The laser beam and its reflections are the most immediately recognised hazards in a laser welding environment — but they are not the only ones. Fire, welding fume, metal dust, thermite reactions and electrical hazards all present serious risks that must be understood and controlled. This guide covers the non-beam hazards associated with ESAB handheld laser welding systems and the measures required to manage them safely.
Fire Hazards
Laser welding can ignite flammable and combustible materials. The laser beam, its reflections and the heat generated by the welding process can all act as ignition sources:
- Keep all combustible materials away from the laser beam and the welding area. This includes paper, cardboard, wood, plastics, lubricants, solvents and any fabric not rated as flame-resistant.
- Assess the work area before welding for flammable materials and remove or shield them.
- Have appropriate fire extinguishing equipment immediately available. For metal fires (including dust and chip fires from laser welding of aluminium, titanium, magnesium and other reactive metals), a Class D fire extinguisher is required. Do not use water on metal fires — metal dusts reacting with water generate heat and hydrogen gas, posing an additional explosion risk.
Emergency Fire Procedure
- In the event of a fire, immediately shut down the laser using the emergency stop button
- Use the appropriate fire extinguisher for the type of fire — Class D for metal fires
- Evacuate the area and follow the facility’s emergency response plan
- Do not attempt to fight a fire if it cannot be safely controlled with the available extinguisher
Welding Fume Hazards
Laser welding generates smoke and fume composed of tiny particles and gases produced from the base material, filler wire (if used), protective gases, paints, coatings and chemical reactions in the weld pool. Welding fume is a known carcinogen and can cause serious harm to the lungs, heart, kidneys and central nervous system with repeated exposure.
- Keep your head clear of the fume plume — do not position yourself so that the rising fume column passes over your face during welding.
- Use the fume extraction system — the extraction system must capture fumes at source. Ensure it is operational and effective before starting any welding session.
- Weld in a ventilated area — general background ventilation supplements (but does not replace) source extraction.
- Monitor air quality routinely — perform routine air monitoring to measure fume levels in the welding area and confirm extraction effectiveness.
- Respiratory protection — in confined spaces or situations where adequate extraction cannot be achieved, wear appropriate respiratory protection. The ESAB laser-specific welding helmet provides face coverage and can be used with appropriate filtration.
Dust Explosion Hazards
Metal dust generated during laser welding presents a serious fire and dust explosion risk — a hazard that is less widely understood than the beam and fume risks but equally important to manage.
Dust explosions occur when combustible metal dust is suspended in air above the lower explosive concentration, and a sufficient ignition energy source is present. The initial explosion can scatter accumulated dust, triggering a more severe secondary explosion that is often the more destructive event.
- Clean collection boxes daily — scrap boxes, pre-boxes and dust collector boxes must be emptied and cleaned at least daily to prevent accumulation of combustible metal dust.
- Magnesium and its alloys — avoid laser cutting or welding magnesium and magnesium alloys. These materials have the highest dust explosion risk of any metal commonly encountered in fabrication environments.
- Aluminium and titanium dust — dust from laser welding of aluminium, titanium and zinc presents significant explosion risk. Manage and clean up these dusts promptly and carefully.
Thermite Reaction Hazards
A thermite reaction is a highly exothermic chemical reaction that produces intense heat and can cause an explosion. In laser welding environments, thermite reactions can be triggered when specific metal dusts come into contact with each other:
- Aluminium dust + iron oxide — the classic thermite reaction. Dust from laser welding aluminium, when mixed with iron oxide (rust) from steel, can ignite and produce an extremely high-temperature reaction that is very difficult to extinguish.
- Titanium, zinc and their alloys — dust from these materials can also cause dangerous reactions when mixed with oxidised iron or copper dust.
To prevent thermite reactions:
- Use dedicated machines for different materials wherever possible. Avoid using the same laser welding system for aluminium and steel without thorough cleaning between materials.
- Fully clean all dust from the work area, collection systems and surrounding surfaces before switching between materials.
- Prevent the mixing of metal dusts from different materials in collection boxes and extraction systems.
- Do not use water on metal or thermite fires — install and maintain appropriate Class D fire extinguishers.
Electrical Hazards
Laser welding power sources operate with high-voltage power supplies. Electrical hazards must be respected and managed with the same diligence as beam and fire hazards:
- Grounding — ensure the power source is properly earthed to prevent electrical shock. Check the earth connection before each operating session.
- No repairs without disconnection — do not perform repairs, maintenance or any work on electrical components without first fully disconnecting the power supply. Follow lockout/tagout procedures.
- Qualified personnel only — electrical maintenance and repair must only be carried out by qualified personnel. Do not attempt to service the laser source, power supply or electrical components without the appropriate training and authorisation.
- Inspect cables and connections — before each operating session, inspect power cables, earth connections and cooling hoses for damage. Do not use the system if any electrical component shows signs of damage or deterioration.
Maintenance and Inspection
Routine maintenance is essential for safe laser welding operation. A poorly maintained system presents hazards beyond those of a correctly maintained one — misaligned beams, damaged lenses that scatter laser energy, blocked extraction systems and deteriorating electrical connections all increase risk.
- Follow the manufacturer’s recommended maintenance schedule for all system components.
- Inspect and clean protective lenses and filters regularly. Contaminated or damaged optics can cause beam misalignment or scattering.
- Inspect the ventilation system regularly to verify effective fume and particle removal.
- Periodically check for wear and damage to system components as described in the maintenance section of the instruction manual.
- Only qualified personnel should service the laser source. Follow the manufacturer’s guidelines for replacing or servicing the laser module.
Emergency Procedures Summary
| Emergency | Immediate action |
| Fire | Shut down laser via emergency stop. Use appropriate extinguisher (Class D for metal fires). Evacuate. Follow facility emergency plan. |
| Laser eye or skin exposure | Seek medical attention immediately. Report to supervisor. Complete incident report. |
| Power failure or machine malfunction | Turn off the machine. Follow lockout/tagout procedures. Notify maintenance personnel. |
| Dust or thermite fire | Do not use water. Use Class D extinguisher. Evacuate. Follow facility emergency plan. |
