Choosing the right manual plasma cutter is one of the most straightforward purchasing decisions in the workshop — once you know what to look for. The market is full of options at varying price points, and the differences between them matter more than most buyers realise. This guide walks you through the key factors to evaluate before you buy, so you end up with a machine that does exactly what you need it to do — on day one and for years to come.
For a broader overview of plasma cutting technology, see our Complete Guide to Plasma Cutting.
Start with Material and Thickness
The single most important factor in choosing a manual plasma cutter is matching the machine to the material you actually cut — not the thickest material you might occasionally need to cut. Every plasma cutter has three capacity figures you need to understand:
  • Pierce capacity — the maximum thickness the machine can pierce (start a cut in the middle of the plate). This is the most honest measure of everyday cutting capability.
  • Recommended cut capacity — the thickness at which the machine cuts cleanly and at a productive speed. This is the figure to match to your typical work.
  • Maximum severance — the absolute maximum thickness the machine can separate, usually at very slow speed with a rough edge. This is not a practical working figure.
As a rule of thumb, choose a machine whose recommended cut capacity comfortably exceeds your typical material thickness. If you regularly cut 10mm mild steel, a machine rated at 12mm cut capacity is working at its limit. A machine rated at 20mm or 25mm gives you headroom, better cut quality and longer consumable life.
Match Amperage to Your Work
Output amperage drives cut capacity. Higher amperage cuts thicker material, but also draws more from the power supply and typically costs more. For most professional fabrication and site applications, the choice comes down to three bands:
  • Up to 30A — light fabrication, automotive bodywork, HVAC, maintenance and repair on thinner materials up to around 10–12mm. Single-phase supply, maximum portability.
  • 40–50A — the professional all-rounder. Handles the vast majority of workshop and site cutting tasks up to 20–25mm. The most popular range for trade and fabrication professionals.
  • 60–70A+ — heavy fabrication, structural steel, construction and industrial maintenance. Cuts comfortably up to 30mm and beyond. Available in single and three-phase.
Check the Power Supply Requirements
Many buyers overlook this until the machine arrives on site. Before you purchase, confirm:
  • Single-phase or three-phase? Most handheld plasma cutters up to around 50A run on single-phase 230V — compatible with a standard workshop or site supply. Higher-amperage models often require three-phase 400V, which is not available on all sites.
  • Input current draw — check the maximum input current (amps) the machine draws from the supply and confirm your circuit can handle it. Running a plasma cutter on an undersized circuit causes tripped breakers and potential damage to the machine.
  • Automatic voltage detection — some entry-level models, like the Cutmaster 30+, include automatic voltage detection that adjusts the output to match the available supply. Useful for site work where supply voltage can vary.
Understand Duty Cycle
Duty cycle tells you how long a machine can cut continuously within a ten-minute period before it needs to cool down. A 60% duty cycle at rated amperage means six minutes of cutting followed by four minutes of rest.
  • For occasional or varied use — a 60% duty cycle is perfectly adequate.
  • For continuous production cutting — look for a higher duty cycle, or choose a machine with more amperage headroom than you need. Running a machine below its maximum amperage improves the effective duty cycle significantly.
  • Overrunning the duty cycle triggers thermal protection and shuts the machine down. It won’t damage the machine, but it does kill productivity.
Air Supply: The Variable Most Buyers Ignore
A plasma cutter is only as good as the air supply feeding it. Poor air quality is the leading cause of bad cut quality and premature consumable wear — and it’s entirely avoidable.
  • Moisture — water in the air supply contaminates the plasma arc, causing spatter, rough cut edges and rapid electrode wear. An inline moisture separator and dryer is essential, not optional.
  • Oil — oil contamination from the compressor has the same effect. Use an oil separator in the airline, particularly with older or high-output compressors.
  • Pressure and flow — check the machine’s minimum air pressure and flow (CFM/l/min) requirements and confirm your compressor can meet them consistently under load. Insufficient air pressure causes the arc to extinguish mid-cut.
  • Filter kit — ESAB offers single and two-stage air filter kits designed specifically for use with the Cutmaster range. A two-stage filter is recommended for any environment where air quality is not guaranteed.
Consumable Life and Running Costs
Consumables — the electrode and cutting tip inside the torch — are the main ongoing cost of plasma cutting. They wear with use and need regular replacement. The differences between consumable systems can be significant over time:
  • Black Series consumables — the ESAB Cutmaster range comes standard with Black Series consumables, engineered for extended service life. Longer-lasting consumables mean less downtime and lower running costs per metre of cut.
  • Gouging consumables — if you intend to use the machine for gouging as well as cutting, check that the torch system supports gouging tips. The Cutmaster SL60 1Torch® accepts a full range of gouging consumables.
  • Grate cutting mode — when cutting expanded metal or grating, the arc fires into open air between strands, accelerating consumable wear. The Cutmaster 50+ and 70+ feature a dedicated grate cutting mode that reduces output during these open-air periods, significantly extending consumable life.
Torch Ergonomics and Features
The torch is the part of the system you interact with on every cut. It matters more than most specifications sheets suggest.
  • Trigger design — the ESAB SL60 1Torch® features a safety trigger lock to prevent accidental firing, and a 2T/4T function. In 4T mode, you press and release the trigger to start cutting, then press and release again to stop — so you’re not holding the trigger throughout long cuts. This makes a real difference to hand fatigue on extended work.
  • Double-tap trigger — tapping the trigger twice shuts the gas solenoid valve, conserving bottled air or nitrogen when not actively cutting. Particularly useful when working from cylinders rather than a compressor.
  • Torch angle — a 75° head is standard for most handheld cutting. A 180° straight body is available for semi-automated and mechanised applications.
  • Lead length — standard leads are 6.1m (20ft). 15.2m (50ft) leads are available for larger work areas where moving the power source is impractical.
Display and Controls
Older plasma cutters used a simple rotary dial. Modern machines offer significantly more control and feedback, which matters in a professional environment.
Cutmaster 30+ plasma cutter panel.
  • The Cutmaster 30+, 50+ and 70+ all feature a 4.3” TFT LCD display with a glove-friendly adjustment knob — clear to read in bright light or dim workshop conditions, and operable without removing your gloves.
  • The display gives you direct access to amperage setting, cutting mode selection (normal or grate), and 2T/4T trigger mode — all without needing to remove panels or refer to a manual.
  • Fault codes and diagnostic information are also displayed, making it easier to identify issues quickly rather than guessing.
Which Cutmaster Is Right for You?
Your application Recommended model Why
Light fabrication, automotive, HVAC, apprentice / training use, cutting up to 10mm Cutmaster 30+ Compact, lightweight, single-phase 230V, easy to use
General fabrication shop, trade professional, site cutting, mixed material thicknesses up to 25mm Cutmaster 50+ Best all-round capability, portable, includes CNC interface
Heavy fabrication, structural steel, construction, industrial maintenance, regular cutting above 20mm Cutmaster 70+ 70A output, 30mm cut capacity, built for demanding environments
Not sure which model fits your application? Get in touch with an ESAB specialist — we’ll help you get the right specification first time.
Portability and Build Quality
If the machine stays in the workshop, portability is less critical. If it goes to site, it matters enormously.
  • Weight — lighter machines are easier to carry to site, but very lightweight units often compromise on power supply components and duty cycle. The Cutmaster range balances portability with industrial build quality.
  • Housing — an all-weather industrial housing protects against dust, moisture and knocks on site. The Cutmaster range uses a robust housing with three carrying handles for easy one or two-person lifting.
  • IP rating — check the ingress protection rating if the machine will be used in wet or dusty environments.
Do You Need a CNC Interface?
Most fabricators buying a manual plasma cutter don’t need a CNC interface — but it’s worth knowing whether the option exists. The Cutmaster 50+ and 70+ both include a pre-installed 14-pin CNC interface with voltage divider, which enables:
  • Remote Start/Stop control
  • OK to Move signal for automated systems
  • Divided arc voltage output for height control
Combined with the optional ESAB MechPak straight-line and circle cutting attachment, this gives you semi-automated cutting capability from a manual machine — a practical step up from freehand cutting for shops that cut a lot of straight lines or repeat circles without the investment of a full CNC table.
