Understand the plasma arc, torch consumables, gas pressure, and the settings that drive clean, fast cuts with the Thermal Dynamics Cutmaster 70+ and Cutmaster 30+.
A Thermal Dynamics Cutmaster doesn’t just cut—it performs a finely tuned process where power, air, and precision parts work together seamlessly. Understanding how this process works will help you maximize cut quality, reduce cleanup, and achieve consistent results on steel, stainless, and aluminum.
New to plasma cutting? Start with What Is Plasma Cutting? for foundational concepts, then return here for deeper technical insights.
Electricity + gas + constriction = plasma arc. That’s the formula behind every plasma cutter. Here’s how it works:
The Cutmaster 70+ at 70 A delivers enough energy for repeatable 3/4” cuts. The portable Cutmaster 30+ applies the same physics on thinner materials—making it a go-to for field service and light fabrication.
Before the torch is ignited, compressed gas begins flowing through the torch body. This is more than just a pre-flow—it serves two purposes:
Shops typically use clean, dry air for most materials. For specialty applications, gases such as nitrogen or oxygen may be used. If the air supply contains moisture or oil, arc stability suffers and consumables fail more quickly.
Once gas is flowing, the system creates a pilot arc between the electrode and nozzle inside the torch.
Pilot arc is one of the biggest advantages of plasma cutting compared to mechanical processes—it enables clean starts without physically contacting the metal surface.
As the operator lowers the torch toward the workpiece, the pilot arc seeks the path of least resistance. When the torch tip is close enough, the arc jumps from the nozzle to the grounded workpiece. This transition is called arc transfer.
This moment is critical—if the ground clamp is poor or the standoff distance is wrong, the arc may fail to transfer properly. That’s why a stable work clamp and correct technique are essential.
Once transferred, the plasma arc becomes a high-energy jet, reaching temperatures of 20,000°C (36,000°F) or more. The focused stream does two things at once:
Cut quality at this stage is controlled by several variables:
When dialed in correctly, the result is a narrow kerf, square edges, and minimal cleanup.
Your torch consumables do the heavy lifting in shaping and focusing the arc. Understanding each part helps extend lifespan and improve cut quality:
Inspect consumables often. Replace at the first signs of pitting, ovaling, or overheating—small investments prevent hours of rework.
Plasma cutters don’t fuse metal. Instead, they prepare material for welding by producing square, clean edges with a minimal heat-affected zone (HAZ). That’s why plasma cutting is a staple in fabrication workflows—parts are cut fast, then welded with minimal cleanup.
Gas pressure is critical to arc stability. Too low and the arc sputters. Too high and you waste gas while damaging consumables.
Always follow your exact manual values—these vary by material and thickness. For details on nonferrous metals, see Plasma Cutting Aluminum & Steel.
Don’t forget: Maintain a good ground clamp, service filters and dryers, and ensure your compressor provides enough CFM to keep pressure steady on long cuts.
Learn more about the innovations behind Thermal Dynamics systems and what sets them apart in cut quality.
