The laser beam and its reflections are the most immediately recognised hazards in a laser welding environment — but they are not the only ones. Fire, welding fume, metal dust, thermite reactions, and electrical hazards all present serious risks that must be understood and controlled. This guide covers the non-beam hazards associated with handheld laser welding systems and the measures required to manage them safely. For guidance on beam hazards and PPE, see our articles on laser beam hazards and radiation and laser welding PPE.
Fire Hazards
The laser beam, its reflections, and the heat generated by the welding process can all act as ignition sources. Laser welding can ignite flammable and combustible materials that would not normally be considered a significant fire risk in a conventional arc welding environment — because the laser beam can travel further and reflections can reach materials that are not immediately adjacent to the weld.
  • Keep all combustible materials away from the laser beam and the welding area — including paper, cardboard, wood, plastics, lubricants, solvents, and any fabric not rated as flame-resistant
  • Assess the work area before welding begins and remove or shield all flammable materials
  • Have appropriate fire extinguishing equipment immediately available and accessible — for metal fires (including dust and chip fires from laser welding of aluminium, titanium, magnesium, and other reactive metals), a Class D fire extinguisher is required
  • Do not use water on metal fires — metal dusts reacting with water generate heat and hydrogen gas, posing an additional explosion risk
Emergency fire procedure
  • Immediately shut down the laser using the emergency stop button
  • Use the appropriate fire extinguisher for the type of fire — Class D for metal fires
  • Evacuate the area and follow the facility's emergency response plan
  • Do not attempt to fight a fire if it cannot be safely controlled with the available extinguisher
Welding Fume Hazards
Laser welding generates smoke and fume composed of fine particles and gases produced from the base material, filler wire (where used), shielding gases, paints, coatings, and chemical reactions in the weld pool. Welding fume is classified as a known human carcinogen and can cause serious harm to the lungs, heart, kidneys, and central nervous system with repeated exposure. The fume generated by laser welding is typically finer in particle size than conventional arc welding fume, which increases its penetration into the respiratory system.
  • Keep your head clear of the fume plume — do not position yourself so that the rising fume column passes over your face during welding
  • Use the fume extraction system — the extraction system must capture fumes at source. Ensure it is operational and effective before starting any welding session. Source extraction is not optional
  • Weld in a ventilated area — general background ventilation supplements but does not replace source extraction
  • Monitor air quality routinely — perform routine air monitoring to measure fume levels in the welding area and confirm extraction effectiveness. Monitoring results should be recorded and reviewed
  • Respiratory protection — in confined spaces or situations where adequate extraction cannot be achieved, wear appropriate respiratory protection equipment (RPE) rated for welding fume. For general guidance on safe workspace setup for laser welding, see our article on setting up a safe laser welding workspace
Dust Explosion Hazards
Metal dust generated during laser welding presents a serious fire and dust explosion risk — a hazard that is less widely understood than beam and fume risks but equally important to manage. Dust explosions occur when combustible metal dust is suspended in air above the lower explosive concentration and a sufficient ignition source is present. The initial explosion can scatter accumulated dust, triggering a more severe secondary explosion that is typically the more destructive event.
  • Clean collection boxes daily — scrap boxes, pre-boxes, and dust collector boxes must be emptied and cleaned at least once per shift to prevent the accumulation of combustible metal dust
  • Magnesium and magnesium alloys — avoid laser cutting or welding magnesium and its alloys. These materials have the highest dust explosion risk of any metal commonly encountered in fabrication environments
  • Aluminium and titanium — dust from laser welding of aluminium, titanium, and zinc presents significant explosion risk. These dusts must be managed and cleaned up promptly and carefully — do not allow them to accumulate in collection systems or on surrounding surfaces
Thermite Reaction Hazards
A thermite reaction is a highly exothermic chemical reaction that produces intense heat and can cause an explosion or uncontrollable fire. In laser welding environments, thermite reactions can be triggered when specific metal dusts come into contact with each other.
The most common risk is aluminium dust combined with iron oxide (rust from steel). When mixed, these two materials can spontaneously ignite and produce a reaction temperature exceeding 2,500°C — far beyond the capability of conventional fire extinguishers to control. Dust from titanium, zinc, and their alloys can also cause dangerous reactions when mixed with oxidised iron or copper dust.
To prevent thermite reactions:
  • Use dedicated machines for different materials wherever possible — avoid using the same laser welding system for aluminium and steel without thorough cleaning between material changes
  • Fully clean all dust from the work area, collection systems, and surrounding surfaces before switching between dissimilar materials
  • Prevent the mixing of metal dusts from different materials in collection boxes and extraction systems — segregated collection is the safest approach
  • Never use water on a metal or thermite fire — install and maintain appropriate Class D fire extinguishers in the laser welding area
Electrical Hazards
Laser welding power sources operate with high-voltage power supplies. Electrical hazards must be respected and controlled with the same rigour as beam and fire hazards.
  • Earthing — ensure the power source is properly earthed before use to prevent electrical shock. Check the earth connection at the start of each operating session
  • Lockout/tagout — do not perform repairs, maintenance, or any work on electrical components without first fully disconnecting the power supply and following lockout/tagout (LOTO) procedures. This is a mandatory safety requirement, not a recommendation
  • Qualified personnel only — electrical maintenance and repair must only be carried out by qualified personnel. Do not attempt to service the laser source, power supply, or electrical components without the appropriate training and authorisation
  • Pre-shift inspection — before each operating session, inspect power cables, earth connections, and cooling hoses for signs of damage, abrasion, or deterioration. Do not use the system if any electrical component is damaged
Maintenance and Inspection
Routine maintenance is essential for safe laser welding operation. A poorly maintained system creates hazards beyond those of a correctly maintained one — misaligned beams, damaged lenses that scatter laser energy, blocked extraction systems, and deteriorating electrical connections all increase risk without warning.
  • Follow the manufacturer's recommended maintenance schedule for all system components — do not defer scheduled maintenance
  • Inspect and clean protective lenses and filters regularly. Contaminated or damaged optics can cause beam misalignment or uncontrolled scattering of laser energy
  • Inspect the ventilation and extraction system regularly to verify effective fume and particle removal — check for blockages, filter condition, and extraction flow rate
  • Periodically check all system components for wear and damage as described in the instruction manual
  • Only qualified personnel should service the laser source — follow the manufacturer's guidelines for replacing or servicing the laser module
Emergency Procedures Summary
Emergency Immediate Action
Fire Shut down laser via emergency stop. Use appropriate extinguisher — Class D for metal fires. Evacuate. Follow facility emergency plan.
Laser eye or skin exposure Seek medical attention immediately. Report to supervisor. Complete incident report. Do not delay medical assessment even if no immediate pain is felt — retinal injuries may not be immediately apparent.
Power failure or machine malfunction Turn off the machine. Apply lockout/tagout. Notify qualified maintenance personnel before the machine is returned to service.
Dust or thermite fire Do not use water. Use Class D extinguisher. Evacuate. Follow facility emergency plan.
