Output: 10–30 A Max Clean Cut: 3/8" (10 mm) Severance: 1/2" (12 mm) Approx. Weight: ~21 lb (9.5 kg) Designed for mobility without compromising cut quality. Ideal for HVAC, MRO, light fab, and jobsite work where fast setup and reliable pilot‑arc starts matter. Tip: If you regularly cut thicker than 10 mm, step up to the 50+ to avoid slow travel speeds and excessive dross.
Output: 15–50 A Max Clean Cut: up to ~1" (25 mm) Severance: up to ~1‑1/4" (32 mm) Duty Cycle: 60% @ 50 A A true all‑rounder: strong duty cycle, excellent consumable life, and capacity to handle both sheet and plate. Suits fabrication shops and contractors who need one machine for diverse work.Good to know: If portability is secondary and you want higher output for plate, consider the 70+ below.
Output: 70 A Max Clean Cut: 3/4" (19 mm) Severance: 1" (25 mm) CNC Ready: Machine torch & interface available Built for heavier work and longer runs, with the option to add a machine torch and interface for table use. A smart bridge into automation without committing to a dedicated mechanized system. Workflow tip: For hybrid shops (manual today, CNC tomorrow), the 70+ provides headroom and an easy path to mechanized cutting.
