Welding consumables — filler metals, nozzles, contact tips, liners, and shielding gases — account for a relatively small proportion of a welding operation's total cost, but have a disproportionately large impact on weld quality, productivity, and operational efficiency. Choosing the wrong consumable for an application can result in weld defects, excessive downtime, failed procedure qualifications, and costly rework.
This guide covers the principles of welding consumable selection, from matching filler metals to base materials across similar and dissimilar joints, through to the specific demands of heavy industrial and exotic alloy applications, and the practical considerations of torch consumable selection for MIG/GMAW welding.
Every welding consumable decision starts with understanding the base material or materials to be joined. The right consumable must be compatible with the base material chemistry, meet the mechanical property requirements of the joint, suit the welding process and position, and comply with any applicable code or procedure qualification requirements.
For most common structural materials — carbon and low-alloy steels, stainless steels, and aluminium — there are established filler metal selection tables that provide a reliable starting point. These tables cover both similar-material joints (welding the same material to itself) and dissimilar-material joints (joining two different alloys), and identify the appropriate filler wire designation under the relevant standard.
Key points when using selection tables:
→ Choosing Welding Consumables: Selection Tables for Similar and Dissimilar Materials
In heavy industrial welding — shipbuilding, pressure vessels, structural steelwork, heavy machinery, and similar demanding environments — the performance requirements placed on weld joints go beyond basic strength. Toughness, ductility, fatigue resistance, and the ability to perform under sustained mechanical stress in challenging operating conditions are all critical. These requirements make filler metal selection significantly more consequential than in light fabrication.
Conventional filler metals for carbon and low-alloy steels typically contain manganese as a key alloying element, contributing to strength and deoxidation. However, in heavy industrial welding, elevated manganese content in the filler metal can be a disadvantage — contributing to brittle microstructures in the weld zone that are susceptible to cracking under high stress or dynamic loading, and reducing the long-term ductility of the joint.
Low manganese filler metals are engineered with a reduced manganese content to address these issues. The primary benefits in heavy industrial applications are:
→ Exploring the Benefits of Low Manganese Filler Metals in Heavy Industrial Welding
A growing range of heavy industrial applications — in aerospace, power generation, chemical processing, and oil and gas — require welding of materials that go beyond standard carbon and stainless steels. These include nickel alloys, titanium alloys, Monel, Inconel, duplex and super-duplex stainless steels, and other exotic materials. Each presents specific challenges that standard filler metals are not designed to address.
Key considerations when working with exotic alloys:
In all cases, contamination control is critical. Exotic alloys are highly sensitive to contamination from moisture, oil, and atmospheric elements — meticulous cleaning and shielding protocols are not optional.
→ Specialised Filler Metals in Heavy Industrial Welding: Exotic Alloys and Demanding Applications
For MIG/GMAW welding, the consumables fitted to the torch — the nozzle, contact tip, liner, and inlet guide — are just as important as the filler metal. Incorrect selection or poor maintenance of torch consumables is one of the most common sources of inconsistent arc performance, spatter, burn-back, and premature consumable failure.
The primary function of the nozzle is to direct shielding gas to the weld pool. Nozzle selection affects gas coverage, access to the joint, and the ability to maintain the correct contact tip-to-work distance. The key variables are nozzle shape, bore diameter, and attachment type.
Nozzle shapes:
Attachment type:
Nozzle bore diameter should be matched to the wire diameter and amperage range of the application. Larger bore diameters provide better gas coverage at higher amperages but increase the overall torch profile. For applications requiring access to narrow joints, a smaller diameter nozzle or tapered shape may be necessary even if it reduces gas coverage slightly.
→ Four Steps to the Right Nozzle Selection for Your Welding Application
The contact tip transfers welding current to the wire and guides it to the arc. Contact tip bore diameter should be matched to the wire diameter — typically 10–15% oversize for aluminium wire (to account for its thermal expansion and softer surface) and a closer fit for steel. Tips with sharp burrs or rough internal bores cause wire shaving, erratic arc performance, and burn-back. For aluminium welding specifically, use only contact tips manufactured for aluminium wire.
The liner guides the wire from the drive rolls to the contact tip. For steel wire, standard steel liners are appropriate. For aluminium wire, the liner must be non-metallic — typically Teflon or nylon — to prevent abrasion and shaving of the soft aluminium surface. A damaged or contaminated liner is one of the most common causes of feedability problems, erratic arc, and burn-back in both steel and aluminium welding. Inspect and replace liners regularly as part of routine torch maintenance.
Explore more ESAB University articles on choosing welding consumables, selecting filler metals, and improving weld quality and performance.
How do I choose the right welding consumables for my application?
Choosing the right welding consumables starts with identifying the base material, welding process, joint requirements, and operating conditions. Filler metals must be compatible with the base alloy and meet the required strength, toughness, and corrosion resistance specifications. Nozzles, contact tips, and liners should also be selected based on wire diameter, welding amperage, and joint accessibility.
What is the difference between welding filler metals and torch consumables?
Filler metals are welding wires, rods, or electrodes that provide additional material to form the welded joint. Torch consumables, such as nozzles, contact tips, and liners, support the welding process by directing shielding gas, transferring electrical current, and guiding the welding wire. Both are essential for maintaining consistent arc performance, weld quality, and productivity.
Why are low manganese filler metals used in heavy industrial welding?
Low manganese filler metals are designed to provide improved toughness, ductility, and resistance to cracking in demanding welding applications. By controlling manganese content and weld metal composition, these consumables can help reduce the formation of brittle microstructures and improve performance under mechanical stress, impact, and fatigue loading.
What welding consumables are required for exotic alloys?
Exotic alloys such as titanium, Inconel, Monel, and duplex stainless steel require specialised filler metals matched to their chemical composition and mechanical properties. Proper filler selection helps maintain corrosion resistance, high-temperature performance, and weld integrity. Clean consumables, suitable shielding gases, and strict contamination control are also essential when welding these materials.
How do nozzles, contact tips, and liners affect MIG welding performance?
MIG welding torch consumables directly influence shielding gas coverage, wire feed consistency, and arc stability. Nozzles direct shielding gas to protect the weld pool, contact tips transfer welding current to the wire, and liners guide the wire through the torch. Incorrect sizing, wear, or contamination can lead to excessive spatter, erratic wire feeding, burn-back, porosity, and premature consumable failure.
