher than for traditional welding systems. However, laser welding can offer long-term cost savings through faster production speeds, reduced material distortion, lower rework rates, and greater automation capabilities. The overall cost-effectiveness depends on the project requirements, production volume, and materials being welded.
Yes. Traditional welding processes such as MIG, TIG, and stick welding may be more practical for field repairs, heavy fabrication, outdoor applications, and projects involving thicker materials or lower production volumes. Traditional welding equipment is often more portable and accessible, making it a preferred solution when precision automation is not required.
No, laser welding does not always require filler wire. Many laser welding applications join metal by melting and fusing the base materials directly. However, filler wire may be used when additional material is needed to bridge gaps, improve weld strength, modify weld properties, or enhance the overall quality of the joint. The need for filler wire depends on the material, joint design, and application requirements.
