Welding Automation Welding Equipment
Laser (Light Amplification by Stimulated Emission of Radiation) welding is a fusion welding process in which metals or thermoplastics are joined using a focused laser beam. It is the most advanced type of welding method and finds application across many industries spanning from aerospace and medical equipment to fine jewelry making.
In the laser welding process, a concentrated beam of light is focused on the cavity between the materials to be joined. The powerful laser beam melts the materials at their seams and fuses into a joint. A highly concentrated heat source allows laser welding in thin sheet metal to be conducted at high speeds of meters per minute. In thicker materials, laser welding can produce deep and narrow welds.
As the process involves low heat input, there is less thermal stress. The focused beam melts only a small surface area of the metal, resulting in minimized heat-induced internal stress and distortion to the workpiece.
High precision
Due to its high precision, faster processing time, wide material tolerance, and consistent high quality, laser welding has various applications, including:
Some of the most common types of traditional welding processes include – Gas Metal Arc Welding (GMAW/MIG), Gas Tungsten Arc Welding (GTAW/TIG), Shielded Metal Arc Welding (SMAW), and Flux Cored Arc Welding (FCAW).
Laser welding and traditional welding each have their own set of advantages. Traditional welding is easy to implement and master and requires less investment, thus making it suitable for all fabrication and manufacturing sectors. Laser welding is the most advanced type of welding. It offers high precision, low heat distortion, and faster processing time. This makes laser welding suitable for applications that require high precision. You must decide which welding method is right for you based on the application, type of project, and budget.
