A Guide to Aluminium Welding
May 16, 2025
Whether you’re a beginner or a professional, welding aluminium can come with a host of challenges - from its lower melting point to its higher thermal conductivity. Knowing how to prepare the metal and your tools, as well as how to choose the right tools for the job can be the difference between failure and success. However there’s no need to worry - we’ve compiled the ultimate guide to aluminium welding, including the techniques and tools you need to achieve strong, clean welds on your project.
Understanding Aluminium Welding Challenges
Aluminium is a versatile material used across a variety of welding projects - from medical equipment to furniture, pipe railing and even architecture. Whilst each type of metal comes with its own challenge, aluminium can be especially difficult. This is due to the following factors:
  • Its oxide layer - aluminium naturally forms a thin oxide layer on its surface. Aluminium oxide has a higher melting point than aluminium (around 2,037 degrees celsius/ 3700 degrees fahrenheit, vs aluminium’s, which is around 660 degrees celsius/ 1220 degrees fahrenheit). This means the oxide layer will need to be removed or broken down before welding, for the best possible fusion. If you don’t remove it, it will impact the quality of your weld.
  • Aluminium alloy variations - Aluminium comes in a variety of alloys, all of which have different characteristics when it comes to welding. Some of them are more difficult to fuse, whilst others can be more likely to crack, for example.
  • Its high thermal conductivity - Aluminium disperses heat quickly, making it harder to maintain heat in the welding area. This can lead to inconsistency in welds. For this reason, you often need more precise control and higher heat for effective aluminium welding.
  • Its lower melting point - This means it can easily melt and flow away, making it harder to weld thicker pieces.
  • Its porosity - Aluminium is prone to porosity (trapping gas bubbles in the weld), which is caused by moisture or oil on the surface of the weld. This, in turn, weakens the weld.
  • Its tendency to distort - Aluminium generally expands and contracts more than other metal when you heat it. This leads to a higher likelihood of warping and distortion during your weld. This means you’ll need to maintain proper heat control and employ clamps to lower the risk of imperfection.
Choosing the Right Aluminium Welder
To help alleviate the challenges above, choosing the right welder and process is key to the success of your weld.
Aluminium Welding
Factors to consider
  • The welding process - this will help determine the type of welder you need (see comparison below).For a detailed comparison of the two main processes for aluminium, see our guide to MIG vs TIG for Aluminium.
  • Power supply - you will need AC (alternating current) for aluminium welding, as it helps remove the oxide layer whilst maintaining penetration. Alternatively, if you need more versatility, AC/DC may be the better choice.
  • The project environment - is it indoor or outdoor?
  • The location - you’ll have to consider how portable your chosen welder is, as well as its size.
  • Amperage range - Aluminium needs a higher amperage due to its high thermal conductivity. You’ll need to make sure your chosen welder’s amperage matches the thickness of aluminium you’re working with. Thicker aluminium will need 200A+, for example.
  • Gas type - whichever welder you’re using, you’ll need pure argon shielding gas. For higher heat input on thicker sections, a mix of argon and helium may be beneficial — see our guide to argon vs helium shielding gases for aluminium welding
  • Budget - TIG welders are generally more expensive than MIG ones. If you’re looking for a higher-end model with more advanced controls and AC/DC, these are more on the expensive side. However, this is what will help you achieve the most professional results.
  • Duty cycle - aluminium is a material that often requires continuous welding. That’s why choosing a welder with a high duty cycle will help you avoid frequent downtime.
  • Machine features - you should look for welders with adjustable balance control to help with cleaning the oxide layer. Preflow and postflow gas control will also help with shielding during the welding and cooling processes. You should also consider pulse settings to help control the heat input, reducing the chances of warping.
  • Torch features - when it comes to TIG welding aluminium, a water-cooled torch is ideal. It helps prevent overheating, which is especially helpful for applications that use high amperage.
  • Material thickness - MIG welders work better on thicker aluminium (4mm+), whereas TIG is the better choice for thinner aluminium (1-3mm)
  • Spool gun compatibility - if you’re opting for MIG, you should opt for a push-pull system or spool gun for consistent wire feeding. This will help stop the soft aluminium wire from getting tangled, as it’s prone to do in a standard MIG welder. For a deeper look at this challenge, see our guide to improving feedability and wire delivery in aluminium MIG welding
  • Brand reliability - when you choose your welder, it’s important to choose a reliable, trustworthy brand that uses high quality materials, such as ours.
MIG vs TIG vs STICK Welding for Aluminium
Type of Welding
MIG
TIG
STICK
Best Thickness
Medium to thick aluminium
Thin aluminium
Thick aluminium
Difficulty Level
Easy to learn
Harder, requires higher skill
Intermediate, requires practice
Equipment Cost
Medium
High
Low
Speed
Fast
Slow
Medium
Portability
Medium
Limited due to shielding gas
High
Precision
Medium
High
Low
Weld Appearance
Moderate
Clean and smooth
Rough
Outdoor use
Not ideal due to gas sensitivity
Good due to lack of a need for gas
MIG Welders
Advantages:
  • Fast, making them the right choice for projects where time is of the essence and precision is less important.
  • Great for thicker aluminium
  • Great for beginners
  • Ideal for indoor welding due to controlled shielding gas conditions
  • MIG with flux-cored wire works well for outdoor welding
  • The more cost-effective option
  • Great for thick aluminium (4mm+)
  • Automated feeding to help prevent tangling
  • Less heat distortion due to faster welding lessening the risks of warping
Considerations:
  • Needs a spool gun or a push-pull system to prevent issues with wire feeding and tangling
  • Can burn through thinner aluminium if it hasn’t been set up correctly.
  • Less precise and harder to control than a TIG welder
  • Needs pure argon shielding gas, and isn’t ideal for outdoor use as a result of the wind.
Types of MIG Welders
For professional and industrial aluminium MIG welding, ESAB's Warrior Edge DX delivers advanced aluminium MIG and pulsed MIG WeldModes, giving operators precise control of heat input, arc stability, and bead profile from thin sheet to heavy sections. The Warrior Edge is designed to work as a complete system alongside ESAB's aluminium-optimised wire feeders and push-pull torches, making it a reliable choice for demanding manual aluminium applications.
For automated and robotic aluminium MIG welding, the Aristo Edge is ESAB's fully integrated robotic welding system, purpose-built for high-productivity aluminium applications.
Explore ESAB's complete aluminium welding solutions.
TIG Welders
Advantages:
  • Precision and control - this makes it the best option for aluminium
  • Provides minimal splatter, offering smooth welds with minimal cleanup
  • Clean and high-quality welds
  • The AC current helps to break through the oxide layer
  • Works especially well on thin aluminium (1-3mm)
Considerations:
  • Requires a high level of control and skill to operate
  • Less beneficial for outdoor welding, as outdoor projects need extra shielding
  • The more expensive option
  • Slower than MIG or STICK welding
STICK Welders
Advantages:
  • Portability
  • Ideal for outdoor use - this is because there’s no need for shielding gas
  • Works better on dirty/ oxidised surfaces than TIG or MIG
  • Suitable for thicker pieces of aluminium
  • More affordable, with lower-cost equipment and consumables
Considerations:
  • Rough, inconsistent welds that need significant cleanup
  • Harder to use on aluminium, so less commonly used
  • Presents rod challenges in that aluminium electrodes are expensive
  • Has limited applications, and is not ideal for precision or use on thinner materials
Aluminium Welding Process
Step 1: Preparing the Aluminium
  • Remove the oxide layer to create a clean surface - you can use tools like a stainless steel wire brush for this. You should make sure to brush in a single direction, so that the oxide is properly removed instead of mixing into the aluminium.
  • Degreasing with an aluminium cleaner or acetone will help remove any contaminants from the aluminium before you start.
  • If the aluminium is thicker, you should make sure to preheat your welder to 200 degrees fahrenheit (65-95 degrees celsius), to reduce the chance of your weld cracking. It will also help improve weld penetration, leading to a cleaner weld.
  • Select your shielding gas - for thicker aluminium, a mix of argon and helium is often used to increase the heat input. Otherwise, 100% Argon is the most common option.
  • Choose your filler wire/rod - it's important to match your filler to the aluminium alloy you're welding. For guidance on making the right choice, see our guide to choosing the right filler metal for aluminium welding.
Step 2: Welding Techniques & Solutions to Common Issues
The techniques and considerations involved in the process of welding aluminium will depend upon your chosen tools. That being said, there are a number of best practices and things to avoid, such as:
  • Making sure to use the correct heat settings to help avoid excessive warping
  • Using clamps or other stabilising measures to keep your piece in place, helping to reduce the chance of warping and imperfections.
  • Welding in the opposite (reverse or backstep) direction can help you distribute heat more evenly throughout your piece
  • Incorrect filler choice or rapid cooling can lead to cracking in the piece. This can be avoided with gradual cooling, and selecting the correct filler rod.
  • Contaminants or an improper gas flow can cause tiny holes to appear in your piece (porosity). Make sure to have proper gas shielding, clean the material thoroughly, and avoid drafts that could spread contaminants around the piece.
  • Having too low of a heat or lower travel speed can lead to burn-through or overheating. You should opt for a lower amperage, a faster travel speed or pulsing to combat this.
Step 3: Cutting and Finishing your Weld
Effective methods involved in the finishing process include:
  • Grinding and bending - in this stage, you look to smooth down your weld, whilst avoiding removing too much material. It’s all about getting the excess material off, and removing any imperfections.
  • Sanding and polishing - this helps give your weld that smooth, polished look. You could even take it one step further and use a buffing wheel or a polishing compound to get a mirror-like finish.
  • Anodizing or painting - these are the optional steps to help create corrosion resistance and strengthen the longevity of your piece. A coating helps create an additional protective layer to protect your piece from the elements.
It’s important to take the following steps into account for the best possible finish:
  • Using lubrication helps prevent clogging when cutting your piece - this could include WD-40 or a cutting wax.
  • Working in a clean area helps avoid further contamination in the final stages of the project.
  • Making sure to use the appropriate tools will help ensure you don’t damage the piece itself, or your equipment.
  • Making sure to keep the heat under control during sanding or grinding as aluminium gets hot quickly.
How to Weld Aluminium with Different Welders
How to weld Aluminium with a TIG welder
Techniques & Considerations
  • An AC-balanced control helps find the right balance of oxide cleaning vs penetration
  • A high-frequency start can also help you limit and avoid any contamination
  • Pulse settings will help you control the heat input and reduce distortion in your weld
  • To get a sharp, stable arc you should taper the tungsten electrode
  • Maintain steady torch angle of 10-15 degrees
  • Avoid excessive heat - this will help prevent burn-through
  • The amount of amperage you need depends on the thickness of the aluminium, as well as factors such as the tungsten size, whether you’ve preheated the material, filler rod size and the current used. A foot pedal can be helpful when it comes to dynamically controlling your amperage.
Types of TIG Welders
There are a number of TIG welders available - you should always consider the factors above, such as environment and material, when selecting the right one. Potential options include:
Our selection of TIG welders allows you to compare the options to find the best choice for your weld.
How to Weld Aluminium with a MIG Welder
  • Using a spool gun or push-pull system can help you prevent wire feeding issues. Check out our guide Improving Feedability and Wire Delivery in Aluminium MIG Welding
  • A higher travel speed helps avoid burn-through and overheating.
  • You should push the torch instead of pulling it. This helps to prevent any contamination and improves the gas coverage.
  • You can avoid splatter and get a smoother arc if you opt for spray transfer mode when it comes to welding aluminium.
Similar to TIG welders, you should always consider the factors above, such as environment and material, when selecting the right MIG welder. Potential options include:
Our selection of MIG welders allows you to compare the options to find the best choice for your weld.
STICK Welding Aluminium
  • Make sure to use DCEP (DC Reverse Polarity)
  • Opting for stringer beads, as opposed to weaving, will help to prevent oxidation buildup
  • Keeping a short arc length helps to avoid excessive splatter
Types of STICK Welders
If you’re considering using a STICK welder for your project, there are a variety of options, such as the following:
You can use our STICK welders comparison tool to find the equipment that suits your needs.
How to Get Started
If you're looking to start your next aluminium weld, we're here to help. ESAB offers a complete range of aluminium welding solutions — from manual MIG and TIG setups through to fully automated and robotic systems — backed by application expertise and global support.
Explore our aluminium welding solutions or get in touch with an ESAB specialist to find the right setup for your project.
Frequently Asked Questions
Aluminium naturally forms a thin oxide layer when exposed to air. This oxide melts at a much higher temperature than the base metal, which can interfere with weld quality if it is not removed. Cleaning the material before welding helps reduce contamination, improve arc stability, and create stronger, more consistent welds. Proper preparation typically includes removing dirt, oil, moisture, and surface oxides.
Aluminium conducts heat quickly, making it more susceptible to burn-through, distortion, and inconsistent penetration than many other metals. It is also prone to porosity if contaminants are present during welding. Using the correct welding parameters, filler metal, shielding gas, and preparation techniques can help overcome these challenges and improve weld quality.
Yes. Both MIG and TIG welding are commonly used for aluminium, but each offers different advantages. MIG welding is often preferred for thicker materials and higher production speeds, while TIG welding provides greater precision and control for thin materials and applications requiring a high-quality appearance. The best process depends on the material thickness, project requirements, and desired finish.
Aluminum can be challenging to weld because it has a low melting point, conducts heat quickly, and forms a tough oxide layer on its surface. These characteristics can make it more susceptible to burn-through, distortion, contamination, and other welding defects if proper techniques are not used.
To prevent porosity, keep the aluminum clean and dry, remove the oxide layer before welding, use clean filler metal, ensure proper shielding gas coverage, and avoid contaminants such as oil, grease, moisture, or dirt. Proper storage and preparation of materials are essential for producing high-quality, porosity-free welds.
